Using the intel Upnp tools and wireshark to diagnose issues
ginjaninja
Post Sun Nov 11, 2012 2:47 pm
Hi all,
i have a couple of niggles and an opportunity when using serviio with my samsung es7000.
Niggle 1 - The renderer will only sort alphabetically on dc:title unless using the samsung allshare server. When using allshare server upnp:originalTrackNumber is used to order the tracks
Niggle 2 - Music Album art is low resolution compared to alternative servers.
Niggle 3 - Music Date is not shown on TVUI when using serviio compared to samsung allshare server whichs shows ID3tag 'YEAR' (as is best). but there is no date variable shown in AV media controller for either samsung or serviio. How might i determine where date on TV UI is coming from when using samsung allshare?.
Opportunity 1 - Exposing the enhanced tv functionality when using serviio that is possible when using samsung allshare server.
Music is fully tagged and in folder structure d:\music\albumartist\(Year) Album Name\TrackNumber. Title
Picture showing niggles
Niggle 1
In by folder view, serviio makes dc:title=filesystem filename, so i get a track order in this view on tv.
in by id3tag views, serviio makes dc:title=id3tag title, so i get no track order on tv.
picture showing track order ( on by folder view only).
no track order on metadat views.
is there a way to either make the tv think the serviio is samsung allshare server (pls see opprtunity)? or
make serviio make dc:title=filename in all music views.
Niggle 2
On Serviio upnp:AlbumartURI is the same as upnp:icon and low res
on servers with high resolution albumart, upnp:AlbumartiURi has different value and target with a higher resolution.
Image,
albumart art shows up in high res with other servers, could serviio reference a higher resolution target.
Niggle 3
dc:date on tracks in serviio is coming from filesystem 'date modified/created'....how could i tell what upnp method, the renderer is using for the date UI..samsung tv is showing the mp3 'year' id3 tag (so its coming from somewhere).
but there is no value in av media controller that could account for the tv knowing the 'date'.
what upnp tool could i use to see how the tv gets date value
**no date value, in samsung server, and yet the mp3 id3tag year is shown on tv ui
**no date value on extended 'properties', in samsung server, and yet the mp3 id3tag year is shown on tv ui
Opportunity 1
When the TV Is talking to the samsung dlna server it has enhanced functionality around 'view by' and structuring results into groups that can be collapsed / expanded.
Might serviio configuration allow serviio to provide this enhanced functionality?
Maybe the attributes on last image are relevant?
ginjaninja
Post Sun Nov 11, 2012 8:46 pm
Re: Using the intel Upnp tools and wireshark to diagnose is
HTTP/1.1 200 OK
Content-Length: 1964
Content-Type: text/xml; charset="utf-8"
DATE: Sun, 11 Nov 2012 20:27:31 GMT
EXT:
SERVER: UPnP/1.0
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<s:Body>
<u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory">
<Result><DIDL-Lite xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&quot;
 xmlns:sec=&quot;http://www.sec.co.kr/dlna&quot;
 xmlns:dlna=&quot;urn:schemas-dlna-org:metadata-1-0/&quot;
 xmlns:dc=&quot;http://purl.org/dc/elements/1.1/&quot;
 xmlns:upnp=&quot;urn:schemas-upnp-org:metadata-1-0/upnp/&quot;
<item id=&quot;133&quot; parentID=&quot;127&quot; restricted=&quot;0&quot;><res bitrate=&quot;140000&quot; duration=&quot;00:04:28&quot; size=&quot;4711023&quot; protocolInfo=&quot;http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000&quot;>http://192.168.4.53:17679/FileProvider/M$268000/O$1/S$/P$MP3/I$audio/mpeg/133</res><upnp:originalTrackNumber>6</upnp:originalTrackNumber><upnp:album>One Cell in the Sea</upnp:album><upnp:genre>Alternative</upnp:genre><upnp:playbackCount>0</upnp:playbackCount><upnp:artist>A Fine Frenzy</upnp:artist><sec:dcmInfo>MOODSCORE=0,MOODID=5,CREATIONDATE=1342166861,YEAR=2012</sec:dcmInfo><sec:modifiationDate>2012-07-13T08:07:41</sec:modifiationDate><sec:preference>0</sec:preference><sec:composer>Alison Sudol</sec:composer><dc:date>2012-07-13T09:07:41</dc:date><upnp:class>object.item.audioItem</upnp:class><dc:title>Almost Lover</dc:title><upnp:objectUpdateID>67</upnp:objectUpdateID><sec:initUpdateID>67</sec:initUpdateID></item>
</DIDL-Lite></Result>
<NumberReturned>1</NumberReturned>
<TotalMatches>15</TotalMatches>
<UpdateID>3451</UpdateID>
</u:BrowseResponse>
</s:Body>
</s:Envelope>
This is the output when the tv requests the track data via the samsung software.
