Transcode - Vizio - Costar
tannor
Post Sun Sep 16, 2012 5:05 pm
I tried to setup a profile to transcode files like this since the Costar will not support AC3:
File size                                : 963 MiB
Duration                                 : 52mn 44s
Overall bit rate                         : 2 552 Kbps
Encoded date                             : UTC 2012-09-07 23:51:35
Writing application                      : mkvmerge v2.7.0 ('Do It Again') built on Jul  2 2010 15:54:17
Writing library                          : libebml v0.7.7 + libmatroska v0.8.1
Format settings, ReFrames                : 5 frames
Duration                                 : 52mn 44s
Bit rate                                 : 2 118 Kbps
Bits/(Pixel*Frame)                       : 0.096
Stream size                              : 799 MiB (83%)
Writing library                          : x264 core 125 r2208 d9d2288
Duration                                 : 52mn 44s
Bit rate                                 : 384 Kbps
Stream size                              : 145 MiB (15%)
Here is the profile I used:
I added this to the bottom of profiles.xml right before the closing tag and then assigned it to my costar after restarting services:
<Profile id="150" name="Vizio Costar" extendsProfileId="1">
        <Video targetContainer="mpegts" targetACodec="mp3" aBitrate="320" forceInheritance="true">
When I do this, it will just sit there the media player and just hang, not sure what I am doing wrong? I am using GTVBox to connect:
and the log says this:
2012-09-16 13:05:33,204 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.15, Profile=Vizio Costar'
2012-09-16 13:05:33,204 DEBUG [ResourceDeliveryProcessor] Request for resource 8 and type 'MEDIA_ITEM' received
2012-09-16 13:05:33,204 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 8 (local)
2012-09-16 13:05:33,204 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 8)
2012-09-16 13:05:33,205 DEBUG [VideoDAOImpl] Reading a Video (id = 8)
2012-09-16 13:05:33,205 DEBUG [VideoDeliveryEngine] Delivering item '8' for client 'IPAddress=/192.168.1.15, Profile=Vizio Costar'
2012-09-16 13:05:33,205 DEBUG [VideoDeliveryEngine] Delivering file 'HDTrailers.mkv' using transcoding
2012-09-16 13:05:33,205 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.15, Profile=Vizio Costar'
2012-09-16 13:05:33,206 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-09-16 13:05:33,206 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file HDTrailers.mkv: AVC_TS_MP_HD_MPEG1_L3_ISO
2012-09-16 13:05:33,206 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 8) as read
2012-09-16 13:05:33,207 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-09-16 13:05:33,207 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-09-16 13:05:33,207 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-09-16 13:05:33,207 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-09-16 13:05:33,207 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Content-Range: bytes 0-49999999999/50000000000,Date: Sun, 16 Sep 2012 17:05:33 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-09-16 13:05:48,859 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-09-16 13:05:48,859 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
tannor
Post Mon Sep 17, 2012 2:04 pm
Re: Transcode - Vizio - Costar
OK I figured it out thanks with the help of the developer of GTVBox.
There is an option when creating a bookmark in GTVBox to the servillo server to use "Live Streaming Mode", I had left it unchecked, and forgot about it, as soon as I checked it all the videos work great.
So turned out had nothing to do with Servillo itself.
robojerk
Post Fri Oct 12, 2012 4:56 pm
I copied/edited your profile, but when I play a MPEG2 file with AC3 audio the video starts with audio, plays for 3-5 seconds, then kicks me out of the video. I'm using GTVBox on the Costar. I can post a log file later if needed. Any ideas why?
This is my first time messing with profiles.
        <Matches container="matroska" aCodec="ac3"/>
        <Matches container="mpeg" aCodec="ac3"/>
        <Matches container="mpegts" aCodec="ac3"/>
        <Matches container="mpegvideo" aCodec="ac3"/>
        <Matches container="mpeg2video" aCodec="ac3"/>
