problems windows 8 and serviio
zixzero
Post Tue Nov 06, 2012 1:58 pm
I have a problem with serviio and windows 8 install and configure it as you used to in windows 7 but when trying to see my files via upnp not see anything you may be blocking windows even disable the firewall program to comprovarlo and nothing
anyone know a solution?
slyfoxrocks
Post Fri Nov 09, 2012 2:31 am
Re: problems windows 8 and serviio
Same issue here! Serviio Pro 1.0.1 was working fine under Windows 7. Once I upgraded to Windows 8 - I can no longer see Serviio from any of my devices (TVs, phone, tablet, WDTV, local computer etc.). Checked firewall settings and these are the same as in Windows 7. Tried uninstalling and reinstalling Serviio, but no luck so far. Thankfully Mezzmo still works fine in Windows 8, so I have a back up for now. Interestingly I can connect to Serviio via Serviidroid on my phone to administer it, but that's about it. Thanks in advance for any help!
Post Fri Nov 09, 2012 11:19 am
And what about Java installation... could you check that.
slyfoxrocks
Post Sat Nov 10, 2012 3:45 am
I reinstalled Java Version 7 Update 9, restarted Serviio and still can't see the server. There is a note on the Java site that states:
"Downloading and installing Java will only work in Desktop mode on Windows 8"
However, even if I used Desktop mode, I still cannot see Serviio from any devices.
yohojones
Post Sat Nov 10, 2012 3:15 pm
I'm having the same problem. I thought it was a firewall problem as well but twonky, link+ and Windows built in dlna server are visable over the network.
Minecraft has been quitting to desktop as well. I think there might be a java issue on windows 8.
NmS
Post Sun Nov 11, 2012 5:37 pm
I have the same problem. Tried everything from reinstalling Serviio and Java. Even tried older versions of Serviio.
Serviio just doesn't wanna show on my device (samsung c650), nor shows up in the network list on the computer itself. Checked all the firewall settings, but all seems fine. Really sucks, because I want to see my media on my TV, not on my computer!
Post Sun Nov 11, 2012 6:11 pm
Its ok for me with Windows 8 and serviio.
Post Sun Nov 11, 2012 11:44 pm
Somebody post detailed log, otherwise we are just guessing.
heathen462
Post Mon Nov 12, 2012 6:14 am
I am having the same issue. Windows 8 Pro, clean install, running maybe a week. Java 7 update 9. I had absolutely no issues with Serviio before this, on Windows 7 Pro, Windows Server v1, and many different flavor of Linux (well, I had issues on Linux, but they were Linux issues ;) ) and many different versions of Serviio. Was running 1.0.1 successfully untill Win8, now it just sin't seen on the network by any device, even my Android running ServiiDroid won't connect to it.
Here is my detailed log, from just before the restart and on. I don't see anything odd here, but you're the expert! There are some bad images in my library, apparently, but other than that...