the tag sec:dcminfo is used to transmit the year.
a similar packet for serviio did not contain this info....so although its not clear where the date is stored, it seems to be transmitted by <sec:dcmInfo>...anyone know what this means? or more importantly how to make use of this to build a serviio profile to communicate track dates (years) to the tv?
Post Sun Nov 11, 2012 11:54 pm
Serviio already pretends it's AllShare for some functionality (eg subtitles). I don't think it's a problem to send the year, will look into it.
Track number - it looks like a problem with the TV, ignoring the track sent. Does it sort correctly with the other server?
HIgh-res icon - DLNA spec states max 160x160 for albumArtUrl. I could send higher res, but then I'd have to store both, hi-res and lo-res resources in the library DB (for the other renderers), which would increase it's size considerably and probably lower performace. Will leave it as it is for now.
ginjaninja
Post Mon Nov 12, 2012 8:23 am
zip wrote:Serviio already pretends it's AllShare for some functionality (eg subtitles). I don't think it's a problem to send the year, will look into it.
Thanks Zip,
re: track order.
I think it is a problem with the TV as well...do you know of a Samsung contact/forum to feedback Samsung issues?
The Samsung allshare server is the only dlna server which allows for proper track order on the tv.
I understand there is a concept of sort and search of dlna but am not informed about it.
An option in the serviio interface/config* which allows dc:title to be filename rather than {title} id3tag might be a simple workaround? what do you think? looking on the internet, music track order issues are not limited to my setup. music track order is a big problem and the issue renders metadata views unusable (on my samsung tv es7000 at least, but i suspect a wider gamut).
could i manually change dc:title in the serviio database with a script or something?
re: albumart resolution.
FWIW serviio is alone in not providing high resolution albumart (against the others i have tested). My music library is 50,000 tracks but the additional metadata is not significant against the size of modern SSDs.
If the tv handled high res for upnp:icon as well (so the two image types could be as one) would that influence you? eg a option to set the max image resolution.
This issue causes a significant aesthetic downgrade compared to other servers.
re: music date
thanks for taking a look.
For my general dlna troubleshooting learning, please could you advise which tool shows how the year value is stored and communicated (rather than resort to wireshark)
re: allshare impersonation.
Might it be possible (by my configuration, or by development request) to build out the impersonation to include presenting the 'view button' as shown on tv images. Or would that be a massive propriety undertaking?
Very happy to do the wireshark/testing gruntwork if that would help.
thank you.
Post Mon Nov 12, 2012 11:29 pm
I do not. On my B and C series Samsungs it renders properly.
You can edit the Apache DB files in library folder.
Add a Bitbucket ticket and I'll see what can be done.
Wireshark is the best. Last time I checked the AllShare server also had a decent log file that included some of this information.
It's very proprietary solution. I think some of the functionality also required knowledge of AllShare insides and wasn't easy/possible to fake without decompiling the AllShare server.
ginjaninja
Post Tue Nov 13, 2012 8:46 am
zip wrote:I do not. On my B and C series Samsungs it renders properly.
Zip
thanks for feedback.
just to clarify ...do you think track order on this tv (samsung es 7000) ...is an issue that serviio could resolve?
if so is it for me to tinker with profiles..or for me to investigate with wireshark something more thoroughly...or is it a development issue?
thanks
Post Tue Nov 13, 2012 4:15 pm
Maybe they need an attribute similar to the YEAR you found, so if you can figure out how to pass it, then I'd implement it.
ginjaninja
Post Tue Nov 13, 2012 4:55 pm
zip wrote:Maybe they need an attribute similar to the YEAR you found, so if you can figure out how to pass it, then I'd implement it.
challenge accepted.
