Serviio 1.0.1 on Vortexbox - console save issue
mrstuck
Post Mon Oct 08, 2012 1:14 pm
Hi all, I would really value any input to the following problem.
I have a vortexbox and recently successfully installed Serviio 1.0.1 onto it (using with my Sony Bravia 2011 TV). Unfortunately the vortexbox had an unresolvable kernel panic, so I had to reinstall everything from scratch including Serviio and the Serviio console. The Serviio console looks fine, but when I click the save button on any of the windows I just get 'http://192.168.0.xxx error: error' and nothing gets saved. This means I can't even enter the library locations.
When I look in the Serviio log there don't seem to be any errors.
Eg of recent output:
,545 INFO [PlaylistMaintainerThread] Started looking playlist changes
2012-10-04 22:07:47,032 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-10-04 22:07:48,708 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-10-05 07:56:28,693 INFO [RendererManager] Stored a new renderer: uuid='24eb0f86-f28a-a6ad-18ff-5a028880823b', name = 'Squeezebox Radio', ipAddress='192.168.0.254', profile = '1'
2012-10-05 22:07:11,841 INFO [UpdateChecker] Checking if a new version is available
2012-10-06 00:03:15,425 INFO [RendererManager] Stored a new renderer: uuid='72e25ce2-e7d3-a6cb-c6b4-2ac0c8fa640c', name = 'Squeezebox 3', ipAddress='192.168.0.254', profile = '1'
2012-10-06 08:10:20,774 INFO [RendererManager] Stored a new renderer: uuid='24eb0f86-f28a-a6ad-18ff-5a028880823b', name = 'Squeezebox Radio', ipAddress='192.168.0.254', profile = '1'
Once again any ideas very welcome ! Thanks
Post Mon Oct 08, 2012 3:18 pm
Re: Serviio 1.0.1 on Vortexbox - console save issue
Are you using the console on another pc pointed at your vortexbox, or are you using a web ui?
mrstuck
Post Mon Oct 08, 2012 5:57 pm
using the web UI on vortexbox
Post Mon Oct 08, 2012 6:13 pm
Which one and which version?
mrstuck
Post Mon Oct 08, 2012 9:03 pm
vortexbox 2.1 (fedora 16), serviio console 1.0.1 and the same version of serviio
Post Tue Oct 09, 2012 12:04 pm
I ment which WebUI, the PHP one or the Ajax one. The only one that will work is the PHP one, version 1.2a viewtopic.php?f=17&t=5330
mrstuck
Post Tue Oct 09, 2012 12:07 pm
Hi, it's the PHP version, if that helps.
Users browsing this forum: Google [Bot] and 2 guests
