Mpeg-4 part14
yaro
Post Fri Oct 19, 2012 1:57 am
Mpeg-4 part14
This codec has been out for a while but serviio does not support it as a Video targetContainer (Video targetContainer=mpeg-4). Is there a reason why ?
Post Sun Oct 21, 2012 9:42 pm
Re: Mpeg-4 part14
Does FFmpeg support it? Post ffmpeg -i of the file.
yaro
Post Mon Oct 22, 2012 4:51 am
Re: Mpeg-4 part14
ffmpeg version 0.7.13, Copyright (c) 2000-2011 the FFmpeg developers
built on Oct 19 2012 22:12:43 with clang 4.1 ((tags/Apple/clang-421.11.66))
configuration: --prefix=/opt/local --enable-swscale --enable-avfilter --enable-libmp3lame --enable-libvorbis --enable-libtheora --enable-libdirac --enable-libschroedinger --enable-libopenjpeg --enable-libvpx --enable-libspeex --disable-libopencore-amrnb --disable-libopencore-amrwb --mandir=/opt/local/share/man --enable-shared --enable-pthreads --cc=/usr/bin/clang --arch=x86_64 --enable-yasm --enable-gpl --enable-postproc --enable-libx264 --enable-libxvid
libavutil 50. 43. 0 / 50. 43. 0
libavcodec 52.123. 0 / 52.123. 0
libavformat 52.111. 0 / 52.111. 0
libavdevice 52. 5. 0 / 52. 5. 0
libavfilter 1. 80. 0 / 1. 80. 0
libswscale 0. 14. 1 / 0. 14. 1
Seems stream 1 codec frame rate differs from container frame rate: 2000.00 (2000/1) -> 25.00 (25/1)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'nor.m4v':
major_brand : M4VP
minor_version : 1
compatible_brands: M4VPM4A mp42isom
creation_time : 2010-07-19 01:26:34
encoder : CoreMediaAuthoring 700, CoreMedia 484.11, i386
Duration: 00:07:08.50, start: 0.000000, bitrate: 1042 kb/s
Stream #0.0(eng): Audio: aac, 44100 Hz, stereo, s16, 131 kb/s
Stream #0.1(und): Video: h264 (Constrained Baseline), yuv420p, 480x360 [PAR 1:1 DAR 4:3], 899 kb/s, 25 fps, 25 tbr, 1k tbn, 2k tbc
Post Mon Oct 22, 2012 4:23 pm
Re: Mpeg-4 part14
Ah, I misread your question. You cannot transcode to mpeg4 container on-the-fly. Reasons have been discussed many times here.