It is frustrating that the Samsung is the only renderer that doesn't treat track order in a normal way...everything else ive tested does (xbox, pc, galaxy tab)..it should be the simplest thing in the world for Samsung to have implemented for music over dlna...pretty shocking.... and pretty shocking on myself not to have picked this up in testing before i bought it...i will investigate the mechanism by which it works.
At this point i am assuming it is using the normal tag upnp:OriginalTrackNumber, but its only affecting the sort order when seen along with some of the propriety gubbins the allshare service communicates. So it might be too propriety to fix for the reasons you mention. Maybe switching dc:title to filename will be the quickest workaround for this tv...but i haven't given up.
thanks
ginjaninja
Post Tue Nov 13, 2012 8:47 pm
POST /smp_11_ HTTP/1.1
Accept: */*
User-Agent: SEC_HHP_[TV]UE46ES7000/1.0 DLNADOC/1.50
Host: 192.168.4.53:17676
SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
CONTENT-TYPE:  text/xml; charset="utf-8"
Content-Length: 454
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>A_L</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>*</Filter><StartingIndex>0</StartingIndex><RequestedCount>30</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>HTTP/1.1 200 OK
Content-Length: 6062
DATE: Tue, 13 Nov 2012 20:25:38 GMT
EXT:
SERVER: UPnP/1.0
Connection: close
<s:Body>
<Result><DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"
 xmlns:sec="http://www.sec.co.kr/dlna"
 xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/"
 xmlns:dc="http://purl.org/dc/elements/1.1/"
 xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/"
<container id="A_L_0003" parentID="A_L" childCount="14" restricted="1"><dc:title>ABBA</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0010" parentID="A_L" childCount="19" restricted="1"><dc:title>ABBA Gold (Greatest Hits)</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0009" parentID="A_L" childCount="14" restricted="1"><dc:title>ABBA Live</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0004" parentID="A_L" childCount="15" restricted="1"><dc:title>Arrival</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0011" parentID="A_L" childCount="20" restricted="1"><dc:title>More Abba Gold (More Abba Hits)</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0021" parentID="A_L" childCount="11" restricted="1"><dc:title>Rarities</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0001" parentID="A_L" childCount="19" restricted="1"><dc:title>Ring Ring</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0007" parentID="A_L" childCount="13" restricted="1"><dc:title>Super Trouper</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0000" parentID="A_L" childCount="28" restricted="1"><dc:title>TestAlbumName</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0012" parentID="A_L" childCount="20" restricted="1"><dc:title>Thank You For The Music (CD 1)</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0013" parentID="A_L" childCount="15" restricted="1"><dc:title>Thank You For The Music (CD 2)</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0014" parentID="A_L" childCount="15" restricted="1"><dc:title>Thank You For The Music (CD 3)</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0015" parentID="A_L" childCount="11" restricted="1"><dc:title>Thank You For The Music (CD 4)</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0005" parentID="A_L" childCount="11" restricted="1"><dc:title>The Album</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0016" parentID="A_L" childCount="17" restricted="1"><dc:title>The Complete Singles Collection (CD 1)</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0018" parentID="A_L" childCount="15" restricted="1"><dc:title>The Complete Singles Collection (CD 2)</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0017" parentID="A_L" childCount="1" restricted="1"><dc:title>The Complete Singles Collection (Cd 1)</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0019" parentID="A_L" childCount="20" restricted="1"><dc:title>The Definitive Collection (CD 1)</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0020" parentID="A_L" childCount="17" restricted="1"><dc:title>The Definitive Collection (CD 2)</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0008" parentID="A_L" childCount="16" restricted="1"><dc:title>The Visitors</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0006" parentID="A_L" childCount="16" restricted="1"><dc:title>Voulez-Vous</dc:title><upnp:class>object.container</upnp:class></container><container id="A_L_0002" parentID="A_L" childCount="18" restricted="1"><dc:title>Waterloo</dc:title><upnp:class>object.container</upnp:class></container></DIDL-Lite></Result>
<NumberReturned>22</NumberReturned>
<TotalMatches>22</TotalMatches>
<UpdateID>4639</UpdateID>
</u:BrowseResponse>
</s:Body>
</s:Envelope>
Output of conversation between TV and Samsung All share when the tv is configured for view by album mode and a view of the music folder is requested.
Points to note
Each album is given an ID "A_L_XXX", with parentID="A_L" and the 'childcount' defines the number of tracks on the album.
