playing mkv on sony bravia KDL-32CX523
carlocaloy31
Post Sun Nov 11, 2012 2:43 pm
im having a problem on playing this video on my Sony bravia KDL-32CX523...
the mkv plays with audio but does not have video....here's the media info ..please help me...
Unique ID : 215030421651749588799114747345853171113 (0xA1C55A5130260CC2B9E73946721B45A9)
Complete name : D:\Movies\CONCERTS\Dream Theater - Live in Budokan HDRip-AVC\Dream Theater - Live at Budokan (5.1 audio).mkv
Format : Matroska
Format version : Version 2
File size : 2.66 GiB
Duration : 2h 56mn
Overall bit rate : 2 153 Kbps
Encoded date : UTC 2012-11-02 11:25:15
Writing application : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
Writing library : libebml v1.2.1 + libmatroska v1.1.1
Format : AVC
Format profile : High@L3.0
Format settings, CABAC : Yes
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 56mn
Width : 720 pixels
Height : 400 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 112
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color primaries : BT.709
Matrix coefficients : BT.709
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 2h 56mn
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Title : 5/1
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 1
00:00:54.054 : en:Chapter 2
00:08:35.749 : en:Chapter 3
00:20:48.080 : en:Chapter 4
00:40:23.021 : en:Chapter 5
00:49:40.026 : en:Chapter 6
00:52:05.055 : en:Chapter 7
00:57:06.023 : en:Chapter 8
01:08:28.972 : en:Chapter 9
01:20:36.432 : en:Chapter 10
01:34:35.036 : en:Chapter 11
01:42:36.025 : en:Chapter 12
01:46:34.054 : en:Chapter 13
01:53:56.080 : en:Chapter 14
02:00:05.449 : en:Chapter 15
02:06:05.007 : en:Chapter 16
02:17:00.002 : en:Chapter 17
02:22:55.067 : en:Chapter 18
02:32:24.010 : en:Chapter 19
Post Sun Nov 11, 2012 6:09 pm
Re: playing mkv on sony bravia KDL-32CX523
What is the profile selected ?
"Muxing mode : Header stripping" is not supported by a lot of devices in native format, you can remove this option with mkvmerg tool.
http://wiki.serviio.org/doku.php?id=header_com&s[]=mkvmerge
robertsearle
Post Sun Nov 11, 2012 8:28 pm
This sounds like the Sony issue viewtopic.php?f=11&t=7726.
Post Mon Nov 12, 2012 7:53 am
So topic solved ?
carlocaloy31
Post Mon Nov 12, 2012 9:42 am
ok i'll try it...
carlocaloy31
Post Mon Nov 12, 2012 10:16 am
i selected "none" on compression but it didn't work...no video...
Post Mon Nov 12, 2012 12:25 pm
- Could you enable serviio detailed logging (see signature)? post log here.
- Could you remux in MPEGTS output with mkvmerge tools and try to play it ?
carlocaloy31
Post Mon Nov 19, 2012 11:25 am
what is this???? where i can find this???
sorry...im not familiar with this...
Post Mon Nov 19, 2012 5:13 pm
carlocaloy31 wrote:serviio detailed logging (see signature)
Do you see my signature links on the bottom of this current message ? (HowTo: Turn on detailed logging)
carlocaloy31
Post Wed Nov 21, 2012 11:41 am
ahhh ok...the link shows that i should change
<category name="org.serviio">
<priority value="INFO"/>
</category>
TO
<priority value="DEBUG"/>
</category>
what is the purpose of this???
Post Wed Nov 21, 2012 11:03 pm
carlocaloy31 wrote:ahhh ok...the link shows that i should change
</category>
TO
</category>
It makes a far more detailed log, with information necessary for these smart people to assist you. Also be aware it makes the log file grow very large in a hurry, so unless you have a large amount of empty drive space I would suggest you only enable the debug long enough to gather the necessary information.
