Original Audio Stops streaming
dlucas10
Post Mon Oct 08, 2012 4:26 am
Hello!
First all, I'd like to thank you for the great work you're doing! Keep it up!
I'm working on installing Serviio on CentOS, and I got it installed without and major hiccups. I'm streaming to a PS3 Slim running the latest firmware. The one thing I'm noticing is that when I set the transcoding to "Keep Original" that it stops about 5 minutes into the movie. It stops at the same place every time. When I change it "Downmix to Stereo" I'm able to stream a lot longer (I haven't watched the full movie yet!). Ideally, I'd like to retain the Audio, and not have to downmix it!
When I enable debugging in the log, I see the error "[WebServer] Broken Pipe" when the stream stops.
I have Wild Media Server running as well on a different computer running Win7 and it's able to stream to the PS3 without an issue. So, I'm not convinced it's a connection issue (or at least someone would really need to prove that to me - after all, I'm a Network Engineer! :)). I built ffmpeg following directions from the Serviio Wiki http://wiki.serviio.org/doku.php?id=howto:linux:install:centos
Does anyone have any insight as to what might be causing this?
Info about the MKV:
(MKVInfo) + EBML head
(MKVInfo) |+ Doc type: matroska
(MKVInfo) |+ Doc type version: 2
(MKVInfo) |+ Doc type read version: 2
(MKVInfo) + Segment, size 8301546781
(MKVInfo) |+ Seek head
(MKVInfo) | + Seek entry
(MKVInfo) |  + Seek ID: 0x15 0x49 0xa9 0x66 (KaxInfo)
(MKVInfo) |  + Seek position: 4099
(MKVInfo) |  + Seek ID: 0x16 0x54 0xae 0x6b (KaxTracks)
(MKVInfo) |  + Seek position: 4214
(MKVInfo) |  + Seek ID: 0x11 0x4d 0x9b 0x74 (KaxSeekHead)
(MKVInfo) |  + Seek position: 8301404056
(MKVInfo) |  + Seek ID: 0x1c 0x53 0xbb 0x6b (KaxCues)
(MKVInfo) |  + Seek position: 8301380103
(MKVInfo) |  + Seek ID: 0x10 0x43 0xa7 0x70 (KaxChapters)
(MKVInfo) |  + Seek position: 5468
(MKVInfo) |+ EbmlVoid (size: 4010)
(MKVInfo) |+ Segment information
(MKVInfo) | + Timecode scale: 20832
(MKVInfo) | + Muxing application: libebml v0.7.8 + libmatroska v0.8.1
(MKVInfo) | + Writing application: DVDFab
(MKVInfo) | + Duration: 5308.149s (01:28:28.149)
(MKVInfo) | + Date: Sun Apr 08 04:03:04 2012 UTC
(MKVInfo) | + Title: The Lion King
(MKVInfo) | + Segment UID: 0xa4 0xb7 0x21 0x32 0x39 0xff 0x9f 0xb6 0xb9 0x2d 0xe0 0xd3 0x36 0x05 0x16 0xfd
(MKVInfo) |+ Segment tracks
(MKVInfo) | + A track
(MKVInfo) |  + Track number: 1 (track ID for mkvmerge & mkvextract: 0)
(MKVInfo) |  + Track UID: 3754925962
(MKVInfo) |  + Track type: video
(MKVInfo) |  + Enabled: 1
(MKVInfo) |  + Default flag: 1
(MKVInfo) |  + Forced flag: 0
(MKVInfo) |  + Lacing flag: 0
(MKVInfo) |  + MinCache: 1
(MKVInfo) |  + Timecode scale: 1
(MKVInfo) |  + Max BlockAddition ID: 0
(MKVInfo) |  + Codec ID: V_MPEG4/ISO/AVC