Albums have <upnp:class>object.container
tracks within the albums (when the albums are expanded) are sorted "well"
Accept: */*
Content-Length: 458
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>A_L_0003</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>*</Filter><StartingIndex>2</StartingIndex><RequestedCount>1</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>HTTP/1.1 200 OK
Content-Length: 1749
EXT:
SERVER: UPnP/1.0
Connection: close
<s:Body>
<item id="A_L_0003_1983" parentID="A_L_0003" restricted="1"><res duration="00:03:05" size="21967658" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000">http://192.168.4.53:17679/FileProvider/M$185000/O$1/S$/P$/I$audio/x-flac/4567</res><upnp:originalTrackNumber>3</upnp:originalTrackNumber><upnp:album>ABBA</upnp:album><upnp:genre>Pop</upnp:genre><upnp:playbackCount>0</upnp:playbackCount><upnp:artist>ABBA</upnp:artist><sec:dcmInfo>MOODSCORE=0,MOODID=5,CREATIONDATE=1325517477,YEAR=2012</sec:dcmInfo><sec:modifiationDate>2012-01-02T15:17:57</sec:modifiationDate><sec:preference>0</sec:preference><dc:date>2012-01-02T15:17:57</dc:date><upnp:class>object.item.audioItem</upnp:class><dc:title>Tropical Loveland</dc:title></item></DIDL-Lite></Result>
<TotalMatches>14</TotalMatches>
</u:BrowseResponse>
</s:Body>
</s:Envelope>
Accept: */*
Content-Length: 458
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>A_L_0003</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>*</Filter><StartingIndex>4</StartingIndex><RequestedCount>1</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>HTTP/1.1 200 OK
EXT:
SERVER: UPnP/1.0
Connection: close
<s:Body>
<item id="A_L_0003_1985" parentID="A_L_0003" restricted="1"><res duration="00:03:01" size="21538185" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000">http://192.168.4.53:17679/FileProvider/M$181000/O$1/S$/P$/I$audio/x-flac/4569</res><upnp:originalTrackNumber>5</upnp:originalTrackNumber><upnp:album>ABBA</upnp:album><upnp:genre>Pop</upnp:genre><upnp:playbackCount>0</upnp:playbackCount><upnp:artist>ABBA</upnp:artist><sec:dcmInfo>MOODSCORE=0,MOODID=5,CREATIONDATE=1325517477,YEAR=2012</sec:dcmInfo><sec:modifiationDate>2012-01-02T15:17:57</sec:modifiationDate><sec:preference>0</sec:preference><dc:date>2012-01-02T15:17:57</dc:date><upnp:class>object.item.audioItem</upnp:class><dc:title>Man in the Middle</dc:title></item></DIDL-Lite></Result>
</u:BrowseResponse>
</s:Body>
</s:Envelope>
Data included about a couple of tracks within container (album) A_L_003 when in the same view mode, by album.
Column 1 in view is dc:title and column 2 in view is upnp:Artist
ginjaninja
Post Tue Nov 13, 2012 9:23 pm
Accept: */*
SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#X_GetFeatureList"
Content-Length: 291
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:X_GetFeatureList xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"></u:X_GetFeatureList></s:Body></s:Envelope>HTTP/1.1 200 OK
Content-Length: 2417
DATE: Tue, 13 Nov 2012 21:07:44 GMT
EXT:
SERVER: UPnP/1.0
Connection: close
<s:Body>
<u:X_GetFeatureListResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory">
<FeatureList><?xml version="1.0" encoding="UTF-8"?><Features xmlns="urn:schemas-upnp-org:av:avs" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:schemas-upnp-org:av:avs http://www.upnp.org/schemas/av/avs.xsd"><Feature name="samsung.com_BASICVIEW" version="2"><container id="1" type="object.item.imageItem"/><container id="1" type="object.item.audioItem"/><container id="1" type="object.item.videoItem"/><container id="1" type="object.item.textItem"/></Feature><Feature name="samsung.com_DCMVIEW" version="1"><container id="I_M" type="IMAGE_Monthly"/><container id="I_C" type="IMAGE_Color"/><container id="I_T" type="IMAGE_Timeline"/><container id="I_P" type="IMAGE_Composition"/><container id="I_F" type="IMAGE_Folder"/><container id="I_N" type="IMAGE_Title"/><container id="I_L" type="IMAGE_LatestDate"/><container id="I_E" type="IMAGE_EarliestDate"/><container id="A_G" type="AUDIO_Genre"/><container id="A_A" type="AUDIO_Artist"/><container id="A_F" type="AUDIO_Folder"/><container id="A_M" type="AUDIO_Mood"/><container id="A_T" type="AUDIO_Title"/><container id="A_L" type="AUDIO_Album"/><container id="V_T" type="VIDEO_Title"/><container id="V_D" type="VIDEO_Date"/><container id="V_F" type="VIDEO_Folder"/><container id="V_L" type="VIDEO_LatestDate"/><container id="V_E" type="VIDEO_EarliestDate"/></Feature></Features></FeatureList>
</u:X_GetFeatureListResponse>
</s:Body>
</s:Envelope>
TV asking DLNA service (Allshare) for its feature list.
