WDTV problems
tuath
Post Sun Oct 21, 2012 11:01 pm
WDTV problems
Hello community!
I have just upgraded my home server to Windows Server 2012 Essentaials, and at the same time upgraded to ServeIIO 1.0.1..
Ever since that change, videos on my WD TV LIVE stop after 1-2 minutes. There are no problem streaming to the xbox or to a windows laptop.
Is there any way to diagnose the problem ? I have had it since I upgraded to 1.0.1. from 0.62, and only with my WD TV Live.
Regards, Erik.
tuath
Post Mon Oct 22, 2012 3:22 am
Re: WDTV problems
After activating "debug" logging levels, this is the error i get when the video stops playing on the wd tv live.
2012-10-21 23:13:59,744 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
Any ideas ?
amagdic
Post Wed Oct 24, 2012 11:11 pm
Re: WDTV problems
I am running Serviio v1.01 on windows server 2008 R2 as a VM on server 2012. I am using a WD TV Live HD Media Player, firmware 1.0.6.34_V. Regardless of which movie I play ie MKV, AVI etc they play for about 2 minutes then I get "There was a problem connecting to the network. The device could not connect to the network." Any help much appreciated
tuath
Post Thu Oct 25, 2012 3:48 am
Re: WDTV problems
I have done a little diagnostics and the problem does not occur with other DLNA servers, only with ServeIIO. I have also update Java to Update 9 and the problem still remains.
Any ideas ? version 0.62 worked flawlessly...
Erik.
Post Thu Oct 25, 2012 12:01 pm
Re: WDTV problems
Does it happen on the exact same time for each movie (e.g. 2 minutes no matter what you play)? Is it in a region of around 2 minutes or exactly (for example) on 2:05? When you replay the same movie, does it happen on the same point? Does this happen to all video files? Does it happen to audio files?
tuath
Post Tue Oct 30, 2012 8:28 pm
Re: WDTV problems
I did some more investigations,
it happens always between 2 and 8 minutes, at different places within the same file and all files I have tried.
When I go back to the list of upnp servers. ServeIIO isn't in the list and reappears a few seconds after.
Thanks !
Erik.
Post Wed Oct 31, 2012 1:53 pm
Re: WDTV problems
It looks like the Serviio notifications (to the devices) are not delivered. They are multicast so delivery is not guaranteed. Might be down to the quality of your network / router.
Willems
Post Sun Nov 04, 2012 7:13 pm
Re: WDTV problems
I have the same problem over here, until yesterday I have been using WHS2011, there it worked flawlessly, however after the upgrade I keep getting the same problems as the other messages in this thread. Somehow the connection does get interrupted.
Willems
Post Mon Nov 05, 2012 5:07 am
Re: WDTV problems
Tested last evening on the same server 2012, and installed Twonky 7, streaming did not get interrupted then.
Post Tue Nov 06, 2012 1:18 pm
Re: WDTV problems
Try different Java version.
Willems
Post Sat Nov 10, 2012 5:22 pm
Re: WDTV problems
Thank you for your response. I had Java 7 64 bits installed automatically and went back to the latest version of Java 6 64 bita, unfortunately no change at all.
crispin85
Post Sat Nov 10, 2012 9:11 pm
Re: WDTV problems
I am having exactly the same problem with serviio on server2012 x64 to a wdtv live. Disappears randomly before reappearing in the list of mediaservers.
Any ideas what can be causing this? Updated/rolled back java etc. no change. This must be an issue with serviio.
Cheers
Post Sun Nov 11, 2012 11:28 pm
Re: WDTV problems
tuath
Post Mon Nov 19, 2012 2:49 am
Re: WDTV problems
Here is a log file, i tried watching "iron man 2" on the wd live.
After about 2 minutes, the video stopped.
