Re: Web UI in PHP (revised)
greenythebeast wrote:Will this run on nginx or lighttpd?
I haven't tried it, but if the PHP requirements are present then I don't see why not. If you happen to give either/both a try, would love to hear the results!
mpemberton5 wrote:greenythebeast wrote:Will this run on nginx or lighttpd?
greenythebeast wrote:Is the 1.3 version on Github ready to go or is it still a WIP?
totoro81 wrote:Hello everyone,
I found a solution to the presentation tab problem.
The issue was in magic_quotes PHP parameter, that must be set to Off. Probably some NAS (like my QNAP) have this setting to On in the default configuration.
There are two methods to change the value:
- directly on php.ini
- locally on the code of serviio web ui
The second method requires that you create a .htaccess file in web_ui/code folder and put this directive into it:
php_value magic_quotes_gpc "Off"
Hope this helps.
Bye!
Xmantium wrote:Reading this - http://en.wikipedia.org/wiki/Magic_quotes
Think it's best to disable magic quotes at system level
mpemberton5 wrote:greenythebeast wrote:Is the 1.3 version on Github ready to go or is it still a WIP?
Definitely work in progress. I guess I should have branched it for the 1.3 version. My apologies for the confusion. Still got some work to do before I release it. Definitely making progress.
csholmq wrote:mpemberton5 wrote:greenythebeast wrote:Is the 1.3 version on Github ready to go or is it still a WIP?
Looking forward to the integration of serviidb.com ! Do you think it will be out in time for the 1.1 release, around Christmas?
Xmantium wrote:Mark is it possible to have Online sources it's own main tab, since I mainly use the web UI to add or change online content and with ServiiDB integration coming in, think it deserves it's own main tab. ServiiDroid does this as well.
I asked zip to also do this with the official console but there's too little room. But the web UI has plenty of place even on my tablet.![]()
Even better a user option to switch it dynamically between main tab or sub tab in Library tab
jshg46 wrote:I'm beginning to think if you are planning on staying with free Serviio, you would be better off with 6.2 . I have upgraded as well and I have seen a lot of interesting problem due to the lack of a license.
lmd wrote:Hi guys,
Well, things have been working really well with my setup. I decided to upgrade Serviio to 1.0.1 and updated the WebUI in PHP to match.
I also recompiled my FFMPEG as I was having problems getting the mediabrowser to work - and all was fine.
However, the trial part of Serviio has expired, and since that I have been unable to edit, add or remove playlists from my online sources.
The feeds themselves are working, but it appears that communications for this feature between the web console and the server aren't communicating properly.
I've checked the Serviio log (detailed logging is on) and I can't see anything amiss - I have had to scour these before to work out problems with FFMPEG and I'm not getting any error messages relating to Online Sources except for a few ILive sources timing out.
Anybody else experienced this?
My setup is as follows:
Ubuntu 12.04LTS Server (headless)
Web UI in PHP
Apache, PHP5, libCurl, libXML all installed and working
Licence just expired
Unable to modify online sources with web ui
Any help appreciated!
Cheers
Edit - The same thing happens with local sources too, I get a feeling anything I update on the console is not being saved - despite the console giving me the 'Saved' response when I click the Save button. When I refresh the browser after saving, the change I thought had applied has disappeared. This has all started happening since the trial period for Pro has expired. Do you think this could be linked or have I added 2 and 2 and come up with 5?
Xmantium wrote:Hi Mark, are you going to make separate versions for Serviio 1.0.1 (bugs fixed) and for 1.1?
