Samsung BluRay bd d6500 Disconnecting
jukkajalava
Post Sun Nov 04, 2012 9:21 pm
So up until a week ago have had no problems streaming my movies to my bluray player worked without any disconnections. The player is connected via LAN cable to a dLink 655 router. have tried reinstalling serviio and used the bound adress feild in the console and no matter what it just dissconected either while browsing folders or that after 5 mins of playing a file.
Is there anybody that can help me with this problem? i have attached my logfile.
Thanks!!! in advanced
(184.96 KiB) Downloaded 503 times
Post Mon Nov 05, 2012 11:15 pm
Re: Samsung BluRay bd d6500 Disconnecting
This is weird
[DiscoveryAdvertisementNotifier] Could not advertise the device on any available NIC, will try again
Did you upgrade network card drivers or java?
jukkajalava
Post Tue Nov 06, 2012 4:22 pm
Hey thanks for the reply as far as i know i have not updated anything. Unless something from windows update changed something. Is there anything i could try to do to get serviio back the way it was?
FirstSoul
Post Thu Nov 08, 2012 1:02 pm
Hi there,
same problem here!
I've nothing updatet or something.
I've the same Problem with Serviio AND TVmobili
System: Mac OS X Mountain Lion
