Streaming to DNLA rendering devices
mettle
Post Thu Oct 25, 2012 11:48 pm
I have a device (a wifi-enabled speaker) which connects using DNLA but does not have any sort of interface for selecting music.
Is there any way serviio can be used to stream music *to* a DNLA-enabled device? What I mean by that is that you would be able to select the device to stream to from the server side, rather than the client side renderer.
The device is a Sony SA-NS400, which you would normally target with something like the Bravia, but this is a more generic issue with media servers when serving to just a renderer, as opposed to some sort of device that can pull from the server, like a xbox, or TV.
teknos
Post Fri Oct 26, 2012 2:10 am
Re: Streaming to DNLA rendering devices
Post Fri Oct 26, 2012 9:51 am
Windows 7 (Windows 8 too) has it's own DMC and it's the "Play To" function of Windows Mediaplayer 12.
The “Play To” feature from Windows Media Player (and the Windows Explorer in Windows 8) launches a DMC to control the media playback experience. [Never tested with Serviio]
This is a Digital Media Controller (DMC), these devices find content on digital media servers (DMS) and play it on digital media renderers (DMR).
Also look at this :
http://jorgenmodin.net/index_html/archi ... re-devices
or
http://oss.linn.co.uk/trac/wiki/KinskyDesktop [Not Tested on Serviio]
mettle
Post Fri Oct 26, 2012 10:48 pm
Thanks for the recommendations.
I'm actually Mac based, though a few of the suggestions are relevant, too.
In fact, I took a look at kinsky and it works okay. The biggest bug seems to be that it oftentimes doesn't advance to the next track in a queue. I'm trying to debug that now... It's also pretty sparse in terms of features, which in some cases is a good thing.
Another piece of software I discovered is SongBook, by Bookshelf Apps. It's amazingly comprehensive in it's capabilities. Thing is, it's $40 once the trial runs out.
Hopefully I can get kinsky to work, or maybe I'll find one of the others you suggested to be useful.
Users browsing this forum: Google [Bot] and 30 guests