2012-11-11 23:00:47,801 WARN [LibraryManager] Cannot read metadata of file P:\Apartment\PANO_20111210_125600.jpg via extractor EMBEDDED. Message: Not a Valid TIFF File
2012-11-11 23:00:47,903 WARN [LibraryManager] Cannot read metadata of file P:\Miscellaneous Events\Xmas Lights 2011\PANO_20111219_193606.jpg via extractor EMBEDDED. Message: Not a Valid TIFF File
2012-11-11 23:00:47,903 WARN [LibraryManager] Cannot read metadata of file P:\Miscellaneous Events\Xmas Lights 2011\PANO_20111219_203343.jpg via extractor EMBEDDED. Message: Not a Valid TIFF File
2012-11-11 23:00:47,904 WARN [LibraryManager] Cannot read metadata of file P:\Miscellaneous Events\Xmas Lights 2011\PANO_20111219_211213.jpg via extractor EMBEDDED. Message: Not a Valid TIFF File
2012-11-11 23:00:47,905 WARN [LibraryManager] Cannot read metadata of file P:\Miscellaneous Events\Xmas Lights 2011\PANO_20111219_214111.jpg via extractor EMBEDDED. Message: Not a Valid TIFF File
2012-11-11 23:00:48,035 WARN [LibraryAdditionsCheckerThread] Cannot add file IMG_20120116_140300.jpg because of an unexpected error. Message: null
java.lang.NegativeArraySizeException
at org.apache.sanselan.common.BinaryFileFunctions.readByteArray(BinaryFileFunctions.java:496)
at org.apache.sanselan.formats.jpeg.JpegUtils.traverseJFIF(JpegUtils.java:94)
at org.apache.sanselan.formats.jpeg.JpegImageParser.readSegments(JpegImageParser.java:170)
at org.apache.sanselan.formats.jpeg.JpegImageParser.readSegments(JpegImageParser.java:267)
at org.apache.sanselan.formats.jpeg.JpegImageParser.getImageInfo(JpegImageParser.java:659)
at org.apache.sanselan.Sanselan.getImageInfo(Sanselan.java:589)
at org.apache.sanselan.Sanselan.getImageInfo(Sanselan.java:479)
at org.serviio.library.local.metadata.extractor.embedded.ImageExtractionStrategy.extractMetadata(ImageExtractionStrategy.java:43)
at org.serviio.library.local.metadata.extractor.embedded.JPEGExtractionStrategy.extractMetadata(JPEGExtractionStrategy.java:63)
at org.serviio.library.metadata.SanselanMetadataRetriever.retrieveImageMetadata(SanselanMetadataRetriever.java:69)
at org.serviio.library.local.metadata.extractor.embedded.EmbeddedMetadataExtractor.retrieveImageMetadata(EmbeddedMetadataExtractor.java:199)
at org.serviio.library.local.metadata.extractor.embedded.EmbeddedMetadataExtractor.retrieveMetadata(EmbeddedMetadataExtractor.java:117)
at org.serviio.library.local.metadata.extractor.MetadataExtractor.extract(MetadataExtractor.java:46)
at org.serviio.library.local.LibraryManager.extractMetadata(LibraryManager.java:224)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.addNewMediaFile(LibraryAdditionsCheckerThread.java:178)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:145)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:134)
at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:83)
2012-11-11 23:00:48,036 WARN [LibraryAdditionsCheckerThread] Cannot add file IMG_20120121_153126.jpg because of an unexpected error. Message: null
2012-11-11 23:00:48,042 WARN [LibraryManager] Cannot read metadata of file P:\Pics to Go through\sdcard\PANO_20120205_202333.jpg via extractor EMBEDDED. Message: Not a Valid TIFF File
2012-11-11 23:00:48,223 WARN [LibraryManager] Cannot read metadata of file P:\Wallpapers\Music\wp01_03.jpg via extractor EMBEDDED. Message: Could not read block (block start: 302, block length: 9871, data length: 290).
2012-11-11 23:05:36,587 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2012-11-11 23:05:36,587 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2012-11-11 23:05:36,587 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2012-11-11 23:05:36,687 INFO [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2012-11-11 23:05:36,787 INFO [FeedUpdaterThread] Finished looking for online resources information
2012-11-11 23:05:36,887 INFO [PluginCompilerThread] Finished looking for plugins
2012-11-11 23:05:37,038 INFO [WebServer] WebServer shutting down
2012-11-11 23:05:37,038 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2012-11-11 23:05:37,038 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2012-11-11 23:05:37,038 INFO [EventDispatcher] Leaving EventDispatcher
2012-11-11 23:05:37,038 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2012-11-11 23:05:38,695 INFO [DatabaseManager] Shutting down database
2012-11-11 23:05:40,132 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2012-11-11 23:05:43,069 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2012-11-11 23:05:43,142 INFO [MediaServer] ------------------------------------------------------------------------
2012-11-11 23:05:43,142 INFO [MediaServer] Serviio DLNA media streaming server v 1.0.1 (rev. 6dbf7c6e334f+)
2012-11-11 23:05:43,142 INFO [MediaServer] Petr Nejedly 2009-2012
2012-11-11 23:05:43,142 INFO [MediaServer] http://www.serviio.org
2012-11-11 23:05:43,143 INFO [MediaServer] Java 1.7.0_09-Oracle Corporation
2012-11-11 23:05:43,143 INFO [MediaServer] OS Windows 8 amd64 6.2
2012-11-11 23:05:43,143 INFO [MediaServer] File encoding: windows-1252
2012-11-11 23:05:43,144 INFO [MediaServer] Headless mode enabled: true
2012-11-11 23:05:43,144 INFO [MediaServer] User home dir: C:\
2012-11-11 23:05:43,144 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2012-11-11 23:05:43,144 INFO [MediaServer] ------------------------------------------------------------------------