(MKVInfo) |  + Codec decode all: 1
(MKVInfo) |  + CodecPrivate, length 43 (h.264 profile: High @L5.1)
(MKVInfo) |  + Default duration: 41.708ms (23.976 frames/fields per second for a video track)
(MKVInfo) |  + Language: und
(MKVInfo) |  + Video track
(MKVInfo) |   + Pixel width: 1920
(MKVInfo) |   + Pixel height: 1080
(MKVInfo) |   + Interlaced: 0
(MKVInfo) |   + Display width: 1920
(MKVInfo) |   + Display height: 1080
(MKVInfo) |  + Track number: 2 (track ID for mkvmerge & mkvextract: 1)
(MKVInfo) |  + Track UID: 604623543
(MKVInfo) |  + Track type: audio
(MKVInfo) |  + Lacing flag: 1
(MKVInfo) |  + MinCache: 0
(MKVInfo) |  + Codec ID: A_DTS
(MKVInfo) |  + Language: eng
(MKVInfo) |  + Audio track
(MKVInfo) |   + Sampling frequency: 48000
(MKVInfo) |   + Channels: 6
(MKVInfo) |+ EbmlVoid (size: 1024)
(MKVInfo) |+ Chapters
(MKVInfo) | + EditionEntry
(MKVInfo) |  + EditionFlagHidden: 0
(MKVInfo) |  + EditionFlagDefault: 0
(MKVInfo) |  + EditionUID: 465520057
(MKVInfo) |  + ChapterAtom
(MKVInfo) |   + ChapterUID: 20520858
(MKVInfo) |   + ChapterTimeStart: 00:00:00.000000000
(MKVInfo) |   + ChapterFlagHidden: 0
(MKVInfo) |   + ChapterFlagEnabled: 1
(MKVInfo) |   + ChapterDisplay
(MKVInfo) |    + ChapterString: (01)00:00:00:000
(MKVInfo) |    + ChapterLanguage: eng
(MKVInfo) |   + ChapterUID: 3329379977
(MKVInfo) |   + ChapterTimeStart: 00:00:02.002000000
(MKVInfo) |    + ChapterString: (02)00:00:02:002
(MKVInfo) |   + ChapterUID: 1602470569
(MKVInfo) |   + ChapterTimeStart: 00:04:45.076000000
(MKVInfo) |    + ChapterString: (03)00:04:45:076
(MKVInfo) |   + ChapterUID: 4249419654
(MKVInfo) |   + ChapterTimeStart: 00:08:15.411000000
(MKVInfo) |    + ChapterString: (04)00:08:15:411
(MKVInfo) |   + ChapterUID: 173287854
(MKVInfo) |   + ChapterTimeStart: 00:11:33.984000000
(MKVInfo) |    + ChapterString: (05)00:11:33:984
(MKVInfo) |   + ChapterUID: 2846193071
(MKVInfo) |   + ChapterTimeStart: 00:14:14.562000000
(MKVInfo) |    + ChapterString: (06)00:14:14:562
(MKVInfo) |   + ChapterUID: 199729330
(MKVInfo) |   + ChapterTimeStart: 00:17:56.033000000
(MKVInfo) |    + ChapterString: (07)00:17:56:033
(MKVInfo) |   + ChapterUID: 935179673
(MKVInfo) |   + ChapterTimeStart: 00:22:59.753000000
(MKVInfo) |    + ChapterString: (08)00:22:59:753
(MKVInfo) |   + ChapterUID: 3753218716
(MKVInfo) |   + ChapterTimeStart: 00:25:41.122000000
(MKVInfo) |    + ChapterString: (09)00:25:41:122
(MKVInfo) |   + ChapterUID: 853496988
(MKVInfo) |   + ChapterTimeStart: 00:30:29.202000000
(MKVInfo) |    + ChapterString: (10)00:30:29:202
(MKVInfo) |   + ChapterUID: 3617231522
(MKVInfo) |   + ChapterTimeStart: 00:35:57.155000000
(MKVInfo) |    + ChapterString: (11)00:35:57:155
(MKVInfo) |   + ChapterUID: 264076967
(MKVInfo) |   + ChapterTimeStart: 00:40:19.083000000
(MKVInfo) |    + ChapterString: (12)00:40:19:083
