Samsung TV C/D/E Series -Buffers when transcoding
ialomia
Post Fri Oct 12, 2012 8:02 am
With the standard configuration, buffering occurs when transcoding.
change from:
<!-- transcode H264 MP4 files with LPCM audio -->
<Matches container="mpegts" aCodec="mp2" />
<Matches container="mp4" aCodec="lpcm" />
<Matches container="matroska" vCodec="vc1" />
<Matches container="ogg" vCodec="mpeg4" />
<Matches container="3gp" aCodec="amrnb" />
Changing the configuration to the following, buffering does not occur. However play time and file size information does not appear.
Change to:
<Matches container="mp4" vCodec="mpeg4" aCodec="aac" />
<!-- transcode H264 MP4 files with AAC audio -->
<Matches container="mp4" aCodec="aac" />
What needs to be changed or added for the play time and file size information to appear.
Post Tue Oct 16, 2012 8:36 pm
Re: Samsung TV C/D/E Series -Buffers when transcoding
That makes no sense. You are transcoding all mp4 files with aac audio, which should play natively and were most likely not transcoded. You lost file size because the file is now transcoded.
ialomia
Post Tue Oct 16, 2012 9:37 pm
Okay, the original configuration with lpcm buffering occurs. When I change the configuration to aac buffering does not occur play time and file size indicates not available.
Post Tue Oct 23, 2012 4:38 pm
Can you post ffmpeg -i of the file?
ialomia
Post Sat Oct 27, 2012 1:18 am
Microsoft Windows [Version 5.2.3790]
(C) Copyright 1985-2003 Microsoft Corp.
C:\Documents and Settings\unreal.VIDEOSERVER>cd \
C:\>cd C:\Program Files\Serviio\lib
C:\Program Files\Serviio\lib>ffmpeg.exe -i D:\shares\Videos\2012
g-config
D:\shares\Videos\2012: Permission denied
C:\Program Files\Serviio\lib>ffmpeg.exe -i D:\shares\Videos\A Perfect Getaway
g-config
D:\shares\Videos\A: No such file or directory
C:\Program Files\Serviio\lib>ffmpeg.exe -i D:\shares\Videos\300
g-config
D:\shares\Videos\300: Permission denied
Post Sat Oct 27, 2012 12:21 pm
you have to provide the full file path (incl. the file name), not just the folder path after the -i parameter.
Are you on wifi or wired connection?
ialomia
Post Sun Oct 28, 2012 3:21 am
My network wired and I am using the "C:\Program Files\Serviio\lib>ffmpeg.exe -i C:\Sanctum\Sanctum" command. Can you tell the correct command line to use?
g-config
C:\Sanctum\Sanctum: No such file or directory
ialomia
Post Sun Oct 28, 2012 12:57 pm
I finally figured out the error. Below is the what you requested.
C:\Program Files\Serviio\lib>ffmpeg.exe -i "M:\Videos\Sherlock Holmes\ps3\Sherlo
ck Holmes\Sherlock Holmes.mp4"
g-config
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'M:\Videos\Sherlock Holmes\ps3\Sherlock
Holmes\Sherlock Holmes.mp4':
major_brand : mp42
minor_version : 0
compatible_brands: mp42isom
title : Sherlock Holmes
Duration: 02:08:24.87, start: 0.000000, bitrate: 7881 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x1080
, 7430 kb/s, 23.98 fps, 24 tbr, 90k tbn, 47.95 tbc
Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, 5.1, s16, 447 kb
/s
C:\Program Files\Serviio\lib>ffmpeg.exe -i "M:\Videos\The Hunger Games\ps3\The H
unger Games\The Hunger Games.mp4"
g-config
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'M:\Videos\The Hunger Games\ps3\The Hung
er Games\The Hunger Games.mp4':
major_brand : mp42
minor_version : 0
title : The Hunger Games
Duration: 02:22:33.62, start: 0.000000, bitrate: 5804 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 1920x800,
5353 kb/s, 23.98 fps, 23.92 tbr, 90k tbn, 47.95 tbc
/s
Post Wed Oct 31, 2012 2:07 pm
It looks like the TV has problems with the AAC audio in MP4 container, at least in your case. Try to upgrade firmware. Otherwise your fix will transcode audio to ac3, causing the missing information (filesize - we don't know the file size of the future transcoded file, duration - it's a problem with Samsungs, they ignore the data Serviio sends).
ialomia
Post Thu Nov 01, 2012 7:45 am
That is what I figured and Samsung has no recent firmware upgrades. Thanks for the help.