The Container IDs "A_...." pertain to views on audio on tv when using samsung software.G=Genre,A=Artist,F=Folder,M=Mood (incidently view by mood is not exposed yet on the tv ui),T=Title,L=Album
Two Features
name=samsung.com_BASICVIEW and name=samsung.com_DCMVIEW
samsung.com_BASICVIEW feature lists four container types
and presumably pertains to when tv is not talking to samsung allshare ?
samsung.com_DCMVIEW has a 'complete' set of container types one of which is the view by album in post above.
ginjaninja
Post Tue Nov 13, 2012 9:38 pm
Accept: */*
Content-Length: 454
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>A_A</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>*</Filter><StartingIndex>0</StartingIndex><RequestedCount>30</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>HTTP/1.1 200 OK
Content-Length: 1199
EXT:
SERVER: UPnP/1.0
Connection: close
<s:Body>
<container id="A_A_0001" parentID="A_A" childCount="317" restricted="1"><dc:title>ABBA</dc:title><upnp:class>object.container</upnp:class></container><container id="A_A_0000" parentID="A_A" childCount="28" restricted="1"><dc:title>TestArtist</dc:title><upnp:class>object.container</upnp:class></container></DIDL-Lite></Result>
<NumberReturned>2</NumberReturned>
<TotalMatches>2</TotalMatches>
</u:BrowseResponse>
</s:Body>
</s:Envelope>
Browsing music when the view is set to 'by artist',
presuming the GetFeatureList has established the TV is talking to a service which supports samsung.com_DCMVIEW (ie samsung allsahre)
each artist has a container ID, The artist abba has 317 tracks, dc:title defines the groupings (in this case two abba and testartist)
ginjaninja
Post Tue Nov 13, 2012 9:58 pm
Accept: */*
Content-Length: 458
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>A_A_0001</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>*</Filter><StartingIndex>0</StartingIndex><RequestedCount>1</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>HTTP/1.1 200 OK
Content-Length: 1747
EXT:
SERVER: UPnP/1.0
Connection: close
<s:Body>
<item id="A_A_0001_1940" parentID="A_A_0001" restricted="1"><res duration="00:03:04" size="23614010" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000">http://192.168.4.53:17679/FileProvider/M$184000/O$1/S$/P$/I$audio/x-flac/4520</res><upnp:originalTrackNumber>1</upnp:originalTrackNumber><upnp:album>Ring Ring</upnp:album><upnp:genre>Pop</upnp:genre><upnp:playbackCount>0</upnp:playbackCount><upnp:artist>ABBA</upnp:artist><sec:dcmInfo>MOODSCORE=0,MOODID=5,CREATIONDATE=1325517476,YEAR=2012</sec:dcmInfo><sec:modifiationDate>2012-01-02T15:17:56</sec:modifiationDate><sec:preference>0</sec:preference><dc:date>2012-01-02T15:17:56</dc:date><upnp:class>object.item.audioItem</upnp:class><dc:title>Ring Ring</dc:title></item></DIDL-Lite></Result>
<TotalMatches>317</TotalMatches>
</u:BrowseResponse>
</s:Body>
</s:Envelope>
now that the containers are defined. the contents (tracks) are communicated.
This is the first content (track)on the first container (artist).
In the 'By Artist' view containers are artists.
the contents of the containers are tracks (the contents of containers are tracks in all views)
When the container (artist) is expanded the 1st column is dc:title and 2nd column is upnp:album...These views are very functional/useful.
