.mkv File : "The data type is not supported" on PS3
astrotouf
Post Wed Aug 15, 2012 1:36 pm
Hi everybody !
I'm trying to watch an mkv file with my PS3 using serviio 1.0.1.
Here are the informations about the file :
Unique ID                                : 249134122375624857663653622084962696009 (0xBB6D7C94C76253FC9A2E245E51293B49)
Complete name                            : E:\Films\The.Expendables.2010.720p.VOSTFR.BRip.AC3.x264-ReMz.mkv
File size                                : 4.63 GiB
Duration                                 : 1h 39mn
Overall bit rate                         : 6 685 Kbps
Movie name                               : The.Expendables.2010.720p.BluRay.AC3.x264-WiNNy
Encoded date                             : UTC 2012-08-15 12:06:50
Writing application                      : mkvmerge v5.7.0 ('The Whirlwind') built on Jul  8 2012 20:08:51
Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
Duration                                 : 1h 39mn
Bit rate                                 : 6 470 Kbps
Height                                   : 544 pixels
Display aspect ratio                     : 2.35:1
Frame rate                               : 25.000 fps
Bits/(Pixel*Frame)                       : 0.372
Stream size                              : 4.38 GiB (95%)
Writing library                          : x264 core 104 r1713 c276662
Encoding settings                        : cabac=1 / ref=4 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=hex / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=6470 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Duration                                 : 1h 39mn
Bit rate                                 : 224 Kbps
Stream size                              : 159 MiB (3%)
Title                                    : AC3 2.0 ENGLISH
Text
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Title                                    : srt: Français
Language                                 : French
Forced                                   : Yes
Can anyone tell me what's the problem with the file.
Thank you !
Post Wed Aug 15, 2012 2:25 pm
Re: .mkv File : "The data type is not supported" on PS3
Don't know.
This file should be remux to mpegts container (format supported by PS3)
Could you enable detailed logging (see signature) and check the ffmpeg command line used to transcode your file ?
astrotouf
Post Wed Aug 15, 2012 3:15 pm
ffmpeg command line
C:\Program Files\Serviio\lib>ffmpeg.exe -i "E:\Films\The.Expendables.2010.720p.V
OSTFR.BRip.AC3.x264-ReMz.mkv"
g-config
Input #0, matroska,webm, from 'E:\Films\The.Expendables.2010.720p.VOSTFR.BRip.AC
3.x264-ReMz.mkv':
    title           : The.Expendables.2010.720p.BluRay.AC3.x264-WiNNy
    creation_time   : 2012-08-15 12:31:25
  Duration: 01:39:12.48, start: 0.000000, bitrate: 6684 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x544 [SAR 1:1 DAR 40:17],
 25 fps, 25 tbr, 1k tbn, 50 tbc
    Stream #0:1(eng): Audio: ac3, 48000 Hz, stereo, s16, 224 kb/s
      title           : AC3 2.0 ENGLISH
    Stream #0:2(fre): Subtitle: text
      title           : srt: Fran+ºais
serviio.log informations
2012-08-15 17:06:35,623 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2012-08-15 17:06:35,633 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.6, Profile=Playstation 3'
2012-08-15 17:06:35,633 DEBUG [ResourceDeliveryProcessor] Request for resource 3315 and type 'COVER_IMAGE' received
2012-08-15 17:06:35,634 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3315)
2012-08-15 17:06:35,636 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 3315
2012-08-15 17:06:35,637 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3508
2012-08-15 17:06:35,637 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-15 17:06:35,637 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 3508,Date: Wed, 15 Aug 2012 15:06:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-08-15 17:06:35,764 DEBUG [WebServer] Incoming connection from /192.168.1.6:50724
2012-08-15 17:06:35,765 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2012-08-15 17:06:35,766 DEBUG [ResourceTransportRequestHandler] GET /resource/3423/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.1:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Interactive,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-08-15 17:06:35,766 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2012-08-15 17:06:35,767 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.6, Profile=Playstation 3'
2012-08-15 17:06:35,768 DEBUG [ResourceDeliveryProcessor] Request for resource 3423 and type 'COVER_IMAGE' received
2012-08-15 17:06:35,768 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3423)
2012-08-15 17:06:35,769 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 3423
2012-08-15 17:06:35,769 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5609
2012-08-15 17:06:35,770 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-15 17:06:35,770 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5609,Date: Wed, 15 Aug 2012 15:06:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-08-15 17:06:35,889 DEBUG [WebServer] Incoming connection from /192.168.1.6:50723
2012-08-15 17:06:35,893 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2012-08-15 17:06:35,905 DEBUG [ResourceTransportRequestHandler] GET /resource/3302/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.1:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Interactive,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-08-15 17:06:35,913 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2012-08-15 17:06:35,923 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.6, Profile=Playstation 3'
2012-08-15 17:06:35,923 DEBUG [ResourceDeliveryProcessor] Request for resource 3302 and type 'COVER_IMAGE' received
2012-08-15 17:06:35,924 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 3302)
2012-08-15 17:06:35,935 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 3302
2012-08-15 17:06:35,940 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 5300
2012-08-15 17:06:35,941 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-15 17:06:35,941 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 5300,Date: Wed, 15 Aug 2012 15:06:35 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-08-15 17:06:36,642 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net3 (Atheros AR5B93 Wireless Network Adapter) and address 192.168.1.1, timeout = 0
2012-08-15 17:06:36,643 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 232e919c-d3d9-3eeb-ac51-8e4209d980af
2012-08-15 17:06:38,432 DEBUG [WebServer] Incoming connection from /192.168.1.6:50722
2012-08-15 17:06:38,433 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2012-08-15 17:06:38,435 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 232e919c-d3d9-3eeb-ac51-8e4209d980af from 192.168.1.6 (headers = [Host: 192.168.1.1:8895,Date: Wed, 15 Aug 2012 15:06:41 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";])
2012-08-15 17:06:38,435 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2012-08-15 17:06:38,436 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.1:8895,Date: Wed, 15 Aug 2012 15:06:41 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";]
2012-08-15 17:06:38,436 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2012-08-15 17:06:38,443 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Playstation 3'
2012-08-15 17:06:38,444 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:36
2012-08-15 17:06:45,668 DEBUG [WebServer] Incoming connection from /192.168.1.6:50721
2012-08-15 17:06:45,668 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2012-08-15 17:06:45,672 DEBUG [ResourceTransportRequestHandler] GET /resource/3980/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.1:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";,TimeSeekRange.dlna.org: npt=0.000-]]
2012-08-15 17:06:45,672 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2012-08-15 17:06:45,673 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.6, Profile=Playstation 3'
2012-08-15 17:06:45,673 DEBUG [ResourceDeliveryProcessor] Request for resource 3980 and type 'MEDIA_ITEM' received
2012-08-15 17:06:45,676 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 3980 (local)
2012-08-15 17:06:45,676 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 3980)
2012-08-15 17:06:45,677 DEBUG [VideoDAOImpl] Reading a Video (id = 3980)
2012-08-15 17:06:45,679 DEBUG [VideoDeliveryEngine] Delivering item '3980' for client 'IPAddress=/192.168.1.6, Profile=Playstation 3'
2012-08-15 17:06:45,679 DEBUG [VideoDeliveryEngine] Delivering file 'The.Expendables.2010.720p.VOSTFR.BRip.AC3.x264-ReMz.mkv' using transcoding
2012-08-15 17:06:45,679 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.6, Profile=Playstation 3'
2012-08-15 17:06:45,680 DEBUG [MediaItemDAOImpl] Getting file of media item 3980
2012-08-15 17:06:45,681 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: E:\Films\The.Expendables.2010.720p.VOSTFR.BRip.AC3.x264-ReMz.mkv
2012-08-15 17:06:45,682 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -i E:\Films\The.Expendables.2010.720p.VOSTFR.BRip.AC3.x264-ReMz.mkv -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-3980-4-ORIGINAL.stf
2012-08-15 17:06:46,191 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-08-15 17:06:46,210 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file The.Expendables.2010.720p.VOSTFR.BRip.AC3.x264-ReMz.mkv: AVC_TS_MP_HD_AC3_ISO
2012-08-15 17:06:46,212 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 3980) as read
2012-08-15 17:06:46,265 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-08-15 17:06:46,273 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-08-15 17:06:46,273 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-08-15 17:06:46,273 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-08-15 17:06:46,273 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-5952.0/5952,Date: Wed, 15 Aug 2012 15:06:46 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-08-15 17:06:47,605 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-08-15 17:07:08,696 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2012-08-15 17:07:10,433 DEBUG [PlaylistDAOImpl] Reading all Playlists
2012-08-15 17:07:10,485 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-15 17:07:10,485 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-15 17:07:15,611 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net3 (Atheros AR5B93 Wireless Network Adapter) and address 192.168.1.1, timeout = 0
I hope it will help.