(MKVInfo) |   + ChapterUID: 2753877123
(MKVInfo) |   + ChapterTimeStart: 00:41:19.435000000
(MKVInfo) |    + ChapterString: (13)00:41:19:435
(MKVInfo) |   + ChapterUID: 2126345657
(MKVInfo) |   + ChapterTimeStart: 00:44:21.950000000
(MKVInfo) |    + ChapterString: (14)00:44:21:950
(MKVInfo) |   + ChapterUID: 2514956209
(MKVInfo) |   + ChapterTimeStart: 00:48:25.569000000
(MKVInfo) |    + ChapterString: (15)00:48:25:569
(MKVInfo) |   + ChapterUID: 3465738373
(MKVInfo) |   + ChapterTimeStart: 00:50:12.217000000
(MKVInfo) |    + ChapterString: (16)00:50:12:217
(MKVInfo) |   + ChapterUID: 2760598458
(MKVInfo) |   + ChapterTimeStart: 00:53:19.779000000
(MKVInfo) |    + ChapterString: (17)00:53:19:779
(MKVInfo) |   + ChapterUID: 2860512945
(MKVInfo) |   + ChapterTimeStart: 00:57:55.847000000
(MKVInfo) |    + ChapterString: (18)00:57:55:847
(MKVInfo) |   + ChapterUID: 1376271261
(MKVInfo) |   + ChapterTimeStart: 01:01:01.574000000
(MKVInfo) |    + ChapterString: (19)01:01:01:574
(MKVInfo) |   + ChapterUID: 1139460274
(MKVInfo) |   + ChapterTimeStart: 01:02:37.336000000
(MKVInfo) |    + ChapterString: (20)01:02:37:336
(MKVInfo) |   + ChapterUID: 1429549991
(MKVInfo) |   + ChapterTimeStart: 01:08:54.630000000
(MKVInfo) |    + ChapterString: (21)01:08:54:630
(MKVInfo) |   + ChapterUID: 895718539
(MKVInfo) |   + ChapterTimeStart: 01:12:46.028000000
(MKVInfo) |    + ChapterString: (22)01:12:46:028
(MKVInfo) |   + ChapterUID: 4246572175
(MKVInfo) |   + ChapterTimeStart: 01:16:47.311000000
(MKVInfo) |    + ChapterString: (23)01:16:47:311
(MKVInfo) |   + ChapterUID: 599596953
(MKVInfo) |   + ChapterTimeStart: 01:20:50.136000000
(MKVInfo) |    + ChapterString: (24)01:20:50:136
(MKVInfo) |   + ChapterUID: 3935228600
(MKVInfo) |   + ChapterTimeStart: 01:23:28.878000000
(MKVInfo) |    + ChapterString: (25)01:23:28:878
(MKVInfo) |   + ChapterUID: 1569856129
(MKVInfo) |   + ChapterTimeStart: 01:28:28.303000000
(MKVInfo) |    + ChapterString: (26)01:28:28:303
(MKVInfo) |+ EbmlVoid (size: 101)
(MKVInfo) |+ Cluster
dlucas10
Post Mon Oct 08, 2012 7:58 pm
Re: Original Audio Stops streaming
Little more to add to this.
I understand they are different programs, etc but I wanted to share some more info. I loaded Plex Media Server on the same CentOS server, using the same MKV file and I was able to to watch the whole video without an issue. Actually, the connection is worse with this as I played the video on my iPAD over wireless where the Serviio is playing to my PS3 on a wired connection.
I understand they are different, but just wanted to pass along some more testing I've done.
Thanks!!
Dave
Post Tue Oct 09, 2012 7:00 am
Probably due to ffmpeg issue. Could you try to update with latest ffmpeg build (take care of build configuration option) ?
dlucas10
Post Tue Oct 09, 2012 12:31 pm
Hello!
Thank you for your reply.
