[SOLVED] No longer locating "movies"
chengka
Post Sat Oct 27, 2012 9:16 pm
Thank you for an outstading product. I have recently run into an issue and I haven't found a thread for a similar issue.
I use Serviio to serve my archived dvd's. My movies are all located in a single directory e:\video\movies. I have always used XBMC to create a library and then I export seperate NFO files for each dvd, into the directory named above. This always worked, but recently Serviio stopped listing my films under Movies and effectively is just listing them as files , under sectiion such as Titles, or Last Added. Based on what I see in the log, Serviio is looking for a single file from XBMC called movie.nfo. Did I unwittingly change something? What did I do?
My files have spaces in the name, but I've always dont that.
E:\Video\Movies>dir the*
Volume in drive E is Files
Volume Serial Number is DA5C-C2FD
Directory of E:\Video\Movies
09/25/2012 08:59 PM 657,393 The Avengers-fanart.jpg
08/21/2012 07:33 AM 6,775,019,998 The Avengers.mkv
09/25/2012 08:59 PM 21,391 The Avengers.nfo
09/25/2012 08:59 PM 102,014 The Avengers.tbn
Serviio v1.0.1 pro
2012-10-26 18:33:25,426 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2012-10-26 18:33:25,426 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2012-10-26 18:33:27,995 ERROR [XBMCExtractor] File 'E:\Video\Movies\movie.nfo' couldn't be parsed:null
2012-10-26 18:33:28,002 ERROR [XBMCExtractor] File 'E:\Video\Movies\movie.nfo' couldn't be parsed:null
2012-10-26 18:33:28,009 ERROR [XBMCExtractor] File 'E:\Video\Movies\movie.nfo' couldn't be parsed:null
2012-10-26 18:33:28,016 ERROR [XBMCExtractor] File 'E:\Video\Movies\movie.nfo' couldn't be parsed:null
2012-10-26 18:33:28,022 ERROR [XBMCExtractor] File 'E:\Video\Movies\movie.nfo' couldn't be parsed:null
2012-10-26 18:33:28,029 ERROR [XBMCExtractor] File 'E:\Video\Movies\movie.nfo' couldn't be parsed:null
2012-10-26 18:33:28,036 ERROR [XBMCExtractor] File 'E:\Video\Movies\movie.nfo' couldn't be parsed:null
2012-10-26 18:33:28,042 ERROR [XBMCExtractor] File 'E:\Video\Movies\movie.nfo' couldn't be parsed:null
2012-10-26 18:33:28,049 ERROR [XBMCExtractor] File 'E:\Video\Movies\movie.nfo' couldn't be parsed:null
2012-10-26 18:33:28,055 ERROR [XBMCExtractor] File 'E:\Video\Movies\movie.nfo' couldn't be parsed:null
2012-10-26 18:33:28,062 ERROR [XBMCExtractor] File 'E:\Video\Movies\movie.nfo' couldn't be parsed:null
2012-10-26 18:33:28,069 ERROR [XBMCExtractor] File 'E:\Video\Movies\movie.nfo' couldn't be parsed:null
2012-10-26 18:33:28,076 ERROR [XBMCExtractor] File 'E:\Video\Movies\movie.nfo' couldn't be parsed:null
2012-10-26 18:33:28,082 ERROR [XBMCExtractor] File 'E:\Video\Movies\movie.nfo' couldn't be parsed:null
2012-10-26 18:33:28,089 ERROR [XBMCExtractor] File 'E:\Video\Movies\movie.nfo' couldn't be parsed:null
2012-10-26 18:33:28,096 ERROR [XBMCExtractor] File 'E:\Video\Movies\movie.nfo' couldn't be parsed:null
Post Sat Oct 27, 2012 10:49 pm
Re: No longer locating "movies"
are you sure there is no (hidden?) movie.nfo file there? Serviio will look for movie.nfo first and if not found it'll try the other file names.
chengka
Post Sat Oct 27, 2012 11:48 pm
That was it.. Thank you!
Users browsing this forum: No registered users and 55 guests