Post Wed Aug 15, 2012 5:17 pm
Your mkv file seems good.
Could you open a windows terminal (type cmd on windows start execute...).
Could you try this command line (this is one used by serviio to transcode your file) ?
C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -fflags +genpts -i E:\Films\The.Expendables.2010.720p.VOSTFR.BRip.AC3.x264-ReMz.mkv -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\TEST.stf
Then post the ffmpeg result and copy the resulting output file to your serviio library and try to play.
astrotouf
Post Wed Aug 15, 2012 6:47 pm
Thank you for quick answer. here is the outpout of your command.
C:\Program Files\Serviio\lib>ffmpeg.exe -fflags +genpts -i E:\Films\The.Expendables.2010.720p.VOSTFR.BRip.AC3.
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack -
-enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runt
ime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --pkg-config=pkg-config
Input #0, matroska,webm, from 'E:\Films\The.Expendables.2010.720p.VOSTFR.BRip.AC3.x264-ReMz.mkv':
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x544 [SAR 1:1 DAR 40:17], 25 fps, 25 tbr, 1k tbn, 50 tb
c
[mpegts @ 03BFF260] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every 40 pkts
Output #0, mpegts, to 'C:\Windows\TEMP\Serviio\TEST.stf':
    encoder         : Lavf54.15.102
    Stream #0:0(eng): Video: h264, yuv420p, 1280x544 [SAR 1:1 DAR 40:17], q=2-31, 25 fps, 90k tbn, 25 tbc
    Stream #0:1(eng): Audio: ac3, 48000 Hz, stereo, 224 kb/s
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
  Stream #0:1 -> #0:1 (copy)
Read error at pos. 545267042 (0x20801d62)kB time=00:11:57.00 bitrate=6458.1kbits/s
frame=18351 fps=1056 q=-1.0 Lsize=  576767kB time=00:12:13.96 bitrate=6437.5kbits/s
video:512238kB audio:20071kB subtitle:0 global headers:0kB muxing overhead 8.352001%
It seems the ffmpeg has encountered an error while reading the file.
I tried to put the TEST.stf file in my movies folder, but serviio doesn't display it. I opened it with VLC on my PC, It was OK. I tried to change the stf extension to .mkv and played it on PS3 but the same error message appears.
Post Thu Aug 16, 2012 4:54 pm
astrotouf wrote:I opened it with VLC on my PC, It was OK. I tried to change the stf extension to .mkv and played it on PS3 but the same error message appears.
The output file is a mpegts (.ts extension), you can retry with .ts extension but it seems that ffmpeg had problem.
VLC is very permissive with format, PS3 not...
Kovally
Post Fri Oct 12, 2012 8:56 am
Can`t play some .mkv files on PS3
I apologize for my English.
I installed on QNAP 469 PRO Serviio 1.0.1. from http://forum.qnap.com/viewtopic.php?f=252&t=61671&start=15#p287412.
I can not play some mkv files on my PS3. Playable but not all mkv files. On the other side PS3 Media Server plays all files.
Help me please.
derby.log
Fri Oct 12 10:18:21 MSD 2012:
Booting Derby version The Apache Software Foundation - Apache Derby - 10.9.1.0 - (1344872): instance a816c00e-013a-539f-9f08-ffffb14cef4a
on database directory /share/MD0_DATA/.qpkg/Serviio1/library/db  with class loader sun.misc.Launcher$AppClassLoader@117140b
Loaded from file:/share/MD0_DATA/.qpkg/Serviio1/lib/derby.jar
java.vendor=Oracle Corporation
java.runtime.version=1.7.0-b147
user.dir=/share/MD0_DATA/.qpkg/Serviio1
derby.system.home=/share/MD0_DATA/.qpkg/Serviio1/library
derby.stream.error.file=../log/derby.log
Database Class Loader started - derby.database.classpath=''
2012-10-12 10:18:19,266 INFO  [MediaServer] ------------------------------------------------------------------------
2012-10-12 10:18:19,268 INFO  [MediaServer] Serviio DLNA media streaming server v 1.0.1 (rev. 6dbf7c6e334f+)
2012-10-12 10:18:19,268 INFO  [MediaServer] Petr Nejedly 2009-2012
2012-10-12 10:18:19,268 INFO  [MediaServer] http://www.serviio.org
2012-10-12 10:18:19,269 INFO  [MediaServer] Java 1.7.0-Oracle Corporation
2012-10-12 10:18:19,269 INFO  [MediaServer] OS Linux i386 2.6.33.2
2012-10-12 10:18:19,269 INFO  [MediaServer] File encoding: UTF-8
2012-10-12 10:18:19,270 INFO  [MediaServer] Headless mode enabled: true
2012-10-12 10:18:19,270 INFO  [MediaServer] User home dir: /share/homes/admin
2012-10-12 10:18:19,270 INFO  [MediaServer] Temp dir: /tmp
2012-10-12 10:18:19,270 INFO  [MediaServer] ------------------------------------------------------------------------
2012-10-12 10:18:19,777 INFO  [WebServer] Socket buffer set to 65535 bytes
2012-10-12 10:18:19,781 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2012-10-12 10:18:19,875 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2012-10-12 10:18:19,876 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2012-10-12 10:18:19,940 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-10-12 10:18:23,188 INFO  [prefs] Created user preferences directory.
