Serviio works on some videos but not others.
justpie
Post Sat Oct 27, 2012 3:40 am
Hey all.
I ran into a rather strange situation. I have been running serviio off of my macbook for some time and it has worked flawlessly for me. However, i have decided to build a media pc, something i can keep on 24x7 and its having issues with some of the files.
Running Serviio 1.0.1 on xbuntu off of a samsung un46D6050 using allshare. I am watching the same movies/videos that i was watching before ( like i said no issues running it off the mac ) but for some reason i can't fastforward some of them, and also the ones that i can't fastforward seem to crash within a few mins and just jump to the next video in the folder. ex: I can watch 4 episodes of big bang season 2, but once i get to the 5th i can't fastforward and it stops playing and jumps to eps 6. I tested it on my mac and it had no issues playing eps 5.
Any Ideas?
Post Sat Oct 27, 2012 12:05 pm
Re: Serviio works on some videos but not others.
what is your ffmpeg version? and can you post ffmpeg -i for some of the files?
justpie
Post Sat Oct 27, 2012 2:07 pm
ffmpeg version 0.8.3-4:0.8.3-0ubuntu0.12.04.1
From a working file :
ffmpeg -i The\ Big\ Bang\ Theory\ -\ 02x04\ -\ The\ Griffin\ Equivalency.avi
ffmpeg version 0.8.3-4:0.8.3-0ubuntu0.12.04.1, Copyright (c) 2000-2012 the Libav developers
  built on Jun 12 2012 16:37:58 with gcc 4.6.3
[mpeg4 @ 0x875b160] Invalid and inefficient vfw-avi packed B frames detected
Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/2733) -> 23.98 (24000/1001)
Input #0, avi, from 'The Big Bang Theory - 02x04 - The Griffin Equivalency.avi':
    encoder         : VirtualDubMod 1.5.10.2 (build 2540/release)
  Duration: 00:21:21.98, start: 0.000000, bitrate: 1142 kb/s
    Stream #0.0: Video: mpeg4 (Advanced Simple Profile), yuv420p, 640x352 [PAR 1:1 DAR 20:11], 23.98 tbr, 23.98 tbn, 23.98 tbc
    Stream #0.1: Audio: mp3, 48000 Hz, stereo, s16, 133 kb/s
From the file that skips.
ffmpeg -i The\ Big\ Bang\ Theory\ -\ 02x05\ -\ The\ Euclid\ Alternative.avi
[mpeg4 @ 0x9d01160] Invalid and inefficient vfw-avi packed B frames detected
Input #0, avi, from 'The Big Bang Theory - 02x05 - The Euclid Alternative.avi':
  Duration: 00:20:00.00, start: 0.000000, bitrate: 1221 kb/s
    Stream #0.1: Audio: mp3, 48000 Hz, stereo, s16, 132 kb/s
Thanks again for the help!
justpie
Post Sat Oct 27, 2012 3:15 pm
Since my last post i found all the source files listed here : http://www.serviio.org/download and got them all compiled and installed.
ffmpg version :
ffmpeg
  built on Oct 27 2012 10:51:32 with gcc 4.6.3
  configuration:
ffmpeg - i : From a working video;
  configuration:
[mpeg4 @ 0x98166c0] Invalid and inefficient vfw-avi packed B frames detected
    Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 640x352 [SAR 1:1 DAR 20:11], 23.98 tbr, 23.98 tbn, 23.98 tbc
    Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16, 32 kb/s
ffmpeg -i from a video thats not working.
  configuration:
[mpeg4 @ 0x94366c0] Invalid and inefficient vfw-avi packed B frames detected
-- Retested the video and ran into the same issue. Every file that fails skips at the exact same spot as before.
Post Sat Oct 27, 2012 10:47 pm
Samsung profile doesn't transcode these files so it's not related to FFMpeg but the files themselves. You could also try to install newer (of different) version of Java, because it seems the only difference between your systems at this point.
justpie
Post Sun Oct 28, 2012 3:57 pm
I tried the latest version of java. However, I reverted back to serviio 0.6.2 and it works like a charm.
-pie.
otaraia
Post Tue Nov 13, 2012 12:26 am
I have a similar issue. when you load a video on my Samsung BDP it shows the length to be less than what is shown on a PC.
Copying the file into the same directory fixes the problem. i.e file.mp4 -> file-copy.mp4
I'm running Serviio 1.0.1 on a Windows 7 platform. TV and BDP are both Samsung using the default Samsung C/D/E profile
if I run ffmpeg on the file it reports :-
Y:\ezRSS - Search Results\incoming>ffmpeg -i "Chicago.Fire.S01E05.HDTV.x264-LOL.[VTV].mp4"
ffmpeg version N-44264-g070b0e1 Copyright (c) 2000-2012 the FFmpeg developers
built on Sep 7 2012 17:38:57 with gcc 4.7.1 (GCC)
configuration: --enable-gpl --enable-version3 --disable-pthreads --enable-runtime-cpudetect --enab
le-avisynth --enable-bzlib --enable-frei0r --enable-libass --enable-libcelt --enable-libopencore-amr
nb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libn
ut --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheo
ra --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-lib
vpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 51. 72.100 / 51. 72.100
libavcodec 54. 55.100 / 54. 55.100
libavformat 54. 25.105 / 54. 25.105
libavdevice 54. 2.100 / 54. 2.100
libavfilter 3. 16.100 / 3. 16.100
libswscale 2. 1.101 / 2. 1.101
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Chicago.Fire.S01E05.HDTV.x264-LOL.[VTV].mp4':
major_brand : isom
minor_version : 1
compatible_brands: isom
creation_time : 2012-11-07 03:24:41
Duration: 00:42:06.85, start: 0.000000, bitrate: 1100 kb/s
Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 720x404, 975 kb/s, 23.98 fps,
23.98 tbr, 24k tbn, 47.95 tbc
creation_time : 2012-11-08 01:53:38
handler_name : GPAC ISO Video Handler
Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, s16, 121 kb/s
creation_time : 2012-11-07 03:24:44
handler_name : GPAC ISO Audio Handler
and one that works....
Y:\ezRSS - Search Results\incoming>ffmpeg -i "Chicago.Fire.S01E05.HDTV.x264-LOL.[VTV] - copy.mp4"
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Chicago.Fire.S01E05.HDTV.x264-LOL.[VTV] - copy.mp4':
major_brand : isom
minor_version : 1
The other frustrating thing is no FFWD - just skip function.
Users browsing this forum: No registered users and 62 guests