Are you saying that the version on the Serviio site is not the latest build and I should get it via git from the source?
Here is the ffmepg version output from my server.
ffmpeg -version
ffmpeg version N-42368-gbf53863
built on Oct  7 2012 21:48:56 with gcc 4.4.6 20120305 (Red Hat 4.4.6-4)
configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid
dlucas10
Post Tue Oct 09, 2012 1:12 pm
I went ahead and downloaded a copy via git and recompiled ffmpeg.
ffmpeg -version
ffmpeg version 0.11.1 Copyright (c) 2000-2012 the FFmpeg developers
  built on Oct  9 2012 08:48:16 with gcc 4.4.6 20120305 (Red Hat 4.4.6-4)
  libavutil      51. 54.100 / 51. 54.100
  libavcodec     54. 23.100 / 54. 23.100
  libavformat    54.  6.100 / 54.  6.100
  libavdevice    54.  0.100 / 54.  0.100
  libavfilter     2. 77.100 /  2. 77.100
I tried the same file again and it failed in the exact same location with the same error. Any other thoughts?? :)
dlucas10
Post Tue Oct 09, 2012 6:42 pm
Hello!
So, I tested some other movies and they are working with the original build of ffmpeg (version N-42368-gbf53863). So, I'm trying to see if there is anything different with this particular movie.
When I ripped the movie, I chose to copy the audio and I've done this for the other movies as well. The only difference with this movie is that it's in DTS-HD Master 7.1 audio format. I believe that DLNA is "weird" when it comes to 7.1, but I'm wondering if there is something I need to build ffmpeg to support such movies? Or do I need to see about not ripping a movie that is 6.1 or 7.1 to only 5.1?
I will try to rip the movie again (I own it!), but without copying the audio.
Thanks!
Dave
Post Tue Oct 09, 2012 6:50 pm
dlucas10 wrote:The only difference with this movie is that it's in DTS-HD Master 7.1 audio format.
I think its probably something weird in this audio stream that sticks ffmpeg transcoding process, that's why I suggested to update ffmpeg...that does not solved it. Then you can contact ffmpeg support.
Could you enable detailed logging (see signature), find the ffmpeg command line used to trasncode this movie?
Try the same command line locally in a terminal and look at ffmpeg log during process.
dlucas10
Post Tue Oct 09, 2012 8:30 pm
Hello!
I was able to determine the command that is used:
/usr/local/bin/ffmpeg -i <location of file> -y -threads 1 -copyts -c:v mpeg2video -sameq -r 24000/1001 -g 15 -c:a ac3 -b:a 384k -ac 6 -map 0:0 -map 0:1 -sn -f mpegts /tmp/Serviio/transcoding-temp-1-4-ORIGINAL.stf
The difference between one that works and the one that does not is the "-ac 6" vs "-ac 2" of course "-ac 2" works.
When I run this command in the terminal, it works without and issue and seems to be transcoding (I'm not sure if there is detail logging?). The stream to the PS3 stops at ~3 minutes into it, where when I run the command in a terminal I'm able to get 15 minutes into it without it stopping. Another thing I noticed is that the process on the linux machine doesn't stop after the broken pipe is reported but the stream stops - is this normal? I'm able to look at the /tmp file and see that it increments even after the stream bombs.
The rip of the movie to AC3 just finished, and I will be testing it shortly.
Thanks for the help!
Dave
dlucas10
Post Wed Oct 10, 2012 1:04 am
Hello!
I posted on the ffmpeg forum and I posted the outputs of the ffmpeg, and it's working as expected according to them.
So, I'm not sure where to go from here to get Surround Sound 5.1 to work instead of stereo for movies.
Should I downgrade the version of Serviio to an earlier version? Any recommendations on next steps?
Post Wed Oct 10, 2012 6:47 am
Do you try to copy the "/tmp/....stf" result file to the serviio library and try to play it in native format ?
Users browsing this forum: Baidu [Spider] and 11 guests