2012-11-11 23:05:43,388 INFO [WebServer] Socket buffer set to 65535 bytes
2012-11-11 23:05:43,396 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2012-11-11 23:05:43,467 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2012-11-11 23:05:43,467 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2012-11-11 23:05:43,515 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2012-11-11 23:05:43,535 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2012-11-11 23:05:44,885 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2012-11-11 23:05:45,362 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2012-11-11 23:05:45,362 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2012-11-11 23:05:45,363 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2012-11-11 23:05:45,364 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2012-11-11 23:05:45,365 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2012-11-11 23:05:45,365 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2012-11-11 23:05:45,366 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2012-11-11 23:05:45,367 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2012-11-11 23:05:45,367 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2012-11-11 23:05:45,368 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2012-11-11 23:05:45,369 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2012-11-11 23:05:45,369 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2012-11-11 23:05:45,643 INFO [MediaServer] ------------------------------------------------------------------------
2012-11-11 23:05:45,643 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2012-11-11 23:05:46,154 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2012-11-11 23:05:46,194 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2012-11-11 23:05:46,810 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2012-11-11 23:05:46,811 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2012-11-11 23:05:47,142 INFO [Device] Created UPnP Device with UUID: 461f9020-4135-38ae-9386-f5f70f662ad0, bound address: 192.168.239.1
2012-11-11 23:05:47,254 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2012-11-11 23:05:47,255 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2012-11-11 23:05:47,543 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2012-11-11 23:05:47,544 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2012-11-11 23:05:47,860 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2012-11-11 23:05:47,861 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2012-11-11 23:05:48,103 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2012-11-11 23:05:48,104 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2012-11-11 23:05:48,224 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2012-11-11 23:05:48,225 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2012-11-11 23:05:48,643 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2012-11-11 23:05:48,644 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2012-11-11 23:05:48,669 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2012-11-11 23:05:48,670 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2012-11-11 23:05:49,198 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2012-11-11 23:05:49,199 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 10
2012-11-11 23:05:49,801 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2012-11-11 23:05:49,802 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2012-11-11 23:05:50,046 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2012-11-11 23:05:50,048 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2012-11-11 23:05:50,184 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2012-11-11 23:05:50,186 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2012-11-11 23:05:50,211 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2012-11-11 23:05:50,212 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2012-11-11 23:05:50,320 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2012-11-11 23:05:50,322 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2012-11-11 23:05:50,366 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2012-11-11 23:05:50,367 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
And here is the derby log as well, for good measure:
Sun Nov 11 23:05:44 MST 2012:
Booting Derby version The Apache Software Foundation - Apache Derby - 10.9.1.0 - (1344872): instance a816c00e-013a-f339-3707-ffff8366333d
on database directory C:\Program Files\Serviio\library\db with class loader sun.misc.Launcher$AppClassLoader@490241ae
Loaded from file:/C:/Program%20Files/Serviio/lib/derby.jar
java.vendor=Oracle Corporation
java.runtime.version=1.7.0_09-b05
user.dir=C:\Program Files\Serviio\bin
derby.system.home=C:\Program Files\Serviio\bin\\..\library
derby.stream.error.file=../log/derby.log
Database Class Loader started - derby.database.classpath=''
Post Mon Nov 12, 2012 11:21 pm
try a different, possibly older, version of Java. The log looks normal
zixzero
Post Tue Nov 13, 2012 5:53 am
my computer will install the java runtime 7 that had the 6 that never gave me problems when using Windows 7, and as usual you can not see serviio UPnP server so java is not the problem.
kappclark
Post Tue Nov 13, 2012 10:47 pm
Has this been resolved ??
