Web UI in Ajax (Mobile & desktop edition)
kairoh
Post Tue Oct 23, 2012 7:57 pm
Re: Web UI in Ajax (Mobile & desktop edition)
@swehawk : I can't reproduce your problem... I've successfully reinstalled the service on many windows (2k, xp, seven)
@moltra : I'm already using the client id "WEBUI", you may have noticed it in your log.
What I don't understand is how you prevent user from voting 50 times for the same media!
@npuser and @qoolbox : This error seems to be a licence issue, I will try to remove mine to reproduce this ;)
Serviio WebUI console developer : New Homepage | Support | Project | Issues
Samsung UA32C6600 | WinXP / Ubuntu 11.10 | Samsung Galaxy S | Freebox v6
Post Tue Oct 23, 2012 8:24 pm
kairoh wrote:@moltra : I'm already using the client id "WEBUI", you may have noticed it in your log.
To vote the user has to log into my site and the vote is keyed to the user. The user can change his vote, but not vote multiple times.
jshg46
Post Sun Oct 28, 2012 12:27 am
Is it any way to password protect the panel?
jshg46
Post Sun Oct 28, 2012 4:50 am
I am having a problem. If I add an rss feed I get an error.
Error: Unable to get value of the property '1': object is null or undefined.
Serviio 1.0.1
anerDev
Post Sun Oct 28, 2012 9:03 am
Hi folks !
When I go to "Library" and add a folder it say:
Error: 'undefined' is not an object (evaluating 'data.accessGroupIds[1]').
Why ?
The folder is /media/hd-dati/download ... "hd-dati" is an external hd and this is the permission
drwxrwxrwx 5 server debian-transmission 4096 ott 24 14:57 download
what's the problem '??
Post Sun Oct 28, 2012 9:10 am
anerDev wrote:Hi folks !
Why ?
Its a problem with the WebUI. The Pro version of Serviio has access groups for blocking content, the WebUI is expecting that data to always be available but it isn't in the free version. @kairoh is working on a fix for it.
anerDev
Post Sun Oct 28, 2012 9:15 am
Thank u for the reply !
But, How I add the download folder to the serviio folder ?
There is a manual mode ?
Thank u
Post Sun Oct 28, 2012 10:03 am
You will have to use the official console see the FAQ for how to set it up, ServiiDroid, or the PHP webui for now.
anerDev
Post Sun Oct 28, 2012 10:15 am
I have put serviioweb in my apache folder, but when I load the page, the page is all white !
And I have put on terminal this command:
sudo sh /usr/local/bin/serviio/bin/serviio-console.sh
and the results is:
server@server:~$ sudo sh /usr/local/bin/serviio/bin/serviio-console.sh
[sudo] password for server:
server@server:~$
Post Sun Oct 28, 2012 10:41 am
Is this a NAS/headless server? If it is, you either have to run a remote X server on you PC if you want ./serviio-console.sh to work, or follow http://www.serviio.org/component/conten ... e?id=21#q2 to install the console on your PC and point it to your server. If your server isn't headless, then you should be able to run ./serviio-console.sh & and it should work, if it doesn't please post the log (in serviio/log).
anerDev
Post Sun Oct 28, 2012 3:31 pm
Nope, I use ubuntu server !
Post Sun Oct 28, 2012 3:32 pm
No its not headless? In which case, post the log as you should be able to just run the console if you are logged into it with a GUI.
anerDev
Post Sun Oct 28, 2012 3:38 pm
(227.23 KiB) Downloaded 1036 times
Post Sun Oct 28, 2012 3:48 pm
No X11 DISPLAY variable was set, but this program performed an operation which requires it.
java.awt.HeadlessException:
   at java.awt.GraphicsEnvironment.checkHeadless(GraphicsEnvironment.java:173)
   at java.awt.Window.<init>(Window.java:477)
   at java.awt.Frame.<init>(Frame.java:419)
   at java.awt.Frame.<init>(Frame.java:384)
   at javax.swing.JFrame.<init>(JFrame.java:174)
   at org.serviio.ui.view.swing.JFrameView.<init>(JFrameView.java:28)
   at org.serviio.ui.view.swing.ServiioFrameView.<init>(ServiioFrameView.java:57)
   at org.serviio.console.ServiioConsole.main(ServiioConsole.java:105)
2012-10-28 16:30:44,773 INFO  [ServiioConsole] Leaving Serviio Console
It doesn't have anything to display the console on.
You said it isn't headless, but how are you connecting to this machine? If locally, are loggin in via a terminal with no X session, then that counts as headless. If your loggin into gnome or kde etc and then opening a terminal, then something is wrong. If remotely, what OS is the machine your using running.
anerDev
Post Sun Oct 28, 2012 4:02 pm
I use Ubuntu Server without desktop Enviroment, only command line !
From my mac, I use ssh for send the command to the server
Post Sun Oct 28, 2012 4:10 pm
anerDev wrote:I use Ubuntu Server without desktop Enviroment, only command line !
No deasktop environment == headless.
On your mac, try
ssh -X user@server
That should tell the server to forward the display to your mac.
anerDev
Post Sun Oct 28, 2012 4:17 pm
Don't work !!!
Andreas-iMac:~ andrea$ ssh -X server@192.168.1.9
server@192.168.1.9's password:
Welcome to Ubuntu 12.04.1 LTS (GNU/Linux 3.2.0-32-generic-pae i686)
* Documentation: https://help.ubuntu.com/
System information as of Sun Oct 28 17:16:33 CET 2012
System load: 0.0 Processes: 98
Usage of /: 3.7% of 55.00GB Users logged in: 0
Memory usage: 18% IP address for eth0: 192.168.1.9
Swap usage: 0%
Graph this data and manage this system at https://landscape.canonical.com/
0 packages can be updated.
0 updates are security updates.
Last login: Sun Oct 28 16:36:57 2012 from 192.168.1.10
server@server:~$
Question, but there is a file where I put the folder url who I would like to share ?
Post Sun Oct 28, 2012 4:23 pm
anerDev wrote:Don't work !!!
Swap usage: 0%
server@server:~$
After logging in, you still have to run the console.
cd /user/local/bin/serviio/bin
anerDev
Post Sun Oct 28, 2012 4:34 pm
Don't work, again !
System information as of Sun Oct 28 17:33:20 CET 2012
System load: 0.2 Processes: 96
Swap usage: 0%
Last login: Sun Oct 28 17:31:40 2012 from 192.168.1.10
server@server:~$ cd /usr/local/bin/serviio/bin
server@server:/usr/local/bin/serviio/bin$ sudo ./serviio-console.sh
Post Sun Oct 28, 2012 4:35 pm
Can you post the log then.
Is there a reason you don't want to simply install the console on your mac and point it to your server? E.g. do this:
Download and install Serviio on your mac, only select to install the console.
Dissable gatekeeper if you have the lastest version (see http://support.apple.com/kb/HT5290)
Browse the contents of Serviio-Console.app and open file Contents/Info.plist in TextEdit.
Scroll down to the bottom where it has
      <key>Properties</key>
      <dict>
        <key>serviio.home</key>
        <string>$JAVAROOT</string>
        <key>java.net.preferIPv4Stack</key>
        <string>true</string>
      </dict>
and change it to
      <dict>
        <key>serviio.remoteHost</key>
        <string>192.168.1.9</string>
      </dict>
Start Serviio-Console.app
Re-enable gatekeeper.
Users browsing this forum: No registered users and 100 guests
