Online Sources....Inconsistency
Raido
Post Sat Nov 03, 2012 5:06 pm
Hi guys....just found out the beauty of this software recently. But when i'm trying to add links/url to my Online Resources, it does not come out consistently. When i restart the software, either, one, two, or sometimes all the links are there. If i will restart again, no online links will be shown in the Online folder. I have tried this both in Mac and in Win XP configuration. Any part that i need to configure for all the links that i want to come out whenever i'm using serviio.
here is what im using:
Serviio - installed in Mac / Win XP
Renderer - Samsung Series 5 TV
Android software - BubleUpnp ( Samsung Galaxy S3 )
Hope you can help me in this.
Post Sat Nov 03, 2012 6:41 pm
Re: Online Sources....Inconsistency
They are only cached, not stored in the DB, so it depends if they are available at the point of the check.
Check your serviio.log to see if there are any errors. Possibly check the detailed log, you should see when an online item cannot be added.
Raido
Post Sun Nov 04, 2012 5:10 am
Thanks for the reply. Sorry for my ignorance, where / how can i check for the log or detailed log? both in mac and xp. Also, is this applicable that even the folders (Online Folders) are not present on the time of the connection, 90% of the time?
Post Sun Nov 04, 2012 12:19 pm
for log, see my signature. It will take some time to scan the online sources after Serviio starts, if it's what you mena
Return to General discussion
