4OD no sound
JB101
Post Tue Oct 30, 2012 11:19 am
4OD no sound
Hi all,
Apologies if this is a stupid question as I'm a complete novice when it comes to media tech etc,
give me a datawarehouse to play with any day.
I've managed to add a couple of 4OD series to my library, the video plays fine on my Sony Bravia - model: KDL-24X320
however I can't figure out how to get the sound working?
I'm currently using the Sony Bravia 2009 profile as that seems to work best with other files I play.
Any advice much appreciated.
If logs / config files will help let know which ones and I'll figure out where they are and post them.
Thanks,
JB
Post Tue Oct 30, 2012 11:35 am
Re: 4OD no sound
-- moderated : move to sony section --
What are 4OD series, local media or an online streams ?
Please read this topic : viewtopic.php?f=11&t=7821
JB101
Post Tue Oct 30, 2012 11:56 am
Re: 4OD no sound
Hi thanks for the really quick reply,
Currently I'm trying to view online streams, so for example Brasseye using the URL: www.channel4.com/programmes/brass-eye/4od
Video plays fine, but no sound.
I think I have the most recent plugin, but again - am a complete novice so may just doing something really blatently wrong?
J
Post Tue Oct 30, 2012 12:18 pm
Re: 4OD no sound
OK,
Could you copy/backup the ./serviio/config/profiles.xml file and replace by this one, then restart serviio services or reboot the pc (select profile Sony Bravia 2011 on serviio console) ?
download/file.php?id=2663
JB101
Post Tue Oct 30, 2012 1:41 pm
Re: 4OD no sound
Awesome - that does the trick - 4OD now working,
Oddly many of my local avi files no longer play now, But I can live with switching xml files and profiles - so thats all cool
Cheers
Post Tue Oct 30, 2012 5:07 pm
Re: 4OD no sound
What is your region US, UK ?
Could you select "Sony Bravia TV (2011) - US"
Users browsing this forum: Google [Bot] and 2 guests