2012-10-12 10:18:23,336 INFO  [MediaServer] ------------------------------------------------------------------------
2012-10-12 10:18:23,336 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2012-10-12 10:18:23,337 INFO  [MediaServer] ------------------------------------------------------------------------
2012-10-12 10:18:24,076 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2012-10-12 10:18:24,222 INFO  [Device] Created UPnP Device with UUID: 3915ea68-96c8-3d46-8665-8207a6f30e6c, bound address: 192.168.1.152
2012-10-12 10:18:25,410 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-10-12 10:18:26,252 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-10-12 10:18:26,687 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-10-12 10:18:27,392 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-10-12 10:18:27,985 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-10-12 10:18:28,275 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-10-12 10:18:29,303 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2012-10-12 10:18:29,370 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-10-12 10:18:30,839 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2012-10-12 10:18:32,619 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-10-12 10:18:33,350 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-10-12 10:18:33,766 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-10-12 10:18:33,844 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-10-12 10:18:34,181 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-10-12 10:18:34,323 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-10-12 10:18:34,977 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2012-10-12 10:18:35,231 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2012-10-12 10:18:35,910 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2012-10-12 10:18:36,648 INFO  [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2012-10-12 10:18:36,955 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2012-10-12 10:18:37,099 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2012-10-12 10:18:38,504 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2012-10-12 10:18:38,711 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2012-10-12 10:18:38,919 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2012-10-12 10:18:39,204 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2012-10-12 10:18:39,485 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2012-10-12 10:18:39,548 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2012-10-12 10:18:39,958 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2012-10-12 10:18:40,266 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2012-10-12 10:18:40,341 INFO  [PluginCompilerThread] Looking for plugins at /share/MD0_DATA/.qpkg/Serviio1/plugins
2012-10-12 10:18:40,341 INFO  [PluginCompilerThread] Started looking for plugins
2012-10-12 10:18:40,344 INFO  [UpdateChecker] Checking if a new version is available
2012-10-12 10:18:40,487 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-10-12 10:18:40,602 INFO  [WebServer] WebServer starting on port 8895
2012-10-12 10:18:40,616 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2012-10-12 10:18:40,616 INFO  [EventDispatcher] Starting EventDispatcher
2012-10-12 10:18:40,618 INFO  [RendererSearchSender] Searching for Renderer devices
2012-10-12 10:18:40,618 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2012-10-12 10:18:40,621 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface bond0 (bond0) and address 192.168.1.152, timeout = 0
2012-10-12 10:18:40,622 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2012-10-12 10:18:42,084 INFO  [PluginCompilerThread] Added Feed plugin Hypem (Hypem.groovy)
2012-10-12 10:18:42,668 INFO  [PluginCompilerThread] Added Web Resouce plugin HDTrailers (HDTrailers.groovy)
2012-10-12 10:18:42,922 INFO  [PluginCompilerThread] Added Web Resouce plugin M6replay (M6replay.groovy)
2012-10-12 10:18:43,012 INFO  [PluginCompilerThread] Added Feed plugin Crackle (Crackle.groovy)
2012-10-12 10:18:43,260 INFO  [PluginCompilerThread] Added Web Resouce plugin Syfy.com (Syfy.groovy)
2012-10-12 10:18:43,308 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2012-10-12 10:18:43,392 INFO  [PluginCompilerThread] Added Feed plugin TrailerAddictRss (TrailerAddictRss.groovy)
2012-10-12 10:18:43,693 INFO  [PluginCompilerThread] Added Feed plugin DailyMotion (DailyMotion.groovy)
2012-10-12 10:18:44,092 INFO  [PluginCompilerThread] Added Feed plugin MegavideoPlugin (MegavideoPlugin.groovy)
2012-10-12 10:18:44,459 INFO  [PluginCompilerThread] Added Web Resouce plugin Walla (Walla.groovy)
2012-10-12 10:18:44,566 INFO  [PluginCompilerThread] Added Feed plugin Tv3Play (Tv3Play.groovy)
2012-10-12 10:18:44,653 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2012-10-12 10:18:44,864 INFO  [PluginCompilerThread] Added Web Resouce plugin DI.FM - SKY.FM - JAZZRADIO.COM v1.0 (digitallyimported.groovy)
2012-10-12 10:18:45,526 INFO  [PluginCompilerThread] Added Web Resouce plugin myiplayer.com (MyiPlayer.groovy)
2012-10-12 10:18:45,823 INFO  [PluginCompilerThread] Added Feed plugin ABC (ABC.groovy)
2012-10-12 10:18:45,967 INFO  [PluginCompilerThread] Added Feed plugin SC2CastUrlExctractor (SC2Casts.groovy)
2012-10-12 10:18:46,351 INFO  [PluginCompilerThread] Added Feed plugin PennyArcade (PennyArcade.groovy)
2012-10-12 10:18:46,500 INFO  [PluginCompilerThread] Added Web Resouce plugin pbskids.org (PBSKids.groovy)
2012-10-12 10:18:46,928 INFO  [PluginCompilerThread] Added Web Resouce plugin 4OD (UK only) (Channel4od.groovy)
2012-10-12 10:18:47,211 INFO  [PluginCompilerThread] Added Web Resouce plugin Tune In (TuneIn.groovy)
2012-10-12 10:18:47,294 INFO  [PluginCompilerThread] Added Web Resouce plugin APVideo (APVideo.groovy)
2012-10-12 10:18:47,424 INFO  [PluginCompilerThread] Added Web Resouce plugin zonytvcom.info (ZonyTV.groovy)
2012-10-12 10:18:47,526 INFO  [PluginCompilerThread] Added Web Resouce plugin TED (TED.groovy)
2012-10-12 10:18:47,657 INFO  [PluginCompilerThread] Added Web Resouce plugin cwtv.com (CW.groovy)
2012-10-12 10:18:47,852 INFO  [PluginCompilerThread] Added Feed plugin CNN (CNN.groovy)
2012-10-12 10:18:47,983 INFO  [PluginCompilerThread] Added Feed plugin BlipTVUrlExtractor (BlipTVUrlExtractor.groovy)
