Subtitles, why it works on PS3MediaServer & not on Serviio??
Post Tue Oct 30, 2012 5:16 pm
Re: Subtitles, why it works on PS3MediaServer & not on Servi
lelin wrote:Is MPEG2
So PMS transcode with subtitles burned, that should be DIVX in rectangle, I think...
lelin
Post Tue Oct 30, 2012 5:42 pm
is MPEG2, no DIVX
see large pic
Post Tue Oct 30, 2012 7:10 pm
Illico wrote:So PMS transcode with subtitles burned, that should be DIVX in rectangle, I think...
You have misunderstood me...
I mean:
If you see a MPEG2 rectangle, that means that the stream is transcoded to mpeg2 (probably with subtitle burned into video stream by mencoder).
If stream was delivered in native format with srt external, you should see DIVX.
Regards
lelin
Post Wed Oct 31, 2012 12:39 am
OK, now what is the solution to have the subtitles in Serviio ?
Post Wed Oct 31, 2012 8:42 am
lelin wrote:OK, now what is the solution to have the subtitles in Serviio ?
From my point of view:
- Wait for ffmpeg dev to implement subtitle burning, then serviio will implement it.
or
- Manually transcode your file to burn sub with another tool.
mxii
Post Mon Nov 19, 2012 3:54 am
or
Option 3 for SRTs: http://forum.serviio.org/viewtopic.php?f=5&t=4650&p=56555#p56555
Previous
