Samsung E Series Profiles
datajan
Post Mon Oct 22, 2012 9:04 am
Re: Samsung E Series Profiles
I wish I had read this before. I just bought a new Samsung ES series (UE50ES6710) and I also have a D-series (UE37D6510). On the D-series MKV playing works great with my Serviio server but on the ES-series it won't play the MKV files. I don't want to recode all my old MKV files so now I'm stuck with a brand new ES-series TV that won't play my series and movies. :(
- Is there a way that Serviio can compensate for the stupid Samsung programmer that ruined his earlier work (there a more programming issues on the ES-series like satellite tracking that are handled in a stupid way)?
- Is there someting else I can do to play my MKV-files on the ES series?
Thanks,
Jan
The Netherlands
Post Mon Oct 22, 2012 2:16 pm
Make sure you select the C/D/E profile
ginjaninja
Post Wed Nov 14, 2012 10:39 am
FWIW, i am running the latest samsung firmware as of last week for an ES 7000.
I dont have audio sync issues in general...i have 'test watched' c. 20 films of varying H264 profiles, reference frames and audio codecs.
I have found 1 file that had a problem so far (below).
youve got me worried that i will find more....hope not.
Unique ID                                :
Complete name                            : test.mkv
File size                                : 4.37 GiB
Duration                                 : 1h 27mn
Overall bit rate                         : 7 136 Kbps
Encoded date                             : UTC 2011-09-28 19:38:11
Writing application                      : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
Writing library                          : libebml v1.2.1 + libmatroska v1.1.1
Format settings, ReFrames                : 5 frames
Duration                                 : 1h 27mn
Bit rate                                 : 5 626 Kbps
Height                                   : 536 pixels
Display aspect ratio                     : 2.40:1
[b]Frame rate                               : 24.000 fps[/b]
Bits/(Pixel*Frame)                       : 0.342
Stream size                              : 3.36 GiB (77%)
Writing library                          : x264 core 116 r2074 2641b9e
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=5626 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Mode                                     : 16
Codec ID                                 : A_DTS
Duration                                 : 1h 27mn
Bit rate                                 : 1 509 Kbps
Bit depth                                : 24 bits
Stream size                              : 947 MiB (21%)
.rechecking it against this post, the unusal thing about this film is the frame rate its 24 rather than 23.XXX and it has chapters (although i dont think chapter are unique).
Would be good to confirm why the tv doesnt like it..
Previous
Return to Feature requests
Users browsing this forum: Baidu [Spider] and 8 guests