2012-10-12 10:18:48,049 INFO  [PluginCompilerThread] Added Feed plugin SvtPlay (SvtPlay.groovy)
2012-10-12 10:18:48,121 INFO  [PluginCompilerThread] Added Feed plugin Tv8Play (Tv8Play.groovy)
2012-10-12 10:18:48,592 INFO  [PluginCompilerThread] Added Feed plugin BBC iPlayer (UK only) (IPlayer.groovy)
2012-10-12 10:18:48,672 INFO  [PluginCompilerThread] Added Web Resouce plugin Refresh (Refresh.groovy)
2012-10-12 10:18:48,725 INFO  [PluginCompilerThread] Added Feed plugin Vimeo (Vimeo.groovy)
2012-10-12 10:18:48,851 INFO  [PluginCompilerThread] Added Web Resouce plugin Escapist (Escapist.groovy)
2012-10-12 10:18:48,898 INFO  [PluginCompilerThread] Added Feed plugin AnOriant (AnOriant.groovy)
2012-10-12 10:18:48,948 INFO  [PluginCompilerThread] Added Feed plugin Tv3Play (Tv3Play (1).groovy)
2012-10-12 10:18:49,077 INFO  [PluginCompilerThread] Added Web Resouce plugin Rage (Rage.groovy)
2012-10-12 10:18:49,196 INFO  [PluginCompilerThread] Added Web Resouce plugin CBS.com (CBS.groovy)
2012-10-12 10:18:49,610 INFO  [PluginCompilerThread] Added Web Resouce plugin ITVPlayer (UK only) (ITVPlayer.groovy)
2012-10-12 10:18:49,713 INFO  [PluginCompilerThread] Added Feed plugin Arte (Arte.groovy)
2012-10-12 10:18:50,155 INFO  [PluginCompilerThread] Added Web Resouce plugin desistreams.tv (DesiStreams.groovy)
2012-10-12 10:18:50,245 INFO  [PluginCompilerThread] Added Web Resouce plugin PornHub (PornHub.groovy)
2012-10-12 10:18:50,290 INFO  [PluginCompilerThread] Added Feed plugin SnotrUrlExtractor (Snotr.groovy)
2012-10-12 10:18:50,345 INFO  [PluginCompilerThread] Added Feed plugin ARD Mediathek RSS Extractor (ARDMediathek.groovy)
2012-10-12 10:18:50,439 INFO  [PluginCompilerThread] Added Feed plugin TF1 (TF1.groovy)
2012-10-12 10:18:50,509 INFO  [PluginCompilerThread] Added Web Resouce plugin Shoutcast (Shoutcast.groovy)
2012-10-12 10:18:50,565 INFO  [PluginCompilerThread] Added Feed plugin Packers (Packers.groovy)
2012-10-12 10:18:50,660 INFO  [PluginCompilerThread] Added Web Resouce plugin W9replay (W9replay.groovy)
2012-10-12 10:18:50,750 INFO  [PluginCompilerThread] Added Feed plugin WAT (WAT.groovy)
2012-10-12 10:18:50,795 INFO  [PluginCompilerThread] Added Feed plugin PBSURLExtractor (PBS.groovy)
2012-10-12 10:18:50,846 INFO  [PluginCompilerThread] Added Feed plugin Orf (Orf.groovy)
2012-10-12 10:18:50,924 INFO  [PluginCompilerThread] Added Feed plugin Gulli (Gulli.groovy)
2012-10-12 10:18:51,042 INFO  [PluginCompilerThread] Added Web Resouce plugin Castalba (Castalba.groovy)
2012-10-12 10:18:51,086 INFO  [PluginCompilerThread] Added Feed plugin ReutersCom (ESPN Radio.groovy)
2012-10-12 10:18:51,132 INFO  [PluginCompilerThread] Added Feed plugin Tv6Play (Tv6Play.groovy)
2012-10-12 10:18:51,250 INFO  [PluginCompilerThread] Added Web Resouce plugin zengatv.com (ZengaTV.groovy)
2012-10-12 10:18:51,739 INFO  [PluginCompilerThread] Added Web Resouce plugin ComedyCentral (ComedyCentral.groovy)
2012-10-12 10:18:51,813 INFO  [PluginCompilerThread] Added Web Resouce plugin veetle.com (Veetle.groovy)
2012-10-12 10:18:51,866 INFO  [PluginCompilerThread] Added Feed plugin WimpCom (WimpCom.groovy)
2012-10-12 10:18:51,917 INFO  [PluginCompilerThread] Added Feed plugin GameTrailers (GameTrailers.groovy)
2012-10-12 10:18:52,069 INFO  [PluginCompilerThread] Added Feed plugin Hulu (US only) (Hulu.groovy)
2012-10-12 10:18:52,156 INFO  [PluginCompilerThread] Added Web Resouce plugin AlloCine (AlloCine.groovy)
2012-10-12 10:18:52,242 INFO  [PluginCompilerThread] Added Feed plugin Pluzz (Pluzz.groovy)
2012-10-12 10:18:52,431 INFO  [PluginCompilerThread] Added Web Resouce plugin CanalPlus (CanalPlus.groovy)
2012-10-12 10:18:52,594 INFO  [PluginCompilerThread] Added Feed plugin ABC iView (Australia only) (ABCiView.groovy)
2012-10-12 10:18:54,983 INFO  [PluginCompilerThread] Added Web Resouce plugin Playlist extractor (Playlist.groovy)
2012-10-12 10:18:55,297 INFO  [PluginCompilerThread] Added Feed plugin Gamespot (Gamespot.groovy)
2012-10-12 10:18:55,374 INFO  [PluginCompilerThread] Added Feed plugin Radio Bremen RSS Extractor (RadioBremen.groovy)
2012-10-12 10:18:55,516 INFO  [PluginCompilerThread] Added Web Resouce plugin YouTubeTop100 (Top100.groovy)
2012-10-12 10:18:55,647 INFO  [PluginCompilerThread] Added Web Resouce plugin Stepashka (Stepashka.groovy)
2012-10-12 10:18:55,701 INFO  [PluginCompilerThread] Added Feed plugin LiveFeeds (LiveFeeds.groovy)
2012-10-12 10:18:56,024 INFO  [PluginCompilerThread] Added Web Resouce plugin HaHaSport (HaHaSport.groovy)
2012-10-12 10:18:56,157 INFO  [PluginCompilerThread] Added Web Resouce plugin ILive (ILive.groovy)
2012-10-12 10:18:56,231 INFO  [PluginCompilerThread] Added Feed plugin RTVE (RTVE.groovy)
2012-10-12 10:18:56,336 INFO  [PluginCompilerThread] Added Feed plugin YouTube (Youtube.groovy)
2012-10-12 10:18:56,406 INFO  [PluginCompilerThread] Added Feed plugin NBA (NBA.groovy)
2012-10-12 10:18:56,650 INFO  [PluginCompilerThread] Added Web Resouce plugin TeamCoco (TeamCoco.groovy)
2012-10-12 10:18:57,047 INFO  [PluginCompilerThread] Added Feed plugin Yahoo Movies (YahooMovies.groovy)
2012-10-12 10:18:57,147 INFO  [PluginCompilerThread] Added Web Resouce plugin ustream.tv (USTREAM.groovy)
2012-10-12 10:18:57,225 INFO  [PluginCompilerThread] Added Web Resouce plugin Sopcast (Sopcast.groovy)
2012-10-12 10:18:57,284 INFO  [PluginCompilerThread] Added Feed plugin Tv4Play (Tv4Play.groovy)
2012-10-12 10:18:57,331 INFO  [PluginCompilerThread] Added Feed plugin ReutersCom (ReutersCom.groovy)
2012-10-12 10:19:06,675 INFO  [FeedUpdaterThread] Started looking for information about online resources
2012-10-12 10:19:06,677 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-10-12 10:19:06,697 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-10-12 10:19:06,698 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2012-10-12 10:25:24,511 WARN  [ProcessExecutor] Process /root/.serviio/opt/bin/ffmpeg has a return code of 137! This is a possible error.
2012-10-12 10:25:48,877 WARN  [ProcessExecutor] Process /root/.serviio/opt/bin/ffmpeg has a return code of 137! This is a possible error.
2012-10-12 10:26:18,313 WARN  [ProcessExecutor] Process /root/.serviio/opt/bin/ffmpeg has a return code of 137! This is a possible error.
2012-10-12 10:26:18,771 WARN  [ProcessExecutor] Process /root/.serviio/opt/bin/ffmpeg has a return code of 1! This is a possible error.
2012-10-12 10:26:19,061 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
   at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
   at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:125)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:95)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:120)
   at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:84)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:79)
   at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:191)
2012-10-12 10:26:19,087 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
profiles.xml
<Profiles version="1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="http://www.serviio.org/xsd/profiles/1.8/Profiles.xsd">
      ========================= DO NOT EDIT - start ====================================
   <Profile id="1" name="Generic DLNA profile">
      <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.GenericDLNAMessageBuilder</ContentDirectoryMessageBuilder>
      <ProtocolInfo>DLNA</ProtocolInfo>
      <DeviceDescription>
         <FriendlyName>Serviio ({computerName})</FriendlyName>
         <ModelName>Serviio Media Server</ModelName>
         <Manufacturer>Petr Nejedly</Manufacturer>
      </DeviceDescription>
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="audio/mpeg">MP3</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/L16;rate=44100;channels=1" name="LPCM">LPCM16_44_MONO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/L16;rate=44100;channels=2" name="LPCM">LPCM16_44_STEREO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/L16;rate=48000;channels=1" name="LPCM">LPCM16_48_MONO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/L16;rate=48000;channels=2" name="LPCM">LPCM16_48_STEREO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/x-ms-wma">WMA_BASE</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/x-ms-wma">WMA_FULL</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/mp4">AAC_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/mp4">AAC_ISO_320</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/vnd.dlna.adts">AAC_ADTS</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/vnd.dlna.adts">AAC_ADTS_320</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/flac">FLAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/ogg">OGG</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/jpeg">JPEG_SM</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/jpeg">JPEG_MED</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/jpeg">JPEG_LRG</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/jpeg">JPEG_TN</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/png">PNG_LRG</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/png">PNG_TN</MediaFormatProfile>
         <MediaFormatProfile mime-type="image/gif">GIF_LRG</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG1</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_PS_PAL</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_PS_NTSC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_EU</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_EU_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_EU_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_NA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_NA_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_NA_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_KO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_SD_KO_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG_TS_SD_KO_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG_TS_JP_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-msvideo">AVI</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-matroska">MATROSKA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-flv">FLV</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-dvr">DVR_MS</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/wtv">WTV</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/ogg">OGV</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">AVC_MP4_LPCM</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mp4">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AAC_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG4_P2_TS_ASP_AAC_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG4_P2_TS_ASP_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG4_P2_TS_ASP_MPEG2_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_MPEG2_L2</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">MPEG4_P2_TS_ASP_MPEG2_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">MPEG4_P2_TS_ASP_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AAC_MULT5_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_AAC_MULT5_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_MPEG1_L3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_MPEG1_L3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HD_DTS_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_HD_DTS_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HD_50_LPCM_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_HP_SD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HP_SD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">AVC_TS_HP_HD_MPEG1_L2_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">AVC_TS_HP_HD_MPEG1_L2_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVMED_BASE</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVMED_FULL</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVHIGH_FULL</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVMED_PRO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">WMVHIGH_PRO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf">VC1_ASF_AP_L1_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf">VC1_ASF_AP_L2_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf">VC1_ASF_AP_L3_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">VC1_TS_AP_L1_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">VC1_TS_AP_L2_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg">VC1_TS_HD_DTS_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts">VC1_TS_HD_DTS_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/3gpp">MPEG4_P2_3GPP_SP_L0B_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/3gpp">MPEG4_P2_3GPP_SP_L0B_AMR</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/3gpp">AVC_3GPP_BL_QCIF15_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/3gpp">MPEG4_H263_3GPP_P0_L10_AMR</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/3gpp">MPEG4_H263_MP4_P0_L10_AAC</MediaFormatProfile>
      </MediaFormatProfiles>
      <OnlineTranscoding>
            <Matches container="mp4"/>
            <Matches container="flv" vCodec="h264"/>
             <Matches container="applehttp" vCodec="h264"/>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384" forceInheritance="true">
            <Matches container="rtp"/>
            <Matches container="rtsp"/>
            <Matches container="applehttp"/>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384">
            <Matches container="asf"/> <!-- to support mms:// streams -->
            <Matches container="flv"/>
         <Audio targetContainer="mp3" aBitrate="384" forceInheritance="true">
            <Matches container="mp3"/>
         </Audio>
      </OnlineTranscoding>
      <AutomaticImageRotation>false</AutomaticImageRotation>
      <LimitImageResolution>true</LimitImageResolution>
      ========================= DO NOT EDIT - end   ====================================
<Profile id="4" name="Playstation 3" extendsProfileId="1">
    <!-- http://manuals.playstation.net/document/en/ps3/current/video/filetypes.html
       The following types of files can be played under  (Video).
       Memory Stick Video Format
        - MPEG-4 SP (AAC LC)
        - H.264/MPEG-4 AVC High Profile (AAC LC)
        - MPEG-2 TS(H.264/MPEG-4 AVC, AAC LC)
       MP4 file format
       MPEG-1 (MPEG Audio Layer 2)
       MPEG-2 PS (MPEG2 Audio Layer 2, AAC LC, AC3(Dolby Digital), LPCM)
       MPEG-2 TS (MPEG2 Audio Layer 2, AC3(Dolby Digital), AAC LC)
       MPEG-2 TS (H.264/MPEG-4 AVC, AAC LC)
       AVI
        - Motion JPEG (Linear PCM)
        - Motion JPEG (mu-Law)
       AVCHD (.m2ts / .mts)
       DivX
       WMV
        - VC-1(WMA Standard V2) -->
      <Detection>
         <HttpHeaders>
            <X-AV-Client-Info>.*PLAYSTATION 3.*</X-AV-Client-Info>
         </HttpHeaders>
      </Detection>
         <MediaFormatProfile mime-type="video/x-ms-wmv">VC1_ASF_AP_L1_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">VC1_ASF_AP_L2_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-wmv">VC1_ASF_AP_L3_WMA</MediaFormatProfile>
         <!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
            remux MKV with any video to MPEG2TS and possibly change audio to ac3, also AVI and FLV with H264
         <Video targetContainer="mpegts" >
            <Matches container="wtv" />
            <Matches container="asf" vCodec="mpeg2video"/> <!--  dvr-ms -->
         <!-- all other unplayable files just transcode to mpeg2 -->
         <Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video" aBitrate="384">
            <Matches container="flv" />
            <Matches container="ogg" />
            <Matches container="3gp" />
            <Matches container="asf" vCodec="mpeg1video"/> <!--  dvr-ms -->
            <Matches container="asf" vCodec="vc1" aCodec="wmapro"/> <!-- only 2 channel audio is natively supported -->
            <Matches container="asf" vCodec="wmv2"/>
         <Audio targetContainer="lpcm" aSamplerate="48000">
            <Matches container="flac" />
            <Matches container="adts" />
         </Audio>
      <OnlineTranscoding>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3">
         <!-- PS3 doesn't like mp3 with unlimited duration (eg online mp3 streams or streams transcoded into mp3 -->
         </Audio>
Post Fri Oct 12, 2012 11:14 am
Re: Can`t play some .mkv files on PS3
Kovally wrote:2012-10-12 10:26:19,061 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
Could ou enable detailed logging (see signature), find the ffmpeg command line used for transcoding and try locally the same command line ?
Kovally
Post Fri Oct 12, 2012 3:49 pm
Try open 3 different mkv files. One opened two does not open with different errors.
serviio.log (past from WARN and below)
2012-10-12 19:19:23,407 WARN  [ProcessExecutor] Process /root/.serviio/opt/bin/ffmpeg has a return code of 137! This is a possible error.
2012-10-12 19:19:23,407 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2012-10-12 19:19:23,409 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2012-10-12 19:19:23,537 DEBUG [TranscodingJobListener] Deleted temp file '/share/MD0_DATA/.qpkg/Serviio1/tmp/Serviio/transcoding-temp-473-4-ORIGINAL.stf': true
2012-10-12 19:19:23,559 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:19:23,559 DEBUG [MediaItemDAOImpl] Getting file of media item 465
2012-10-12 19:19:23,560 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /share/Download/transmission/completed/Nely/Hodejegerne.2011.BluRay.1080p.x264.DTS-HDChina.Rus.Eng.mkv
2012-10-12 19:19:23,560 DEBUG [ProcessExecutor] Starting /root/.serviio/opt/bin/ffmpeg -fflags +genpts -i /share/Download/transmission/completed/Nely/Hodejegerne.2011.BluRay.1080p.x264.DTS-HDChina.Rus.Eng.mkv -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a ac3 -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /share/MD0_DATA/.qpkg/Serviio1/tmp/Serviio/transcoding-temp-465-4-ORIGINAL.stf
2012-10-12 19:19:24,061 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-10-12 19:19:24,061 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Hodejegerne.2011.BluRay.1080p.x264.DTS-HDChina.Rus.Eng.mkv: AVC_TS_MP_HD_AC3_ISO
2012-10-12 19:19:24,061 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 465) as read
2012-10-12 19:19:24,098 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-12 19:19:24,098 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-10-12 19:19:24,099 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-12 19:19:24,099 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-10-12 19:19:24,099 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-6006.0/6006,Date: Fri, 12 Oct 2012 15:19:24 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-10-12 19:19:27,121 DEBUG [WebServer] I/O error: Broken pipe
2012-10-12 19:19:27,123 DEBUG [WebServer] Incoming connection from /192.168.1.196:54993
2012-10-12 19:19:27,123 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:19:27,124 DEBUG [ResourceTransportRequestHandler] GET /resource/465/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.152:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,TimeSeekRange.dlna.org: npt=0.000-,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-10-12 19:19:27,124 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:19:27,125 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:19:27,125 DEBUG [ResourceDeliveryProcessor] Request for resource 465 and type 'MEDIA_ITEM' received
2012-10-12 19:19:27,125 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 465 (local)
2012-10-12 19:19:27,125 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 465)
2012-10-12 19:19:27,126 DEBUG [VideoDAOImpl] Reading a Video (id = 465)
2012-10-12 19:19:27,127 DEBUG [VideoDeliveryEngine] Delivering item '465' for client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:19:27,127 DEBUG [VideoDeliveryEngine] Delivering file 'Hodejegerne.2011.BluRay.1080p.x264.DTS-HDChina.Rus.Eng.mkv' using transcoding
2012-10-12 19:19:27,127 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:19:27,127 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-10-12 19:19:27,128 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Hodejegerne.2011.BluRay.1080p.x264.DTS-HDChina.Rus.Eng.mkv: AVC_TS_MP_HD_AC3_ISO
2012-10-12 19:19:27,128 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 465) as read
2012-10-12 19:19:27,198 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-12 19:19:27,198 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-10-12 19:19:27,198 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-12 19:19:27,198 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-10-12 19:19:27,198 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-6006.0/6006,Date: Fri, 12 Oct 2012 15:19:27 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-10-12 19:19:28,311 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-10-12 19:19:32,665 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-10-12 19:19:32,665 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-10-12 19:19:33,319 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-10-12 19:19:38,326 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-10-12 19:19:43,333 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-10-12 19:19:48,340 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-10-12 19:19:53,346 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-10-12 19:19:58,354 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-10-12 19:19:58,798 DEBUG [WebServer] I/O error: Broken pipe
2012-10-12 19:19:59,336 DEBUG [WebServer] Incoming connection from /192.168.1.196:54989
2012-10-12 19:19:59,336 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:19:59,337 DEBUG [ResourceTransportRequestHandler] GET /resource/573/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.152:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Interactive,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-10-12 19:19:59,337 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:19:59,337 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:19:59,338 DEBUG [ResourceDeliveryProcessor] Request for resource 573 and type 'COVER_IMAGE' received
2012-10-12 19:19:59,338 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 573)
2012-10-12 19:19:59,338 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 573
2012-10-12 19:19:59,338 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 826
2012-10-12 19:19:59,339 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-12 19:19:59,339 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 826,Date: Fri, 12 Oct 2012 15:19:59 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-10-12 19:20:02,040 DEBUG [WebServer] Incoming connection from /192.168.1.196:54988
2012-10-12 19:20:02,041 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,042 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.196:
2012-10-12 19:20:02,042 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,048 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:02,052 DEBUG [WebServer] Incoming connection from /192.168.1.196:54987
2012-10-12 19:20:02,053 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,053 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.196:
2012-10-12 19:20:02,059 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = V_F, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-10-12 19:20:02,060 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-10-12 19:20:02,060 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-10-12 19:20:02,065 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:02,068 DEBUG [WebServer] Incoming connection from /192.168.1.196:54986
2012-10-12 19:20:02,069 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,070 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.196:
2012-10-12 19:20:02,070 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,077 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:02,081 DEBUG [WebServer] Incoming connection from /192.168.1.196:54985
2012-10-12 19:20:02,081 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,082 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.196:
2012-10-12 19:20:02,082 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,090 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = V_F, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-10-12 19:20:02,090 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-10-12 19:20:02,091 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-10-12 19:20:02,098 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:02,139 DEBUG [WebServer] Incoming connection from /192.168.1.196:54984
2012-10-12 19:20:02,185 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,186 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.196:
2012-10-12 19:20:02,186 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,195 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:02,198 DEBUG [WebServer] Incoming connection from /192.168.1.196:54983
2012-10-12 19:20:02,198 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,199 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.196:
2012-10-12 19:20:02,199 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,206 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = V_F, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-10-12 19:20:02,206 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-10-12 19:20:02,206 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-10-12 19:20:02,214 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:02,491 DEBUG [WebServer] Incoming connection from /192.168.1.196:54982
2012-10-12 19:20:02,491 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,492 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.196:
2012-10-12 19:20:02,492 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,499 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:02,502 DEBUG [WebServer] Incoming connection from /192.168.1.196:54981
2012-10-12 19:20:02,503 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,503 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.196:
2012-10-12 19:20:02,504 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,514 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = V_F^FOL_R1, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-10-12 19:20:02,515 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-10-12 19:20:02,515 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-10-12 19:20:02,520 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:02,527 DEBUG [WebServer] Incoming connection from /192.168.1.196:54980
2012-10-12 19:20:02,527 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,528 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.196:
2012-10-12 19:20:02,528 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,534 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:02,538 DEBUG [WebServer] Incoming connection from /192.168.1.196:54979
2012-10-12 19:20:02,538 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,539 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.196:
2012-10-12 19:20:02,539 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,545 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = V_F^FOL_R1, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-10-12 19:20:02,545 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-10-12 19:20:02,546 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-10-12 19:20:02,551 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:02,559 DEBUG [WebServer] Incoming connection from /192.168.1.196:54978
2012-10-12 19:20:02,559 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,560 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.196:
2012-10-12 19:20:02,560 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,567 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:02,570 DEBUG [WebServer] Incoming connection from /192.168.1.196:54977
2012-10-12 19:20:02,571 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,572 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.196:
2012-10-12 19:20:02,572 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:02,578 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = V_F^FOL_R1, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-10-12 19:20:02,578 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-10-12 19:20:02,579 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-10-12 19:20:02,584 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:03,361 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-10-12 19:20:03,775 DEBUG [WebServer] Incoming connection from /192.168.1.196:54976
2012-10-12 19:20:03,776 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:03,777 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.196:
2012-10-12 19:20:03,777 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:03,783 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:03,787 DEBUG [WebServer] Incoming connection from /192.168.1.196:54975
2012-10-12 19:20:03,787 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:03,788 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.196:
2012-10-12 19:20:03,788 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:03,794 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = V_F^FOL_R1$F1, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-10-12 19:20:03,794 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-10-12 19:20:03,794 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-10-12 19:20:03,799 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:03,802 DEBUG [WebServer] Incoming connection from /192.168.1.196:54974
2012-10-12 19:20:03,802 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:03,803 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.196:
2012-10-12 19:20:03,803 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:03,809 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:03,813 DEBUG [WebServer] Incoming connection from /192.168.1.196:54973
2012-10-12 19:20:03,813 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:03,814 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.196:
2012-10-12 19:20:03,814 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:03,820 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = V_F^FOL_R1$F1, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-10-12 19:20:03,820 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-10-12 19:20:03,821 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-10-12 19:20:03,825 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:03,833 DEBUG [WebServer] Incoming connection from /192.168.1.196:54972
2012-10-12 19:20:03,834 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:03,834 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#GetSystemUpdateID"' from 192.168.1.196:
2012-10-12 19:20:03,841 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:03,845 DEBUG [WebServer] Incoming connection from /192.168.1.196:54971
2012-10-12 19:20:03,845 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:03,846 DEBUG [ServiceControlRequestHandler] ServiceControl request received for action '"urn:schemas-upnp-org:service:ContentDirectory:1#Browse"' from 192.168.1.196:
2012-10-12 19:20:03,846 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:03,853 DEBUG [ContentDirectory] Browse() called for renderer Playstation 3 (profile 4) with parameters: objectID = V_F^FOL_R1$F1, browseFlag = BrowseMetadata, filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, startIndex = 0, count = 1, sortCriteria =
2012-10-12 19:20:03,853 DEBUG [AccessGroupDAOImpl] Reading a AccessGroup (id = 1)
2012-10-12 19:20:03,853 DEBUG [LocalContentCacheDecorator] Found entry in the cache (local_default), returning it
2012-10-12 19:20:03,862 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
2012-10-12 19:20:03,879 DEBUG [WebServer] Incoming connection from /192.168.1.196:54970
2012-10-12 19:20:03,879 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:03,879 DEBUG [ResourceTransportRequestHandler] GET /resource/554/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.152:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Interactive,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-10-12 19:20:03,880 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:03,880 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:20:03,880 DEBUG [ResourceDeliveryProcessor] Request for resource 554 and type 'COVER_IMAGE' received
2012-10-12 19:20:03,881 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 554)
2012-10-12 19:20:03,881 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 554
2012-10-12 19:20:03,881 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 887
