stream Desktop on TV philips
babusce
Post Thu Oct 18, 2012 6:18 pm
Hello everyone, I'm Sonia Italy.
My Sw installed: Ubuntu 12.04 - VLC 2.0.4 - Serviio 1.0.1 - Philips TV 32PFl7665 / M sw updated;
The problem: I can not do the streams desktop.
a) On my PC with VLC active I see a Switzerland channel TV full screan (La1); I use this terminal comand:
;rtmpdump -v -r "rtmp://cp108478.live.edgefcs.net/live/rsila1_1_800@45513" --swfsize "927772" --swfhash "c5508d4c14a86bfa902ec749eb544d0c260f9fed9993ed712c7d905506ef47f8" -q | vlc - --aspect-ratio=16:9
b) start Serviio; Status: 192.168.1 etc NRM-------> Philips
c) Library Online Souce I:
- Source type: Live stream
- Source URL: http://localhost:8081/desk.ts
- Display Name: Desktop
d) I press add, save, refresh
e) I go to the video folder on the TV Online Source and can not find anything.
What I wish? See Swiss channel on TV, not on PC.
Can you help? :cry:
thanks
Sonia
Post Thu Oct 18, 2012 11:42 pm
Re: stream Desktop on TV philips
What makes you think that VLC is sending a stream to 8081?
babusce
Post Fri Oct 19, 2012 7:33 am
This Serviio guide: http://wiki.serviio.org/doku.php?id=stream_pc_linux
Do you think it's not right?
I'm not sure wich port VLC use, I think 8080. Could you tell me how know it?
Txs
Sonia
Post Fri Oct 19, 2012 6:36 pm
You never issued the command to stream to 8081 per the guide.
babusce
Post Sat Oct 20, 2012 7:51 am
You should carefully read the wiki.
I know that the port 8081 is an example, but I do not know which port I use.
I use serviio very good to see the movies on television. And everything works fine.
In addition, I would just send my desktop.
I wonder how to solve the problem and you tell me nonsense.
if you do not know what to advise me, it is better not to respond and you'd better figure
If you do not know the answer, let it go,its better!
Post Sat Oct 20, 2012 3:42 pm
2 points:
- I developed the method and wrote the guide.
- I don't help people with your kind of attitute, and I doubt others will.
babusce
Post Sat Oct 20, 2012 5:18 pm
you who are not well suited to explain, or do you think you sound like a follower of a religious sect.
Serviio is a complex software and know more than others does not give right to offend. Are you a technical presumptuous.
It amazes me that you leave to assist in the forum with that kind of approach.
I just asked if someone would give me a hand, I did not learn a lesson from a stuffy like you.
there are other sw. keep to serviio
goodbey
Sonia :mrgreen:
P.S.
read here. but I doubt you to admit that we are talking about port 8081 as you are overshadowed by your arrogance.
This process allows any video playable on your desktop, preferably in fullscreen, to be streamed and displayed on your TV. The only Serviio change is to add the livestream from your PC to the Serviio console ie: http:192.168.1.10:8081 All the rest involves the setup of your PC to create the stream using VLC.
While the ability to stream your desktop to your TV can give you a remote monitor capability, the real value is to be able to display the output of any application on your TV, in particular the fullscreen output from any video playback application including flash videos.
This means that you can now browse and display all those videos on news sites, tv network shows, movie sites, social sites or music sites etc, that are not available as rss feeds, or unencripted rtmp live streams. You can now also access and display the text info that usually accompanys many of those videos, or the subtitles that overlay videos such as hulu, or the music title/artist/album information which are not available directly to Servio online streams.
To stream your desktop you need to install VLC to do the streaming (I'm using 1.1.10).
Either from the command prompt or by creating a shortcut on your desktop run the following command.
vlc screen:// :screen-fps=24.000000 :input-slave=alsa://pulse :screen-follow-mouse :screen-mouse-image="~/Pictures/mousepointerimage.png" :sout="#transcode{vcodec=mp2v,vb=10000,fps=24,width=1280,acodec=mp3,ab=192,channels=2,samplerate=44100} :http{dst=:8081/desk.ts}" :no-sout-rtp-sap :no-sout-standard-sap :ttl=1 :sout-keep
Finally, to setup Serviio to play the stream, add your PC's static address to the Serviio Console/Online Sources/Live Stream in the form http://192.168.1.2:8081/desk.ts and name it “Desktop”. (Note that zip has advised that the stream must be running, as instructed above, when the link is added to the console, else Serviio will not accept the link or display it in the Online menu.) Then on the TV click on the “Desktop” icon and the stream should play.
Trace: • add_live_feeds • start • install • stream_pc_linux
casper
Post Thu Mar 21, 2013 10:33 am
Any idea how to do the same with Serviio on a PC? Alsa I suppose would not work?
Return to Philips
Users browsing this forum: Baidu [Spider] and 0 guests
