PACKAGE: Serviio for ReadyNAS (Intel x86)
koffer
Post Thu Oct 11, 2012 10:35 am
Hi there,
I created a package with
Serviio 1.0.1 version
the package also contain JRE - Java 1.7.0_07.
No WEBUI in "stable" version.
Download here
Also you need FFMpeg package for ReadyNAS
Comments are welcome.
PS..Its my first addon for ReadyNAS. I have never used Serviio before.
UPDATE v0.3:
Sorry for v0.3 there was integration only of WEBUI. But in clean install there was no PHP module in Apache.
If you have PHP module already installed, Web UI must working correctly. Link to download
UPDATE v0.4.0:
I am testing new solution with WebUI. It working correctly on my installation and on clean (factory reset) installation.
New package/update only if needed will install - PHP5 packages and specific configuration file to current web server of ReadyNAS.
But make sure to have the EnableRootSSH add-on installed before installing new versio of add-on. If something goes wrong, i can explain how u can fix it.
New version is here. (0.4.0)
Quinny
Post Sun Oct 14, 2012 8:31 am
Re: PACKAGE: Serviio 1.0.1 for ReadyNAS (Intel x86)
Hi. Installed (I already have Ffmpeg) but does not seem to activate. Also will need some idea of how you have setup where it looks for the media files.
This thread may help http://forum.serviio.org/viewtopic.php?f=14&t=5910
Serviio fan. DLNA to Panasonic VT tvs, QNAP 651 and Synology 916 NAS boxes.
koffer
Post Sun Oct 14, 2012 2:56 pm
Thx for reply.
In this package there is no webUI for the moment. You can use Serviio Console on your Desktop.
First install Serviio Console from desktop installation package, and add line
-Dserviio.remoteHost=XXX.XXX.XXX.XXX
to C:\Program Files\Serviio\bin\ServiioConsole.exe.vmoptions
Path to shares ("Add path..." button) : /c/media/Videos for example.
I tested addon with factory reset (4.2.22) on my Ultra 4, it seems to work properly.
viperhansa
Post Sat Oct 20, 2012 5:19 pm
Is it possible to run this with PRO license key?
Will there be a webui for it?
Where is the donate button?? :P
Well, i think this is a nice package, will be looking forward to updates and improvements!
Keep up the good work!!
Post Sat Oct 20, 2012 5:27 pm
viperhansa wrote:Is it possible to run this with PRO license key?
You have the following options as the web ui's don't support uploading a license:
1) Use the official console on your pc and point it to your NAS
2) Use ServiiDroid
3) Use this method from your NAS viewtopic.php?f=17&t=5330&p=50586#p50586
koffer
Post Sun Oct 21, 2012 12:52 pm
viperhansa wrote:Will there be a webui for it?
New version with WebUI will be released soon.
Thanks to mpemberton5
viperhansa wrote:Where is the donate button??
:oops:, Thanks a lot!
Quinny
Post Sat Oct 27, 2012 6:20 am
Woot. Waits eagerly :)
yupsolo
Post Fri Nov 09, 2012 8:23 pm
thnx! I'll try the package tonight.
koffer
Post Mon Nov 19, 2012 12:45 am
Hey guys, i am sorry for the delay with this update.
I released an update with WebUI. It wasn't difficult :) problem is PHP module.
v.0.3 contain only the integration of WebUI 1.2a.
Link to a new release in my first post.
deedesie
Post Mon Nov 19, 2012 7:46 am
Hi, I just tried your new bin file. By the way, the bin file v.0.3 has the same name as your original file?
Anyway, when clicking on the "open web console" both firefox and ie want to save or open a php file. Basically it does not know what to do with the file?
Any ideas?
koffer
Post Mon Nov 19, 2012 9:19 pm
thx for reply.....,
you can download first release... here
I have the solution, but i must to test it before release, because installation of PHP can broke the webserver of ReadyNAS.
Look for updates in my first post
deedesie
Post Tue Nov 20, 2012 4:48 am
new package works 100%!!!! THANK YOU SO MUCH! :D
koffer
Post Tue Nov 20, 2012 4:56 am
deedesie wrote:new package works 100%!!!! THANK YOU SO MUCH! :D
Great !!! Thank u)
deedesie
Post Tue Nov 20, 2012 5:26 am
spoke to early. after initial install, i could see some video files and play them successfully. What i did not realize is that most of my folders and files are missing.
no matter what i add to the shared folders screen through the webui, no media files show up on my players. tested iphone, xbox and tv.
koffer
Post Tue Nov 20, 2012 5:29 am
okey...it was unknown problem with permission in ffmpeg addon. Reinstallation of ffmpeg resolved a problem.
In next release i think i'll try to recompile ffmpeg and add to package of Serviio
deedesie
Post Tue Nov 20, 2012 6:49 am
yes - with immediate help from koffer and going through the logs he found it was an ffmpeg issue. I think when i tried to upgrade to v1.3 if broke something. a uninstall/install for ffmpeg worked perfectly. thanks again to koffer and by the way, anyone with serviio and readynas - this is a perfect match! very nicely done koffer. :D
thanks for all your great help.
deedesie
Post Wed Nov 21, 2012 6:54 am
Hi Koffer, just another update, but with the Presentation tab in the webui, making changes and pressing the save button does NOT save the settings. Not sure you can replicate this behaviour?
Xmantium
Post Sat Nov 24, 2012 10:28 pm
deedesie wrote:Hi Koffer, just another update, but with the Presentation tab in the webui, making changes and pressing the save button does NOT save the settings. Not sure you can replicate this behaviour?
We had this same problem with QNAP NAS boxes too - here is a solution - viewtopic.php?f=17&t=5330&start=180#p56821
Your ReadyNAS php.ini is defaulted to "On"
yupsolo
Post Mon Nov 26, 2012 12:26 pm
Thaknx Koffer for all this time on this Serviio package!!
I installed it since ver 0.1 and can't get the transcoding to work.
I really need to know where are the log files to help me understand what's wrong.
thx!
Yupsolo
csholmq
Post Mon Nov 26, 2012 12:34 pm
yupsolo wrote:Thaknx Koffer for all this time on this Serviio package!!
thx!
Yupsolo
> find / -name serviio.log
Users browsing this forum: Bing [Bot] and 9 guests
