I can see it, but can't connect?
ravx25
Post Wed Oct 17, 2012 7:50 pm
Hi, I have been using Serviio almost a month now. When it works, its great! I've had a few instances where I had to uninstall Serviio and reinstall it.
This last time though I'm at a complete loss. Everything was working just great, but today...the TV notices Serviio but won't connect to it. I've tried uninstalling/reinstalling Serviio, checked the internet connection on the TV, checked to make sure my router running Tomato has multicast and uPnP enabled, turned off the Windows Firewall and disabled MS Security Essentials. I really don't understand what in the world happened?!?! Nothing changed.
I downloaded Plex Media Server and it works just fine. With the firewall off, no router settings changed and no A/V running what in the world is the problem here? Please help, as I am really liking Serviio and would prefer to use it. Thanks in advance.
Oh and I have a LG LE5400 TV as an FYI. I should also mention that the Serviio Console can see the TV, albeit with an orange dot but it's always been that way.
ravx25
Post Thu Oct 18, 2012 1:18 am
Re: I can see it, but can't connect?
n/m, i think I figured it out. I had added an MP4 file to a TV folder I had and for some odd reason it just completely freaks Serviio out. I also couldn't just regular uninstall Serviio...I had to dig through the registry for every Serviio key to delete before a reinstall would fix it.
Users browsing this forum: Baidu [Spider] and 33 guests