Accept: */*
Content-Length: 458
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>A_A_0001</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>*</Filter><StartingIndex>1</StartingIndex><RequestedCount>1</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>HTTP/1.1 200 OK
Content-Length: 1764
DATE: Tue, 13 Nov 2012 21:07:46 GMT
EXT:
SERVER: UPnP/1.0
Connection: close
<s:Body>
<item id="A_A_0001_1941" parentID="A_A_0001" restricted="1"><res duration="00:03:12" size="24048377" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000">http://192.168.4.53:17679/FileProvider/M$192000/O$1/S$/P$/I$audio/x-flac/4521</res><upnp:originalTrackNumber>2</upnp:originalTrackNumber><upnp:album>Ring Ring</upnp:album><upnp:genre>Pop</upnp:genre><upnp:playbackCount>0</upnp:playbackCount><upnp:artist>ABBA</upnp:artist><sec:dcmInfo>MOODSCORE=0,MOODID=5,CREATIONDATE=1325517476,YEAR=2012</sec:dcmInfo><sec:modifiationDate>2012-01-02T15:17:56</sec:modifiationDate><sec:preference>0</sec:preference><dc:date>2012-01-02T15:17:56</dc:date><upnp:class>object.item.audioItem</upnp:class><dc:title>Another Town Another Train</dc:title></item></DIDL-Lite></Result>
</u:BrowseResponse>
</s:Body>
</s:Envelope>
This is the second content (track) in the first container (artist).
The content of the artist is orderered by track and by album. All of the 1st album appears first (ordered by track) and then all the 2nd etc.
perhaps the containers are the equivalent of normal serviio folders...Its just when in DCMVIEW mode, the samsung tv just presents containers as groups which can be expanded and collapsed on screen, as opposed to folders that can be browsed into.
Accept: */*
Content-Length: 460
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>A_A_0001</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>*</Filter><StartingIndex>316</StartingIndex><RequestedCount>1</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>HTTP/1.1 200 OK
Content-Length: 1775
DATE: Tue, 13 Nov 2012 22:06:21 GMT
EXT:
SERVER: UPnP/1.0
Connection: close
<s:Body>
<item id="A_A_0001_2300" parentID="A_A_0001" restricted="1"><res duration="00:23:28" size="167357394" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000">http://192.168.4.53:17679/FileProvider/M$1408000/O$1/S$/P$/I$audio/x-flac/4924</res><upnp:originalTrackNumber>11</upnp:originalTrackNumber><upnp:album>Rarities</upnp:album><upnp:genre>Pop</upnp:genre><upnp:playbackCount>0</upnp:playbackCount><upnp:artist>ABBA</upnp:artist><sec:dcmInfo>MOODSCORE=0,MOODID=5,CREATIONDATE=1325517477,YEAR=2012</sec:dcmInfo><sec:modifiationDate>2012-01-02T15:17:57</sec:modifiationDate><sec:preference>0</sec:preference><dc:date>2012-01-02T15:17:57</dc:date><upnp:class>object.item.audioItem</upnp:class><dc:title>ABBA Undeleted (Medley of Outtakes)</dc:title></item></DIDL-Lite></Result>
</u:BrowseResponse>
</s:Body>
</s:Envelope>
This is the last track in the 1st container
tracks have upnp:class object.item.audioItem, which i guess is normal.
ginjaninja
Post Tue Nov 13, 2012 10:43 pm
Dont know how normal all this is,
I am guessing the TV is deciding on how to order based on internal logic that the TV chooses not to apply to serviio...because of the getfeaturelist?.
