Can't see folders on Samsung players or webconsole
tdalton
Post Wed Nov 07, 2012 5:38 pm
Hi, I'm new to Serviio finally giving up on Samsung's PC Share Manager. One thing I noticed out of the gate is that my folders are not showing up. So I have one folder shared with videos and in that folder are a bunch of subfolders. WIth PC Share Manager I could see all my folders and navigate them. When I click on Folders in Serviio either from my Samsung BDP OR the Serviio console the "Folders" folder is blank. I also have another question regarding the limited access option. My take is that you need to share a separate folder and specify limited access to that specific folder (and hopefully inherently it's subfolders) and then only devices with limited access rights can see it? One more curve ball. Let's say I am sharing D:\movies and in that folder I have D:\movies\adult. If I have full access share to D:\movies and create another share to D:\movies\adult with limited access will that work or will that not work? I have created two shares this same way but since I can't get a folder view I can't test it. Any info would be greatly appreciated. Thanks!
tdalton
Post Thu Nov 08, 2012 1:11 pm
Re: Can't see folders on Samsung players or webconsole
If anyone can help it would be immensely appreciated. I'm evaluating the Pro version and need to figure this out before I decide to buy or not. Thanks!
Post Tue Nov 13, 2012 12:34 am
Did any file get added? Can you post your log?
tdalton
Post Tue Nov 13, 2012 3:00 am
all the files seem show up when I just list them but folder structure is not there for some reason. I'll email you the log right now. Thanks.
Post Tue Nov 13, 2012 2:49 pm
Files are added as per the log. What do you mean by the web console? MediaBrowser?
