[SOLVED] Ubuntu 12.04 ffmpeg problems
ElToro1966
Post Thu Nov 08, 2012 3:24 pm
I've just upgraded to 1.01 and it works fine, except that I have problems playing back podcasts. On my Foobar2000-client (v.1.1.16 on Win7) I get the following error:
Unable to open item for playback (Internal Server Error (500)):
"http://192.168.0.109:8895/resource/1000000000090001/MEDIA_ITEM/MP3-0/ORIGINAL"
I can see the server, the folders and each podcast in the UPnP browser of the Foobar2000, but it is impossible to play back. I've also tried other clients without success.
The server:
Serviio 1.01
Ubuntu 12.04 LTS
ffmpeg 4:0.8.3-0ubuntu0.12.04.1 (latest version)
The server log:
2012-11-08 13:37:28,738 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error.
2012-11-08 13:37:52,797 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
   at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
   at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:125)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:95)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:117)
   at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:84)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:79)
   at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:191)
2012-11-08 13:38:03,012 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error.
2012-11-08 13:38:17,887 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/transcoding-temp-1000000000090002-1-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-1000000000090002-1-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
   at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:45)
2012-11-08 13:38:28,077 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error.
2012-11-08 13:38:28,101 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
org.serviio.library.online.CannotRetrieveThumbnailException: Failed to download thumbnail http://nrk.no/img/595808.jpg.
   at org.serviio.library.online.OnlineLibraryManager.findThumbnail(OnlineLibraryManager.java:266)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:107)
Caused by: java.io.FileNotFoundException: http://img.nrk.no/img/595808.jpg
   at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1613)
   at org.serviio.util.HttpClient.retrieveBinaryFileFromURL(HttpClient.java:72)
   at org.serviio.library.online.OnlineLibraryManager.findThumbnail(OnlineLibraryManager.java:258)
   ... 1 more
2012-11-08 13:38:28,466 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:28,823 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:29,176 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:29,517 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:29,860 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:30,204 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:30,551 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:30,894 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:31,350 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:31,710 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:32,068 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:32,417 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:32,780 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:33,137 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:33,489 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:33,833 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:34,403 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:34,829 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
2012-11-08 13:38:35,187 WARN  [FeedUpdaterThread] An error occured while retrieving thumbnail, will remove it from the item the and will continue
   ... 1 more
Post Thu Nov 08, 2012 8:40 pm
Re: Podcast problems - Internal Server Error 500
Probably old version of FFmpeg.
ElToro1966
Post Fri Nov 09, 2012 12:31 pm
zip wrote:Probably old version of FFmpeg.
It shouldn't be. But it is. Installed ffmpeg via the Ubuntu Software Center, but this seems to be insufficient. The steps below have to be followed.
Changing header to solved and title to Ubuntu 12.04 ffmpeg problems.
For Ubuntu 12.05 that have problems as above, the ffmpeg should be installed from the terminal. Moreover, additional codecs and libraries should be installed to esnure flawless operation of Serviio. Recommend you do the following using Terminal:
Install missing codecs (including latest Lame):
sudo apt-get install ubuntu-restricted-extras
Install DVD playback libraries:
sudo apt-get install libdvdread4
sudo wget --output-document=/etc/apt/sources.list.d/medibuntu.list http://www.medibuntu.org/sources.list.d/$(lsb_release -cs).list && sudo apt-get --quiet update && sudo apt-get --yes --quiet --allow-unauthenticated install medibuntu-keyring && sudo apt-get --quiet update
sudo apt-get install libdvdcss2
Install ffmpeg:
sudo apt-get install libxine1-ffmpeg gxine mencoder mpeg2dec vorbis-tools id3v2 mpg321 mpg123 libflac++6 ffmpeg totem-mozilla icedax tagtool easytag id3tool lame nautilus-script-audio-convert libmad0 libjpeg-progs flac faac faad sox ffmpeg2theora libmpeg2-4 uudeview flac libmpeg3-1 mpeg3-utils mpegdemux liba52-0.7.4-dev libquicktime2
Install Gstreamer:
sudo apt-get install gstreamer0.10-ffmpeg gstreamer0.10-fluendo-mp3 gstreamer0.10-gnonlin gstreamer0.10-sdl gstreamer0.10-plugins-bad-multiverse gstreamer0.10-plugins-bad gstreamer0.10-plugins-ugly totem-plugins-extra gstreamer-dbus-media-service gstreamer-tools
That's it! :geek:
Post Fri Nov 09, 2012 2:19 pm
Re: [SOLVED] Ubuntu 12.04 ffmpeg problems
great, thanks. Maybe you could add it /update the wiki?
ElToro1966
Post Fri Nov 09, 2012 4:42 pm
zip wrote:great, thanks. Maybe you could add it /update the wiki?
Done. http://wiki.serviio.org/doku.php?id=howto:linux:install:ubuntu12-04
8-)
Post Sun Nov 11, 2012 10:57 pm
Users browsing this forum: No registered users and 51 guests