2012-10-12 19:20:03,881 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-12 19:20:03,882 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 887,Date: Fri, 12 Oct 2012 15:20:03 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-10-12 19:20:03,953 DEBUG [WebServer] Incoming connection from /192.168.1.196:54969
2012-10-12 19:20:03,953 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:03,954 DEBUG [ResourceTransportRequestHandler] GET /resource/560/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.152:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Interactive,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-10-12 19:20:03,954 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:03,955 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:20:03,955 DEBUG [ResourceDeliveryProcessor] Request for resource 560 and type 'COVER_IMAGE' received
2012-10-12 19:20:03,955 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 560)
2012-10-12 19:20:03,956 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 560
2012-10-12 19:20:03,956 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 2869
2012-10-12 19:20:03,956 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-12 19:20:03,956 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 2869,Date: Fri, 12 Oct 2012 15:20:03 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-10-12 19:20:04,106 DEBUG [WebServer] Incoming connection from /192.168.1.196:54968
2012-10-12 19:20:04,106 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:04,107 DEBUG [ResourceTransportRequestHandler] GET /resource/570/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.152:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Interactive,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-10-12 19:20:04,107 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:04,108 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:20:04,108 DEBUG [ResourceDeliveryProcessor] Request for resource 570 and type 'COVER_IMAGE' received
2012-10-12 19:20:04,108 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 570)
2012-10-12 19:20:04,109 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 570
2012-10-12 19:20:04,109 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 959
2012-10-12 19:20:04,109 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-12 19:20:04,109 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 959,Date: Fri, 12 Oct 2012 15:20:04 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-10-12 19:20:04,139 DEBUG [WebServer] Incoming connection from /192.168.1.196:54967
2012-10-12 19:20:04,140 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:04,140 DEBUG [ResourceTransportRequestHandler] GET /resource/569/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.152:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Interactive,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-10-12 19:20:04,141 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:04,141 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:20:04,141 DEBUG [ResourceDeliveryProcessor] Request for resource 569 and type 'COVER_IMAGE' received
2012-10-12 19:20:04,141 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 569)
2012-10-12 19:20:04,142 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 569
2012-10-12 19:20:04,142 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 1839
2012-10-12 19:20:04,142 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-12 19:20:04,142 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 1839,Date: Fri, 12 Oct 2012 15:20:04 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-10-12 19:20:04,189 DEBUG [WebServer] Incoming connection from /192.168.1.196:54966
2012-10-12 19:20:04,189 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:04,190 DEBUG [ResourceTransportRequestHandler] GET /resource/550/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.152:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Interactive,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-10-12 19:20:04,190 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:04,191 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:20:04,210 DEBUG [ResourceDeliveryProcessor] Request for resource 550 and type 'COVER_IMAGE' received
2012-10-12 19:20:04,210 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 550)
2012-10-12 19:20:04,211 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 550
2012-10-12 19:20:04,211 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 826
2012-10-12 19:20:04,211 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-12 19:20:04,211 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 826,Date: Fri, 12 Oct 2012 15:20:04 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-10-12 19:20:04,240 DEBUG [WebServer] Incoming connection from /192.168.1.196:54965
2012-10-12 19:20:04,240 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:04,241 DEBUG [ResourceTransportRequestHandler] GET /resource/553/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.152:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Interactive,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-10-12 19:20:04,241 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:04,242 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:20:04,242 DEBUG [ResourceDeliveryProcessor] Request for resource 553 and type 'COVER_IMAGE' received
2012-10-12 19:20:04,242 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 553)
2012-10-12 19:20:04,243 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 553
2012-10-12 19:20:04,243 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 3322
2012-10-12 19:20:04,244 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-12 19:20:04,244 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 3322,Date: Fri, 12 Oct 2012 15:20:04 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-10-12 19:20:04,356 DEBUG [WebServer] Incoming connection from /192.168.1.196:54964
2012-10-12 19:20:04,357 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:04,358 DEBUG [ResourceTransportRequestHandler] GET /resource/556/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.152:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Interactive,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-10-12 19:20:04,358 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:04,359 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:20:04,359 DEBUG [ResourceDeliveryProcessor] Request for resource 556 and type 'COVER_IMAGE' received
2012-10-12 19:20:04,359 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 556)
2012-10-12 19:20:04,360 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 556
2012-10-12 19:20:04,360 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 918
2012-10-12 19:20:04,360 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-12 19:20:04,361 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 918,Date: Fri, 12 Oct 2012 15:20:04 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-10-12 19:20:04,390 DEBUG [WebServer] Incoming connection from /192.168.1.196:54963
2012-10-12 19:20:04,390 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:04,391 DEBUG [ResourceTransportRequestHandler] GET /resource/551/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.152:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Interactive,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-10-12 19:20:04,391 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:04,392 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:20:04,392 DEBUG [ResourceDeliveryProcessor] Request for resource 551 and type 'COVER_IMAGE' received
2012-10-12 19:20:04,392 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 551)
2012-10-12 19:20:04,392 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 551
2012-10-12 19:20:04,393 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 826
2012-10-12 19:20:04,393 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-12 19:20:04,393 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 826,Date: Fri, 12 Oct 2012 15:20:04 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-10-12 19:20:04,423 DEBUG [WebServer] Incoming connection from /192.168.1.196:54962
2012-10-12 19:20:04,423 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:04,424 DEBUG [ResourceTransportRequestHandler] GET /resource/555/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.152:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Interactive,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-10-12 19:20:04,424 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:04,425 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:20:04,425 DEBUG [ResourceDeliveryProcessor] Request for resource 555 and type 'COVER_IMAGE' received
2012-10-12 19:20:04,425 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 555)
2012-10-12 19:20:04,426 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 555
2012-10-12 19:20:04,426 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 894
2012-10-12 19:20:04,426 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-12 19:20:04,426 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 894,Date: Fri, 12 Oct 2012 15:20:04 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-10-12 19:20:04,456 DEBUG [WebServer] Incoming connection from /192.168.1.196:54961
2012-10-12 19:20:04,456 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:04,457 DEBUG [ResourceTransportRequestHandler] GET /resource/552/COVER_IMAGE HTTP/1.1, headers = [Host: 192.168.1.152:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Interactive,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";]]
2012-10-12 19:20:04,457 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:04,458 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:20:04,458 DEBUG [ResourceDeliveryProcessor] Request for resource 552 and type 'COVER_IMAGE' received
2012-10-12 19:20:04,458 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 552)
2012-10-12 19:20:04,459 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 552
2012-10-12 19:20:04,459 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 904
2012-10-12 19:20:04,459 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-10-12 19:20:04,459 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 904,Date: Fri, 12 Oct 2012 15:20:04 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-10-12 19:20:05,396 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface bond0 (bond0) and address 192.168.1.152, timeout = 0
2012-10-12 19:20:05,405 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 3915ea68-96c8-3d46-8665-8207a6f30e6c
2012-10-12 19:20:07,143 DEBUG [WebServer] Incoming connection from /192.168.1.196:54960
2012-10-12 19:20:07,144 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:07,145 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device 3915ea68-96c8-3d46-8665-8207a6f30e6c from 192.168.1.196 (headers = [Host: 192.168.1.152:8895,Date: Fri, 12 Oct 2012 15:20:06 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";])
2012-10-12 19:20:07,145 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:07,146 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.1.152:8895,Date: Fri, 12 Oct 2012 15:20:06 GMT,User-Agent: UPnP/1.0,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment Inc."; mn="PLAYSTATION 3"; mv="1.0";]
2012-10-12 19:20:07,146 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:07,150 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'Playstation 3'
2012-10-12 19:20:07,211 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:47
2012-10-12 19:20:08,369 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-10-12 19:20:11,051 DEBUG [WebServer] Incoming connection from /192.168.1.196:54959
2012-10-12 19:20:11,052 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:11,053 DEBUG [ResourceTransportRequestHandler] GET /resource/11/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.152:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";,TimeSeekRange.dlna.org: npt=0.000-]]
2012-10-12 19:20:11,053 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:11,053 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:20:11,054 DEBUG [ResourceDeliveryProcessor] Request for resource 11 and type 'MEDIA_ITEM' received
2012-10-12 19:20:11,054 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 11 (local)
2012-10-12 19:20:11,054 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 11)
2012-10-12 19:20:11,054 DEBUG [VideoDAOImpl] Reading a Video (id = 11)
2012-10-12 19:20:11,055 DEBUG [VideoDeliveryEngine] Delivering item '11' for client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:20:11,055 DEBUG [VideoDeliveryEngine] Delivering file 'Killer.Elite.2011.Blu-ray.1080p.AVC.Rus.Eng.mkv' using transcoding
2012-10-12 19:20:11,055 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-465-4-ORIGINAL.stf', will stop the job
2012-10-12 19:20:11,056 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-465-4-ORIGINAL.stf'
2012-10-12 19:20:11,056 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-240,5,main]
2012-10-12 19:20:11,056 DEBUG [ProcessUtils] Sending kill -9 to the Unix process: 11897
2012-10-12 19:20:11,056 DEBUG [ProcessExecutor] Starting kill -9 11897
2012-10-12 19:20:11,061 WARN  [ProcessExecutor] Process /root/.serviio/opt/bin/ffmpeg has a return code of 137! This is a possible error.
2012-10-12 19:20:11,061 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2012-10-12 19:20:11,061 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2012-10-12 19:20:11,225 DEBUG [TranscodingJobListener] Deleted temp file '/share/MD0_DATA/.qpkg/Serviio1/tmp/Serviio/transcoding-temp-465-4-ORIGINAL.stf': true
2012-10-12 19:20:11,226 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:20:11,226 DEBUG [MediaItemDAOImpl] Getting file of media item 11
2012-10-12 19:20:11,226 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /share/Download/transmission/completed/Movie/Killer.Elite.2011.Blu-ray.1080p.AVC.Rus.Eng.mkv
2012-10-12 19:20:11,227 DEBUG [ProcessExecutor] Starting /root/.serviio/opt/bin/ffmpeg -fflags +genpts -i /share/Download/transmission/completed/Movie/Killer.Elite.2011.Blu-ray.1080p.AVC.Rus.Eng.mkv -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /share/MD0_DATA/.qpkg/Serviio1/tmp/Serviio/transcoding-temp-11-4-ORIGINAL.stf
2012-10-12 19:20:11,368 WARN  [ProcessExecutor] Process /root/.serviio/opt/bin/ffmpeg has a return code of 1! This is a possible error.
2012-10-12 19:20:11,368 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2012-10-12 19:20:11,727 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
   at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
   at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:125)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:95)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:120)
   at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:84)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:79)
   at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:191)
2012-10-12 19:20:11,732 DEBUG [WebServer] Incoming connection from /192.168.1.196:54957
2012-10-12 19:20:11,732 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:11,733 DEBUG [ResourceTransportRequestHandler] GET /resource/11/MEDIA_ITEM/AVC_TS_MP_HD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.152:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";,TimeSeekRange.dlna.org: npt=0.000-]]
2012-10-12 19:20:11,733 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.196
2012-10-12 19:20:11,734 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:20:11,734 DEBUG [ResourceDeliveryProcessor] Request for resource 11 and type 'MEDIA_ITEM' received
2012-10-12 19:20:11,734 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 11 (local)
2012-10-12 19:20:11,734 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 11)
2012-10-12 19:20:11,735 DEBUG [VideoDAOImpl] Reading a Video (id = 11)
2012-10-12 19:20:11,735 DEBUG [VideoDeliveryEngine] Delivering item '11' for client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:20:11,736 DEBUG [VideoDeliveryEngine] Delivering file 'Killer.Elite.2011.Blu-ray.1080p.AVC.Rus.Eng.mkv' using transcoding
2012-10-12 19:20:11,736 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.196, Profile=Playstation 3'
2012-10-12 19:20:11,736 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
2012-10-12 19:20:13,374 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-10-12 19:20:18,379 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-10-12 19:20:23,785 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-10-12 19:20:28,389 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-10-12 19:20:32,666 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-10-12 19:20:32,666 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-10-12 19:20:33,394 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-10-12 19:20:38,399 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
Kovally
Post Mon Oct 15, 2012 11:25 am
Re: .mkv File : "The data type is not supported" on PS3
Аny thoughts about problem solution. Thanks in advance.
Post Mon Oct 15, 2012 12:40 pm
What is your ffmpeg version ?
Could you try with this one : http://www.serviio.org/download ?
Take care of compile config opion.
Kovally
Post Tue Oct 16, 2012 9:56 am
Thanks to answer.
I do not know where to look version ffmpeg.
Download from your link Serviio for Linux and overwrite files in directory Serviio in NAS from archive. This not help with those issues errors.
What else can I try?
Post Tue Oct 16, 2012 10:35 am
Could ou try locally in a terminal the same ffmpeg command line ?
/root/.serviio/opt/bin/ffmpeg -fflags +genpts -i "/share/Download/transmission/completed/Movie/Killer.Elite.2011.Blu-ray.1080p.AVC.Rus.Eng.mkv" -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /share/MD0_DATA/.qpkg/Serviio1/tmp/Serviio/transcoding-temp-11-4-ORIGINAL.stf
Kovally
Post Sat Oct 20, 2012 10:45 am
Illico wrote:Could ou try locally in a terminal the same ffmpeg command line ?
I try command line as you pointed out, and in the second case added in path MDO_DATA. The result is the same.
login as: admin
admin@192.168.1.152's password:
[~] # /root/.serviio/opt/bin/ffmpeg -fflags +genpts -i "/share/Download/transmission/completed/Movie/Killer.Elite.2011.Blu-ray.1080p.AVC.Rus.Eng.mkv" -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /share/MD0_DATA/.qpkg/Serviio1/tmp/Serviio/transcoding-temp-11-4-ORIGINAL.stf       /root/.serviio/opt/bin/ffmpeg: error while loading shared libraries: librtmp.so.0: cannot open shared object file: No such file or directory
[~] # /root/.serviio/opt/bin/ffmpeg -fflags +genpts -i "/share/MD0_DATA/Download/transmission/completed/Movie/Killer.Elite.2011.Blu-ray.1080p.AVC.Rus.Eng.mkv" -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a copy -map 0:0 -map 0:1 -sn -f mpegts /share/MD0_DATA/.qpkg/Serviio1/tmp/Serviio/transcoding-temp-11-4-ORIGINAL.stf
Kovally
Post Thu Oct 25, 2012 11:11 am
What else can I try to do?
Post Thu Oct 25, 2012 12:14 pm
Your FFmpeg is not compiled properly (missing rtmp library), thus transcoding will fail.
Kovally
Post Fri Oct 26, 2012 12:05 pm
Tell me, please, how I can fix it?
Post Fri Oct 26, 2012 12:18 pm
I don't know. Did you originally compile it yourself? There are some tutorials on the Serviio Wiki page.
Xmantium
Post Sat Nov 10, 2012 5:00 pm
Kovally wrote:Tell me, please, how I can fix it?
Hi Kovally, just read your same post in the QNAP NAS forums.
The ffmpeg is pre-compiled by the QPKG you installed, I'm using another ffmpeg by another Serviio forum user that I will share in Qnaps forum