I am looking at getting a Dell with Windows 8 to run Serviio ... maybe run it in a VM under windows XP ?
Post Wed Nov 14, 2012 8:55 am
kappclark wrote:I am looking at getting a Dell with Windows 8 to run Serviio ... maybe run it in a VM under windows XP ?
I bought a DELL with Windows 8 on INTEL-i7, install Java and Serviio without problems (simply have to set admin user on serviio service, like my previous Windows XP setting)
heathen462
Post Wed Nov 14, 2012 4:21 pm
Can you clarify how you did this? It doesn't seem to matter which user this service runs under, Serviio simply does not show on my network. Plex Media Server and Universial DLNA Server (or whatever it's called) both display fine. I really love Serviio, and prefer to use this one. It is the best I've found so far.
Something I find odd, is my DLNA devices show up in the Serviio Console, so it CAN see the network, but other devices just can't see it...
heathen462
Post Wed Nov 14, 2012 4:44 pm
I should add as well, that like the other users with this issue, I have disabled my firewall, with no change. I have disabled Plex to see if this was blocking or conflicting somehow (Plex wasn't even installed when this issue first became apparent) with no change either. I can see all other devices on my network, so this certainly isn't a networking issue. I had been running the most current Java under Windows 7 as well, so this seems to be something specific with Serviio and Windows 8.
heathen462
Post Wed Nov 14, 2012 5:17 pm
Progress!
In Windows 8, you have to enable the default administrator service. Do this by opening an elevated command prompt and running the following command:
net user administrator /active:yes
You should then set a password for this user for your own safety. This user will now appear under the Users control panel as a local account.
Next, open the Management Console (right click on My Computer, click Manage or search it in "Metro").
Services & Applications -> Services, find the Serviio service -> right click -> Properties -> Log On
Choose "This Account" and enter "Administrator" for the user, then enter the password you should have set for this user, twice.
Stop the Serviio Server within Serviio Console, then stop the Serviio service.
Start the Serviio service, then start the Serviio server.
I also bound my computer's IP within Serviio, however this doesn't seem to make a difference as I only have 1 IP on this box.
Now Serviidroid sees and can manage Serviio. My xBox sees it, but cannot connect, and my PS3 cannot see it at all, though.
Post Wed Nov 14, 2012 7:18 pm
Could you :
- enable detailed logging (see signature)
- stop serviio service
- start serviio service
- post log
For my setup:
- install java 7
- download serviio, install serviio
- In metro search "cmd" to launch a windows terminal execute "services.msc", rigth click "properties" on serviio service, connection tab, set the account with ILLICO/admin value, I have to do this to have access to my remote shared network disk.
heathen462
Post Thu Nov 15, 2012 3:11 pm
Illico wrote:Could you :
- post log
For my setup:
- install java 7
My detailed log is on the first page of this thread, but I am happy to do it again if it helps.
heathen462
Post Thu Nov 15, 2012 4:57 pm
SOLVED
Previously, in Windows 7, I never ran HomeGroup. I simply shared my content in the classic fashion.
As a troubleshooting step, I enabled HomeGroup sharing on my Windows 8 box, and Serviio is now seen on the network by all devices.
I find this odd, as other DLNA servers such as Plex were showing up just fine, just as Serviio had in Windows 7.
I was also able to set the service to run under the system service again, so the issue is and was, that HomeGroup sharing needs to be enabled in Windows 8 for Serviio to be seen by devices on the network. I think the previous issue I had with ServiiDroid not seeing it was just my own stupidity.
Post Thu Nov 15, 2012 6:21 pm
heathen462 wrote:...HomeGroup sharing needs to be enabled in Windows 8 for Serviio to be seen by devices on the network.
Yes, it's also enabled on mine, I did not notice that. I remember now, that on first windows 8 start, it asked if we want to enable sharing, answer was : yes.
Thanks, topic solved.
Users browsing this forum: No registered users and 65 guests
