[SOLVED] Futubox (and other) streams on LG
i've done 1000000 try first of all sharing desktop with vlc and tversity (or also serviio) but it sucks...the best thing i think i've done still now is that i've installed playlist.groovy and download the futubox channels playlist, i've rtmp, rtsp, http format of the channels...i've adeed to serviio like web resource with this command :
http://-SW-ufile:///c:/playlist.m3u-SW-tVIDEO
the playlist is a valid playlist with the source coded in this way : http://tv.futubox.com/ilive/z050210.str ... UTUBOXCODE
it's all ok, if i try to connect to serviio with another pc wirelesly i haven''t any kind of problem, i can see the channel and i can play it...in my lg 42lm670s i can see the folders, the channel (with a mp3 icon) i try to play it and after 10 or more seconds of waiting (with the ring) it says in italian (il file corrente non e' valido) i can traduct it as "the current file is not valid"
i've try with this method with an udp channel and it works on the other pc and also on my tv...
i've try a lot of things :
-try to change playlist with another one in xspf (try also m3u8) format
-try to use transcoding option in serviio
-try to use rtmp, rtsp and http streams in the playlist (all tested first in vlc)
-try to modify the profile.xlm with the code that a guy posted here adding transcode for flv format
-try to connect tv and router with a cable
and a lot of other things that i've forgot, all work everytime from another pc via wireless (or cable) but never on tv...
i can't figure out the problem and i hope you can help me
thanks a lot
waiting for a response
