He-acc to acc
jibtga
Post Thu Oct 11, 2012 12:55 pm
He-acc to acc
It's possible transcode from audio code: he-acc to simple acc? how could it be done?
thanks in advance
Post Thu Oct 11, 2012 1:36 pm
Re: He-acc to acc
currently there s no distinction between these two, so you cannot do that. You could transcode all aac to, for example, ac3
AndyMc
Post Sat Oct 27, 2012 5:00 pm
Re: He-acc to acc
Hiya, how to I transcode all ACC to AC3?
EDIT:
I've tried many things, understand ok the script but doesn't seem to change anything, as if it's not using the profiles.xml I'm editing.
I'm editing the profiles.xml in the config dir.
Post Sat Oct 27, 2012 10:23 pm
Re: He-acc to acc
did you restart the service/PC after you make changes to profiles.xml?
AndyMc
Post Mon Oct 29, 2012 1:09 am
Re: He-acc to acc
Yes, have you the code to make all h264 acc to play as ac3?
I see also level 4.2 and higher should transcode but this doesn't work for me and I have to use h264 level editor to change from 4.2+ to 4.1.
I have a C series Samsung TV, so I made changes in that profile. Should I omit other lines of code that are already there as default?
I didn't restart PC, it's a slow boot due to many things loading, but I stopped the Services and made sure none were still running in Task Manager.
I had installed Serviio to 2 locations, one was just old dir I think. I will look in registry for serviio see if its showing which folder used.
Users browsing this forum: Baidu [Spider] and 21 guests