2012-11-18 21:40:39,648 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 1015635970-1533674769/1533674770,Content-Length: 518038800,Date: Mon, 19 Nov 2012 02:40:39 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:39,738 DEBUG [WebServer] Incoming connection from /192.168.2.40:39601
2012-11-18 21:40:39,739 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:39,739 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=1050214144-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:39,740 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:39,740 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:39,741 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:39,741 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:39,742 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:39,742 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:39,749 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:39,763 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:39,763 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 483460626
2012-11-18 21:40:39,763 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:39,764 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 1050214144-1533674769/1533674770,Content-Length: 483460626,Date: Mon, 19 Nov 2012 02:40:39 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:39,825 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:39,830 DEBUG [WebServer] Incoming connection from /192.168.2.40:39602
2012-11-18 21:40:39,830 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:39,831 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=1150788716-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:39,831 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:39,832 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:39,832 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:39,833 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:39,834 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:39,834 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:39,855 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:39,855 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 382886054
2012-11-18 21:40:39,855 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:39,856 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 1150788716-1533674769/1533674770,Content-Length: 382886054,Date: Mon, 19 Nov 2012 02:40:39 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:39,906 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:39,909 DEBUG [WebServer] Incoming connection from /192.168.2.40:39603
2012-11-18 21:40:39,909 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:39,910 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=1271383320-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:39,911 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:39,911 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:39,912 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:39,912 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:39,913 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:39,913 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:39,938 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:39,938 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 262291450
2012-11-18 21:40:39,939 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:39,939 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 1271383320-1533674769/1533674770,Content-Length: 262291450,Date: Mon, 19 Nov 2012 02:40:39 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:40,018 DEBUG [WebServer] Incoming connection from /192.168.2.40:39604
2012-11-18 21:40:40,018 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,019 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=1393301862-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:40,019 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,020 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,020 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:40,020 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:40,022 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,022 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:40,028 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:40,046 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:40,046 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 140372908
2012-11-18 21:40:40,047 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:40,047 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 1393301862-1533674769/1533674770,Content-Length: 140372908,Date: Mon, 19 Nov 2012 02:40:40 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:40,186 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:40,188 DEBUG [WebServer] Incoming connection from /192.168.2.40:39605
2012-11-18 21:40:40,198 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,199 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=1494253826-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:40,200 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,200 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,200 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:40,201 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:40,202 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,202 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:40,229 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:40,230 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 39420944
2012-11-18 21:40:40,230 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:40,230 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 1494253826-1533674769/1533674770,Content-Length: 39420944,Date: Mon, 19 Nov 2012 02:40:40 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:40,268 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:40,271 DEBUG [WebServer] Incoming connection from /192.168.2.40:39606
2012-11-18 21:40:40,272 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,273 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=1533647946-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:40,273 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,274 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,274 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:40,274 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:40,275 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,276 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:40,296 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:40,296 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 26824
2012-11-18 21:40:40,296 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:40,297 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 1533647946-1533674769/1533674770,Content-Length: 26824,Date: Mon, 19 Nov 2012 02:40:40 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:40,314 DEBUG [WebServer] I/O error: Connection reset
2012-11-18 21:40:40,316 DEBUG [WebServer] Incoming connection from /192.168.2.40:39607
2012-11-18 21:40:40,317 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,318 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=1142032-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:40,318 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,319 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,319 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:40,319 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:40,320 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,321 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:40,455 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:40,455 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 1532532738
