[SOLVED] VPN & Serviio
castalla
Post Sat Oct 27, 2012 10:31 pm
If I run a vpn service on the serviio PC server then there are no valid files when I connect via Samasung Allshare.
If the VPN is disabled, then files appear in folders and are playable.
Is there a setting or a fix for this behaviour?
Post Sat Oct 27, 2012 10:54 pm
Re: VPN & Serviio
Does it bind to a wrong IP address in that case? E.g. the IP of the virtual network adapter.
castalla
Post Sat Oct 27, 2012 10:57 pm
Re: VPN & Serviio
Where would I find this info?
Post Sat Oct 27, 2012 11:22 pm
Re: VPN & Serviio
check the log to which IP address Serviio binds
castalla
Post Sun Oct 28, 2012 11:23 am
Re: VPN & Serviio
Okay .... fixed, by forcing a binding to the serviio PC. Thanks for the hints.
