Problem with high resolution images on Samsung BD-D5100
Desperaton
Post Sun Jan 15, 2012 3:55 pm
being new to Serviio and dlna in general, so far I'm quite happy with the audio and video capabilities. But there is a problem with images. The thumbnails display fine, but when selecting the high resolution ones for viewing, their is an error message. Images less than 4096x4096 (my guess...) display fine, but with higher resolution I get a message saying something like "unsupported file format" (translated from Swedish). I test with a png file 4288x2848, but get the same results with jpg:s with the same resolution. If I take that file and crop it to 3750x2519 (using Gimp) and save it under a different file name , it displays fine.
I have tried both false and true in
<LimitImageResolution>true</LimitImageResolution>
I created a log file with the "true" option set, to confirm that serviio does some kind of transformation.
Any ideas on how to fix this? Is their a way to test how serviio transforms an image to lower resolution?
Here is part of the log file (whole file attached after restarting with only 4 images in the library):
2012-01-09 21:20:24,778 DEBUG [ImageDeliveryEngine] Delivering file '4_test.jpg' using transcoding
2012-01-09 21:20:24,779 DEBUG [ImageDeliveryEngine] Retrieving transcoded version of file 4_test.jpg using format profile JPEG_LRG
2012-01-09 21:20:24,779 DEBUG [MediaItemDAOImpl] Getting file of media item 4160
2012-01-09 21:20:24,784 DEBUG [ImageUtils] Starting image resize, size = 3196507 bytes
2012-01-09 21:20:27,591 DEBUG [ImageUtils] Returning resized image, size = 1870279 bytes
2012-01-09 21:20:27,591 DEBUG [TranscodingCache] Storing media item 4160 with profile JPEG_LRG to cache
2012-01-09 21:20:27,591 DEBUG [ResourceTransportRequestHandler] Entity will be consumed till the end
2012-01-09 21:20:27,591 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: -1
2012-01-09 21:20:27,591 DEBUG [ResourceTransportRequestHandler] Sending file back
Thanks for any help!
/Glenn
serviio.log.zip
(10.54 KiB) Downloaded 452 times
mbr
Post Sat Nov 03, 2012 6:31 pm
Re: Problem with high resolution images on Samsung BD-D5100
I have the Samsung BD-D5100 blu ray player and same problem with large jpg files. I find out that if file is larger than 3889x2591 (most probably width is the cruicial) it is not showed, and samsung shows "unsupported file format" message.
Would it be possible to make Serviio to resize image files larger than 3889x2591 to some lower resolution by configuration?
Post Mon Nov 05, 2012 11:04 pm
I'll double check. Can one of you send me an image that shows this behaviour to zip[at]serviio.org ?
mbr
Post Sun Dec 02, 2012 2:59 pm
I sent a sample photo.
Swehawk
Post Thu Dec 20, 2012 5:46 pm
I have a similar problem with the LG-profile. There is however another thread on this subject: viewtopic.php?f=7&t=7285&hilit=image