2012-11-18 21:40:40,455 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:40,455 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 1142032-1533674769/1533674770,Content-Length: 1532532738,Date: Mon, 19 Nov 2012 02:40:40 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:40,463 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:40,466 DEBUG [WebServer] Incoming connection from /192.168.2.40:39608
2012-11-18 21:40:40,467 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,468 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=90037460-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:40,468 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,469 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,469 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:40,469 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:40,470 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,471 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:40,505 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:40,505 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 1443637310
2012-11-18 21:40:40,505 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:40,505 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 90037460-1533674769/1533674770,Content-Length: 1443637310,Date: Mon, 19 Nov 2012 02:40:40 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:40,513 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:40,517 DEBUG [WebServer] Incoming connection from /192.168.2.40:39609
2012-11-18 21:40:40,518 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,518 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=175851400-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:40,519 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,519 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,520 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:40,520 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:40,521 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,521 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:40,546 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:40,546 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 1357823370
2012-11-18 21:40:40,547 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:40,547 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 175851400-1533674769/1533674770,Content-Length: 1357823370,Date: Mon, 19 Nov 2012 02:40:40 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:40,554 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:40,558 DEBUG [WebServer] Incoming connection from /192.168.2.40:39610
2012-11-18 21:40:40,559 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,560 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=298746016-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:40,560 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,561 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,561 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:40,561 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:40,562 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,563 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:40,596 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:40,596 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 1234928754
2012-11-18 21:40:40,597 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:40,597 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 298746016-1533674769/1533674770,Content-Length: 1234928754,Date: Mon, 19 Nov 2012 02:40:40 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:40,616 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:40,618 DEBUG [WebServer] Incoming connection from /192.168.2.40:39611
2012-11-18 21:40:40,633 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,634 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=460935836-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:40,634 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,635 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,635 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:40,635 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:40,636 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,636 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:40,663 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:40,663 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 1072738934
2012-11-18 21:40:40,664 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:40,664 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 460935836-1533674769/1533674770,Content-Length: 1072738934,Date: Mon, 19 Nov 2012 02:40:40 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:40,673 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:40,678 DEBUG [WebServer] Incoming connection from /192.168.2.40:39612
2012-11-18 21:40:40,678 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,679 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=545492110-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:40,679 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,680 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,680 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:40,681 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:40,682 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,682 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:40,713 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:40,713 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 988182660
2012-11-18 21:40:40,713 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:40,714 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 545492110-1533674769/1533674770,Content-Length: 988182660,Date: Mon, 19 Nov 2012 02:40:40 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:40,721 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:40,725 DEBUG [WebServer] Incoming connection from /192.168.2.40:39613
2012-11-18 21:40:40,726 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,727 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=624040566-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:40,727 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,728 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,728 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:40,728 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:40,729 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,729 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:40,754 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:40,755 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 909634204
2012-11-18 21:40:40,755 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:40,755 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 624040566-1533674769/1533674770,Content-Length: 909634204,Date: Mon, 19 Nov 2012 02:40:40 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:40,763 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:40,767 DEBUG [WebServer] Incoming connection from /192.168.2.40:39614
