Cannot Access Server
andrew_long15
Post Sun Oct 07, 2012 2:35 am
I have a Sony Blu Ray Player BDP S590. And a Macbook pro with Snow Leopard. Yesterday I had Serviio working correctly and was able to access files on the server (Macbook) using my TV/DVD. Today, from the TV, all I am getting is a message that says: "The server is currently starting up. Please wait. Setup may take a few minutes." But after a minute or so it says "Cannot start server". The Blu Ray appears in the device list in servio and the server says that it is running.
Help!
ccarmaicl
Post Thu Oct 11, 2012 8:20 pm
Re: Cannot Access Server
i had the same problem. started. when i wached content on TV, an turned off my PC.
I reinstall application, it worked for me.
andrew_long15
Post Tue Oct 16, 2012 7:03 pm
Well, it is kind of embarrassing but I solved the problem. If my Mac is asleep then the DVD player won't connect to it. Seems obvious in retrospect. Anyway, I just have to make sure my Mac is awake before I connect and all is well.
Post Tue Oct 16, 2012 8:02 pm
I am running an old Athlon 64 as a media server 24/7 running linux. This way I do not have to worry about my laptop being asleep and can hit the media browser while traveling.
