ServiiDroid (Android Console) - Get it on Google Play
Xmantium
Post Fri Nov 02, 2012 9:48 pm
Re: ServiiDroid (Android Console) - Get it on Google Play
Is possible to make "Start", "Stop" and "Refresh" button to stay few pixels above the Device line so its always even/aligned
Tried restarting app on tablet, still cant access any settings in Advanved section, all other tabs work... tried holding down but doesn't work... hmmm....
Worked fine on previous build
Post Fri Nov 02, 2012 9:50 pm
Ahhh, do you have short click turned off? Its now using a common class for managing lists, i need to ignore it for the advanced one. Give me 5 min and i'll upload a fix.
Post Fri Nov 02, 2012 9:57 pm
I've uploaded a new version that should fix that.
Xmantium
Post Fri Nov 02, 2012 9:58 pm
Ah ha! Yes Short click turned off, switched it to edit and now works! But yes short clock should only apply to devices, folders and sources.
Any scope to a user re-arranging top tabs?
Post Fri Nov 02, 2012 10:11 pm
I'll have a look once I've got this version out. I won't give complete freedom, but I think I could give a few pre-defined orders, but I need to check a few things first.
Xmantium
Post Sat Nov 03, 2012 8:07 am
Is the update the same link and version number?
Post Sat Nov 03, 2012 8:10 am
Same link, new file. Just redownload it and install it over. I think it has a new internal version code, but that doesn't matter when side loading.
Post Sat Nov 03, 2012 3:04 pm
This one moves from context menus to action modes (plus some other minor tweaks).
Please report any problems, I'm hoping to push this out to everyone tomorrow.
EDIT: Preview 3 adds support for different tab orders (have done very little testing on this)
Xmantium
Post Sat Nov 03, 2012 9:46 pm
Amazing job, everything workin!
Thanks for the tab ordering, works fine but it lists the same template three more times, there's probably a duplication bug
Post Sat Nov 03, 2012 9:49 pm
I have 5 orders and they are all different, are you sure (they do look pretty similar).
Xmantium
Post Sat Nov 03, 2012 10:35 pm
Here's a screen shot, last three are duplicates
http://db.tt/UQMyf7ou
Post Sat Nov 03, 2012 10:49 pm
Ah, they are duplicated because they don't contain devices as it's a large tablet (which would make them unique), I'll have to supply two different sets.
Post Mon Nov 05, 2012 9:42 pm
The next release is now delayed until next weekend, but I think it will be worth it. In addition to the other improvements, it will now include updated icons and more importantly, batch operations....
Xmantium
Post Mon Nov 05, 2012 10:33 pm
Show off! :D
Serious note looking good!
Is it possible to have one media icon showing to make it simpler
Ie in your example Google Developers entry, it just shows the rrs and video icon, as online sources can only be one variable unlike folder sources.
Post Mon Nov 05, 2012 10:37 pm
Xmantium wrote:Show off! :D
:D
Yes, thats my plan, just working on the framework stuff first, then I'll finish updating the remaining icons and adjust the positiong and sizing.
Post Sun Nov 11, 2012 1:20 pm
I've just uploaded 1.8 to google play. Please test it and report back problems/request adjustments and changes. Assuming everything is OK with this release, I'm going to return my focus to ServiiGo for a while (with the exception of adding support for 1.1 once that comes out). Enjoy.
==== 1.8 ====
*Combined the status and devices view on large tablets
*Added support for modifying multiple items at once via multiselect action modes
*Added high resolution versions of all icons
*Adjustments for tablets
*Reworked the backend to eliminate some rare bugs
*Added support for changing the order of tabs
*Fixed the theme not being applied to the online sources re-order view
*Translation updates
*Library updates
Xmantium
Post Sun Nov 11, 2012 9:46 pm
Thanks for the latest update, everything working fine as it should. Liking the new icons.
I've got one little snag, I thought the selection button appears when user press edit icon/button on action bar.
Find it little distracting and it uses some space from the online sources. I'm probably used to the old style.
Please can you make the selection boxes appear dynamically when user press an edit button or holds down on item. :D
Post Mon Nov 12, 2012 8:55 am
The checkboxes are always there because they serve multiple purposes. They show when an item is selected, but they also inform the user in the first place that they can do things to the list items. They can also be used to start the action mode (user either long clicks and list item, or clicks a checkbox to start). Most of the apps that apply this design pattern use small checkboxes so I want to keep them always visible as that is what users will get used to.
Having said that, I'm not that happy about the layout for online sources. It looked OK when I had audio, image and video icons, even if they were redundant, but they were redundant so I removed them. I might try putting the type icon just above the checkbox, and the media type icon next to the source url (slightly under the title). Now that refreshing single or multiple items is easier, I could also remove the dedicated refresh button.
Post Mon Nov 12, 2012 6:15 pm
Try this. If there still isn't enough space I'll hide the dedicated refresh button in portrait mode on phones.
==== 1.8.2 ====
*Added support for picking a license file to upload from within the license info view
*Minor UI adjustments and bug fixes
Xmantium
Post Tue Nov 13, 2012 10:52 pm
Any thoughts about updating the ServiiDroid logo for more 3D look.
Compared to other ICS/JellyBean icons the current Droid looks flat
Heres one:
