[SOLVED] Avi problems with BDP
Daibak
Post Tue Nov 06, 2012 8:49 pm
I read many topics in this forum about avi and BDP (i know that it has already been asked)but i didn't unterstand what to do (I am not keen on codecs).
These are the info:
Sony BDP-S390 (2011, updated and bought in Europe) and SMP profile
When I tried to play avi files it says that they aren't supported.
Can someone explain how to fix the problem? i'll post a detailed log if necessary.
Post Wed Nov 07, 2012 8:44 am
Re: Avi problems with BDP
For Sony BDP-S390, use "Sony BD Player / SMP" profile.
Could you provide information about the avi file that does not play ? (see signature link)
Suggest to change the FourCC of your avi file to XVID with this tool : http://wiki.serviio.org/doku.php?id=avi4cc
Daibak
Post Wed Nov 07, 2012 4:50 pm
I am already using that profile.
This is the information about one of the unplayable files:
C:\Programmi\Serviio\lib>ffmpeg.exe -i "C:\(not important)\HIMYM-1X11.avi"
g-config
Input #0, avi, from 'C:\(not important)\Server\HIMYM
-1X11.avi':
    encoder         : VirtualDubMod 1.5.10.2 (build 2540/release)
  Duration: 00:21:10.76, start: 0.000000, bitrate: 1154 kb/s
    Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv
420p, 576x432 [SAR 1:1 DAR 4:3], 23.98 tbr, 25 tbn, 23.98 tbc
    Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16, 32 kb/
s
Daibak
Post Tue Nov 13, 2012 7:40 pm
Thank, thank you very much
