Compatibility with XBMC NFO files generated bv MCM
kesawi
Post Tue May 01, 2012 2:12 pm
Media Center Master (MCM) is a common metatdata media library manager.
When MCM generates the XBMC NFO metadata files for individual tv episodes it inserts the following tags at the start and end of the files:
<xbmc_compatible_nfo xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
</xbmc_compatible_nfo>
The inclusion of these tags in the XMBC metadata file prevents serviio from detecting the associated media file as being a TV series as confirmed in this thread.
Manually removing the headers is a pain, particularly given the frequency with which the content of most media libraries grows.
As MCM is a widely used metadata manager, I would like to see serviio ignore these additional tags and recognise these files as a TV series automatically.
Post Tue May 01, 2012 3:43 pm
Re: Compatibility with XBMC NFO files generated bv MCM
kesawi
Post Tue May 01, 2012 8:12 pm
mrots
Post Mon Aug 20, 2012 9:50 am
I am running 1.0.1 and this doesn't seem to be fixed for me... (the ticket was resolved on 15th May 2012)
I have just come across this thread as I have been fighting the same issue for a while and couldn't find a solution - manually removing the </xbmc_compatible_nfo> parts fixes the problem as expected, but Serviio still cant read the MCM .nfo file correctly as the ticket indicates.
Is this still a problem, or am I missing something?
hansj
Post Sun Aug 26, 2012 10:40 am
same for me, the ticket seems not to be solved or at least the error is still there
Post Sun Aug 26, 2012 11:29 pm
Oh, I thought I fixed it. Can you reopen the ticket and mark it for 1.1? Also attach your nfo file there.
mrots
Post Mon Aug 27, 2012 12:30 am
I have Re-opened and attached .nfo file created by Media Center Master as requested. Sorry but I couldn't mark it for version 1.1...
Post Wed Sep 12, 2012 10:36 pm
I looked at this and it should indeed be fixed. What error exactly are you getting? Can you post the log?
Btw, the attachment to the ticket is missing title and other important fields.
hansj
Post Mon Oct 22, 2012 9:16 pm
The error is simply that the TV-Series folders are empty.
When you remove the xbmc stuff, the series will show in serviio.
The log does not show anything, when using the default logging options.
I still have to change the errorlevel and hopefully get something meaningful.
Cheers,
hansj
hansj
Post Mon Oct 22, 2012 9:34 pm
ok, it seems there is no error generated. I simulated a new episode and this is the debug log:
2012-10-22 23:31:27,919 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: I:\Serien\Once upon a time\Season 1\Once.Upon.A.Time.S01E08.mkv
2012-10-22 23:31:27,920 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i I:\Serien\Once upon a time\Season 1\Once.Upon.A.Time.S01E08.mkv
2012-10-22 23:31:28,376 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: I:\Serien\Once upon a time\Season 1\Once.Upon.A.Time.S01E08.mkv
2012-10-22 23:31:28,376 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i I:\Serien\Once upon a time\Season 1\Once.Upon.A.Time.S01E08.mkv -frames:v 1 -c:v copy -f h264 -vbsf h264_mp4toannexb -an pipe:
2012-10-22 23:31:29,093 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve thumbnail for file: I:\Serien\Once upon a time\Season 1\Once.Upon.A.Time.S01E08.mkv
2012-10-22 23:31:29,093 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -ss 120 -i I:\Serien\Once upon a time\Season 1\Once.Upon.A.Time.S01E08.mkv -an -frames:v 1 -f image2 pipe:
2012-10-22 23:31:30,079 DEBUG [ImageUtils] Starting image resize, size = 92582 bytes
2012-10-22 23:31:30,322 DEBUG [ImageUtils] Returning resized image, size = 6704 bytes
2012-10-22 23:31:30,578 INFO [LibraryAdditionsCheckerThread] Added file 'Once.Upon.A.Time.S01E08.mkv' (title: Once.Upon.A.Time.S01E08) to Library
2012-10-22 23:31:31,669 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-10-22 23:31:31,669 DEBUG [LocalContentCacheDecorator] Cleared cache (local_default)
Of course, the series is not visible using dlna...
Hope this helps,
Hansj
Post Mon Oct 22, 2012 9:43 pm
I have fixed this for 1.1
hansj
Post Wed Oct 24, 2012 6:12 am
Do you have an eta for 1.1?
Or where can I find such info?
Thanks,
hansj
Post Wed Oct 24, 2012 12:57 pm
Hoping it'll go into betatesting within a few weeks
WildRushSykes
Post Wed Oct 24, 2012 5:21 pm
hansj
Post Fri Oct 26, 2012 1:29 pm
I already requested beta-access, maybe you can put me on the list 8-)
Thanks,
hansj
WildRushSykes
Post Fri Oct 26, 2012 2:21 pm
Welcome to the team :D
Return to Feature requests
Users browsing this forum: Baidu [Spider] and 12 guests