2012-11-18 21:40:40,768 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,769 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=747368294-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:40,769 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,770 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,770 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:40,770 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:40,771 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,772 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:40,821 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:40,821 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 786306476
2012-11-18 21:40:40,821 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:40,822 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 747368294-1533674769/1533674770,Content-Length: 786306476,Date: Mon, 19 Nov 2012 02:40:40 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:40,829 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:40,832 DEBUG [WebServer] Incoming connection from /192.168.2.40:39615
2012-11-18 21:40:40,833 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,834 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=814971712-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:40,834 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,835 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,835 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:40,835 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:40,836 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,837 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:40,863 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:40,863 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 718703058
2012-11-18 21:40:40,863 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:40,863 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 814971712-1533674769/1533674770,Content-Length: 718703058,Date: Mon, 19 Nov 2012 02:40:40 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:40,871 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:40,875 DEBUG [WebServer] Incoming connection from /192.168.2.40:39616
2012-11-18 21:40:40,876 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,876 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=903774906-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:40,877 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,877 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,878 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:40,878 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:40,879 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,879 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:40,904 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:40,904 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 629899864
2012-11-18 21:40:40,905 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:40,905 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 903774906-1533674769/1533674770,Content-Length: 629899864,Date: Mon, 19 Nov 2012 02:40:40 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:40,912 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:40,917 DEBUG [WebServer] Incoming connection from /192.168.2.40:39617
2012-11-18 21:40:40,917 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,918 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=1015755914-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:40,918 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,919 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,919 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:40,919 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:40,920 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,921 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:40,946 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:40,946 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 517918856
2012-11-18 21:40:40,947 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:40,947 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 1015755914-1533674769/1533674770,Content-Length: 517918856,Date: Mon, 19 Nov 2012 02:40:40 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:40,955 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:40,960 DEBUG [WebServer] Incoming connection from /192.168.2.40:39618
2012-11-18 21:40:40,960 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,961 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=1050239224-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:40,961 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:40,962 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,962 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:40,962 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:40,964 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:40,964 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:40,988 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:40,988 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 483435546
2012-11-18 21:40:40,988 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:40,988 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 1050239224-1533674769/1533674770,Content-Length: 483435546,Date: Mon, 19 Nov 2012 02:40:40 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:40,994 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:41,003 DEBUG [WebServer] Incoming connection from /192.168.2.40:39619
2012-11-18 21:40:41,004 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:41,005 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=1150883196-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:41,005 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:41,006 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:41,006 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:41,006 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:41,008 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:41,008 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:41,046 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:41,046 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 382791574
2012-11-18 21:40:41,047 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:41,047 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 1150883196-1533674769/1533674770,Content-Length: 382791574,Date: Mon, 19 Nov 2012 02:40:41 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:41,054 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:41,058 DEBUG [WebServer] Incoming connection from /192.168.2.40:39620
2012-11-18 21:40:41,058 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:41,059 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=1271504872-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:41,059 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:41,060 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:41,060 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:41,060 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:41,062 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:41,062 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:41,105 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:41,120 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 262169898
2012-11-18 21:40:41,451 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:41,451 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 1271504872-1533674769/1533674770,Content-Length: 262169898,Date: Mon, 19 Nov 2012 02:40:41 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:41,459 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:41,465 DEBUG [WebServer] Incoming connection from /192.168.2.40:39621
2012-11-18 21:40:41,465 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:41,466 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=1393420550-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:41,467 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:41,467 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:41,468 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:41,468 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:41,469 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:41,469 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:41,538 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:41,538 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 140254220
2012-11-18 21:40:41,538 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:41,539 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 1393420550-1533674769/1533674770,Content-Length: 140254220,Date: Mon, 19 Nov 2012 02:40:41 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:41,546 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:41,550 DEBUG [WebServer] Incoming connection from /192.168.2.40:39622
2012-11-18 21:40:41,550 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:41,551 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=1494374090-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:41,551 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:41,552 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:41,552 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:41,553 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:41,554 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:41,554 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:41,579 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:41,580 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 39300680
2012-11-18 21:40:41,580 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:41,580 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 1494374090-1533674769/1533674770,Content-Length: 39300680,Date: Mon, 19 Nov 2012 02:40:41 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:41,588 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:41,592 DEBUG [WebServer] Incoming connection from /192.168.2.40:39623
2012-11-18 21:40:41,592 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:41,593 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=1533671938-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:41,594 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:41,594 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:41,595 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:41,595 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:41,596 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:41,597 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:41,629 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:41,630 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 2832
2012-11-18 21:40:41,630 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:41,630 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 1533671938-1533674769/1533674770,Content-Length: 2832,Date: Mon, 19 Nov 2012 02:40:41 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:41,633 DEBUG [WebServer] I/O error: Connection reset
2012-11-18 21:40:41,635 DEBUG [WebServer] Incoming connection from /192.168.2.40:39624
2012-11-18 21:40:41,636 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:41,637 DEBUG [ResourceTransportRequestHandler] GET /resource/42762/MEDIA_ITEM/AVI-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Range: bytes=65536-,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:41,637 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:41,638 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:41,638 DEBUG [ResourceDeliveryProcessor] Request for resource 42762 and type 'MEDIA_ITEM' received
2012-11-18 21:40:41,638 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42762 (local)
2012-11-18 21:40:41,639 DEBUG [VideoDeliveryEngine] Delivering item '42762' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:41,640 DEBUG [VideoDeliveryEngine] Delivering file 'Inception.avi' in native format
2012-11-18 21:40:41,671 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:41,671 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 1533609234
2012-11-18 21:40:41,671 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:41,672 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-msvideo,Content-Range: bytes 65536-1533674769/1533674770,Content-Length: 1533609234,Date: Mon, 19 Nov 2012 02:40:41 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:41,706 DEBUG [RendererManager] Removing renderer 118295a4-0090-a9c1-b275-27c57a50f750 from list of active renderers
2012-11-18 21:40:41,738 DEBUG [RendererManager] Adding renderer Renderer [uuid=118295a4-0090-a9c1-b275-27c57a50f750, ipAddress=192.168.2.40, name=WD TV Live, profileId=14, manuallyAdded=false, forcedProfile=true, enabled=true, accessGroupId=1] to list of active renderers
2012-11-18 21:40:43,250 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2012-11-18 21:40:45,812 DEBUG [RendererManager] Removing renderer 118295a4-0090-a9c1-b275-27c57a50f750 from list of active renderers
2012-11-18 21:40:45,829 DEBUG [RendererManager] Adding renderer Renderer [uuid=118295a4-0090-a9c1-b275-27c57a50f750, ipAddress=192.168.2.40, name=WD TV Live, profileId=14, manuallyAdded=false, forcedProfile=true, enabled=true, accessGroupId=1] to list of active renderers
2012-11-18 21:40:45,829 DEBUG [WebServer] Incoming connection from /192.168.2.40:39625
2012-11-18 21:40:45,830 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:45,831 DEBUG [ResourceTransportRequestHandler] HEAD /resource/42766/MEDIA_ITEM/AVC_MP4_MP_HD_720p_AAC-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:45,831 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:45,832 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:45,832 DEBUG [ResourceDeliveryProcessor] Request for resource 42766 and type 'MEDIA_ITEM' received
2012-11-18 21:40:45,832 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42766 (local)
2012-11-18 21:40:45,833 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 42766, format AVC_MP4_MP_HD_720p_AAC and profile WDTV Live
2012-11-18 21:40:45,834 DEBUG [ResourceDeliveryProcessor] Sending HEAD response back
2012-11-18 21:40:45,834 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mp4,Content-Length: 2313389718,Date: Mon, 19 Nov 2012 02:40:45 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MP4_MP_HD_720p_AAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:45,846 DEBUG [WebServer] Incoming connection from /192.168.2.40:39626
2012-11-18 21:40:45,847 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:45,848 DEBUG [ResourceTransportRequestHandler] GET /resource/42766/MEDIA_ITEM/AVC_MP4_MP_HD_720p_AAC-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.2.11:8895,Content-Length: 0,transferMode.dlna.org: Streaming,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks]]
2012-11-18 21:40:45,848 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:45,849 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:45,849 DEBUG [ResourceDeliveryProcessor] Request for resource 42766 and type 'MEDIA_ITEM' received
2012-11-18 21:40:45,849 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 42766 (local)
2012-11-18 21:40:45,850 DEBUG [VideoDeliveryEngine] Delivering item '42766' for client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:45,851 DEBUG [VideoDeliveryEngine] Delivering file 'Iron Man 2.mp4' in native format
2012-11-18 21:40:45,871 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-11-18 21:40:45,871 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 2313389718
2012-11-18 21:40:45,871 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:45,871 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mp4,Content-Length: 2313389718,Date: Mon, 19 Nov 2012 02:40:45 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-11-18 21:40:46,287 DEBUG [WebServer] Incoming connection from /192.168.2.40:39627
2012-11-18 21:40:47,061 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:47,061 DEBUG [ResourceTransportRequestHandler] GET /resource/40872/COVER_IMAGE HTTP/1.0, headers = [HOST: 192.168.2.11:8895,User-Agent: ALPHA Networks/CTID,Accept: */*]]
2012-11-18 21:40:47,062 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:40:47,062 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.2.40, Profile=WDTV Live'
2012-11-18 21:40:47,063 DEBUG [ResourceDeliveryProcessor] Request for resource 40872 and type 'COVER_IMAGE' received
2012-11-18 21:40:47,067 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 40872
2012-11-18 21:40:47,068 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 6152
2012-11-18 21:40:47,068 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-11-18 21:40:47,068 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: image/jpeg,Content-Length: 6152,Date: Mon, 19 Nov 2012 02:40:47 GMT,Server: Windows Server 2012, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Interactive]]
2012-11-18 21:41:52,503 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:48
2012-11-18 21:42:29,693 DEBUG [RendererManager] Removing renderer 118295a4-0090-a9c1-b275-27c57a50f750 from list of active renderers
2012-11-18 21:42:29,710 DEBUG [RendererManager] Adding renderer Renderer [uuid=118295a4-0090-a9c1-b275-27c57a50f750, ipAddress=192.168.2.40, name=WD TV Live, profileId=14, manuallyAdded=false, forcedProfile=true, enabled=true, accessGroupId=1] to list of active renderers
2012-11-18 21:42:29,730 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2012-11-18 21:42:31,346 WARN [EmbeddedMetadataExtractor] Cannot read image file E:\ServerFolders\Pictures\2003\2003-12-26\P1000019.JPG
2012-11-18 21:42:32,062 WARN [LibraryManager] Cannot read metadata of file E:\ServerFolders\Pictures\2006\2006-05-13 (Maman 50th)\HPIM4852.JPG via extractor EMBEDDED. Message: Cannot read file HPIM4852.JPG for metadata extraction: Not a Valid JPEG File: missing JFIF string
2012-11-18 21:42:32,064 WARN [LibraryManager] Cannot read metadata of file E:\ServerFolders\Pictures\2006\2006-05-13 (Maman 50th)\HPIM4854.JPG via extractor EMBEDDED. Message: Cannot read file HPIM4854.JPG for metadata extraction: Not a Valid JPEG File: missing JFIF string
2012-11-18 21:42:32,067 WARN [LibraryManager] Cannot read metadata of file E:\ServerFolders\Pictures\2006\2006-05-13 (Maman 50th)\HPIM4858.JPG via extractor EMBEDDED. Message: Cannot read file HPIM4858.JPG for metadata extraction: Not a Valid JPEG File: missing JFIF string
2012-11-18 21:42:32,086 WARN [LibraryManager] Cannot read metadata of file E:\ServerFolders\Pictures\2006\2006-05-13 (Maman 50th)\HPIM4861.JPG via extractor EMBEDDED. Message: Cannot read file HPIM4861.JPG for metadata extraction: Not a Valid JPEG File: missing JFIF string
2012-11-18 21:42:32,088 WARN [LibraryManager] Cannot read metadata of file E:\ServerFolders\Pictures\2006\2006-05-13 (Maman 50th)\HPIM4862.JPG via extractor EMBEDDED. Message: Cannot read file HPIM4862.JPG for metadata extraction: Not a Valid JPEG File: missing JFIF string
2012-11-18 21:42:32,090 WARN [LibraryManager] Cannot read metadata of file E:\ServerFolders\Pictures\2006\2006-05-13 (Maman 50th)\HPIM4863.JPG via extractor EMBEDDED. Message: Cannot read file HPIM4863.JPG for metadata extraction: Not a Valid JPEG File: missing JFIF string
2012-11-18 21:42:35,398 WARN [EmbeddedMetadataExtractor] Cannot read image file E:\ServerFolders\Pictures\2009\2009-10-03 Guy R Wedding\PICT2930.JPG
2012-11-18 21:42:38,602 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.2.40:52783
2012-11-18 21:42:38,602 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:42:38,603 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.40:52783
2012-11-18 21:42:38,603 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.2.40:52783
2012-11-18 21:42:38,603 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:42:38,604 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.2.40:52783
2012-11-18 21:42:39,103 DEBUG [WebServer] Incoming connection from /192.168.2.40:64051
2012-11-18 21:42:39,103 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:42:39,104 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device b3d47380-b220-3f14-b287-c3e3e8f14386 from 192.168.2.40 (headers = [Host: 192.168.2.11:8895,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 Intel MicroStack/1.0.1423])
2012-11-18 21:42:39,104 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:42:39,104 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [Host: 192.168.2.11:8895,User-Agent: INTEL_NMPR/2.1 DLNADOC/1.50 Intel MicroStack/1.0.1423]
2012-11-18 21:42:39,105 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:42:39,107 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'WDTV Live'
2012-11-18 21:42:39,120 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:42:39,120 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service X_MS_MediaReceiverRegistrar
2012-11-18 21:42:39,122 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-11-18 21:42:39,133 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:42:39,134 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ContentDirectory
2012-11-18 21:42:39,135 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-11-18 21:42:39,152 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.2.40
2012-11-18 21:42:39,153 DEBUG [ServiceDescriptionRequestHandler] ServiceDescription request received for service ConnectionManager
2012-11-18 21:42:39,154 DEBUG [ServiceDescriptionRequestHandler] Sending ServiceDescription XML back
2012-11-18 21:42:41,682 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth6 (D-Link DGE-530T Gigabit Ethernet Adapter) and address 192.168.2.11, timeout = 0
2012-11-18 21:42:41,684 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device b3d47380-b220-3f14-b287-c3e3e8f14386
2012-11-18 21:42:46,516 DEBUG [RendererManager] Removing renderer 118295a4-0090-a9c1-b275-27c57a50f750 from list of active renderers
mike_s104
Post Mon Nov 19, 2012 6:57 pm
Re: WDTV problems
First think I would look at is turning off any firewall then it would be disabling or troubleshooting any A/V software installed on the server. I would also check the connection speed of the NIC. I would also look at any self-made cables.
Also, what model is your WVTV unit and what firmware is on it?
mike_s104
Post Mon Nov 19, 2012 6:58 pm
Re: WDTV problems
Willems wrote:Thank you for your response. I had Java 7 64 bits installed automatically and went back to the latest version of Java 6 64 bita, unfortunately no change at all.
Try a 32bit version.
Post Tue Nov 20, 2012 2:26 pm
Re: WDTV problems
I made some improvements for 1.1 hopefully.
mike_s104
Post Tue Nov 20, 2012 8:27 pm
Re: WDTV problems
zip wrote:I made some improvements for 1.1 hopefully.
I'm willing to beta test.
Users browsing this forum: Baidu [Spider], Google [Bot] and 20 guests
