Limited access for MediaBrowser
Kefut
Post Fri Nov 02, 2012 5:18 pm
Hi all,
I would like to set my MediaBrowser to Limited access, but I only see internal IP's of my devices and none of them seam to belong to the MediaBrowser.
Is it just not possible to to restict it, or how can I do that?
Thanks!
Post Sat Nov 03, 2012 3:59 pm
Re: Limited access for MediaBrowser
Not possible at the moment.
Post Sat Nov 03, 2012 4:23 pm
I wonder if you could control access using a .htaccess file. I will try it on mine. It is an apache control file.
http://www.javascriptkit.com/howto/htaccess5.shtml
Is there a pesky person perpetrating pain upon you? Stalking your site from the vastness of the electron void? Blockem! In your htaccess file, add the following code--changing the IPs to suit your needs--each command on one line each:
order allow,deny deny from 123.45.6.7 deny from 012.34.5. allow from all
You can deny access based upon IP address or an IP block. The above blocks access to the site from 123.45.6.7, and from any sub domain under the IP block 012.34.5. (012.34.5.1, 012.34.5.2, 012.34.5.3, etc.) I have yet to find a useful application of this, maybe if there is a site scraping your content you can block them, who knows.
Post Sat Nov 03, 2012 4:31 pm
He meant Serviio's access groups feature, which as zip said isn't supported via the CDS API (MediaBrowser, ServiiGo) at the moment.
Post Sat Nov 03, 2012 4:48 pm
Yes, but there might be other ways to do it.
Post Sat Nov 03, 2012 6:46 pm
For the .htaccess file to work you'd have to access MB via the Apache proxy, not directly.
Post Sat Nov 03, 2012 7:46 pm
K was not sure how you was serving the Web page.
Kefut
Post Sat Nov 03, 2012 9:41 pm
zip wrote:Not possible at the moment.
You say "at the moment". Is it plaaned for the future?
Thanks!
Post Sun Nov 04, 2012 5:23 pm
possibly, will have to think about a nice way to implement it
LeJoKeR
Post Sun May 17, 2015 1:42 pm
Any news about this request ? I got some issue with this, can't limit access to some kind of content over media browser.
Tkx
Users browsing this forum: Baidu [Spider] and 180 guests