swapping wireshark to Serviio
POST /serviceControl HTTP/1.1
Accept: */*
Host: 169.254.26.244:8895
Content-Length: 291
Connection: close
EXT:
Date: Tue, 13 Nov 2012 22:21:55 GMT
Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1
Content-Length: 867
Connection: close
<?xml version="1.0" encoding="utf-8" ?><SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><u:X_GetFeatureListResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><FeatureList><?xml version="1.0" encoding="UTF-8"?><Features xmlns="urn:schemas-upnp-org:av:avs" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation=" urn:schemas-upnp-org:av:avs http://www.upnp.org/schemas/av/avs.xsd"><Feature name="samsung.com_BASICVIEW" version="1"><container id="I" type="object.item.imageItem"/><container id="A" type="object.item.audioItem"/><container id="V" type="object.item.videoItem"/></Feature></Features></FeatureList></u:X_GetFeatureListResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
getfeaturelist when talking to serviio.....no DCMVIEW
Accept: */*
Content-Length: 451
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>A</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>*</Filter><StartingIndex>0</StartingIndex><RequestedCount>1</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>HTTP/1.1 200 OK
EXT:
Content-Length: 957
Connection: close
<?xml version="1.0" encoding="utf-8" ?><SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><?xml version="1.0" encoding="UTF-8" standalone="no"?><DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" xmlns:sec="http://www.sec.co.kr/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/"><container childCount="40" id="A_A" parentID="A" restricted="1" searchable="0"><dc:title>Artists</dc:title><upnp:class>object.container</upnp:class></container></DIDL-Lite></Result><NumberReturned>1</NumberReturned><TotalMatches>6</TotalMatches><UpdateID>30</UpdateID></u:BrowseResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
Accept: */*
Content-Length: 452
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>A</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>*</Filter><StartingIndex>0</StartingIndex><RequestedCount>30</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>HTTP/1.1 200 OK
EXT:
Content-Length: 1944
Connection: close
<?xml version="1.0" encoding="utf-8" ?><SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><?xml version="1.0" encoding="UTF-8" standalone="no"?><DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" xmlns:sec="http://www.sec.co.kr/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/"><container childCount="40" id="A_A" parentID="A" restricted="1" searchable="0"><dc:title>Artists</dc:title><upnp:class>object.container</upnp:class></container><container childCount="25" id="AL_A" parentID="A" restricted="1" searchable="0"><dc:title>Album Artists</dc:title><upnp:class>object.container</upnp:class></container><container childCount="1" id="A_F" parentID="A" restricted="1" searchable="0"><dc:title>Folders</dc:title><upnp:class>object.container</upnp:class></container><container childCount="113" id="A_G" parentID="A" restricted="1" searchable="0"><dc:title>Genres</dc:title><upnp:class>object.container</upnp:class></container><container childCount="0" id="A_PL" parentID="A" restricted="1" searchable="0"><dc:title>Playlists</dc:title><upnp:class>object.container</upnp:class></container><container childCount="4" id="A_OF" parentID="A" restricted="1" searchable="0"><dc:title>Online</dc:title><upnp:class>object.container</upnp:class></container></DIDL-Lite></Result><NumberReturned>6</NumberReturned><TotalMatches>6</TotalMatches><UpdateID>30</UpdateID></u:BrowseResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
servvio presents its music views (containers) to TV
incidently dc:titles are not ordered in relation to where they appear in the list, but alphabetically. I think the TV is deciding on how to sort the views.
Accept: */*
Content-Length: 454
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>AL_A</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>*</Filter><StartingIndex>0</StartingIndex><RequestedCount>1</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>HTTP/1.1 200 OK
EXT:
Date: Tue, 13 Nov 2012 22:22:00 GMT
Content-Length: 963
Connection: close
<?xml version="1.0" encoding="utf-8" ?><SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><?xml version="1.0" encoding="UTF-8" standalone="no"?><DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" xmlns:sec="http://www.sec.co.kr/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/"><container childCount="33" id="AL_A^INI_65" parentID="AL_A" restricted="1" searchable="0"><dc:title>A</dc:title><upnp:class>object.container</upnp:class></container></DIDL-Lite></Result><NumberReturned>1</NumberReturned><TotalMatches>25</TotalMatches><UpdateID>30</UpdateID></u:BrowseResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
Albumartist - 'A'
Accept: */*
Content-Length: 462
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>AL_A^INI_65</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>*</Filter><StartingIndex>0</StartingIndex><RequestedCount>30</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>HTTP/1.1 200 OK
EXT:
Date: Tue, 13 Nov 2012 22:22:05 GMT
Content-Length: 8198
Connection: close
<?xml version="1.0" encoding="utf-8" ?><SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><?xml version="1.0" encoding="UTF-8" standalone="no"?><DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" xmlns:sec="http://www.sec.co.kr/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/"><container childCount="1" id="AL_A^INI_65^ART_7635" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>A-Ha</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="21" id="AL_A^INI_65^ART_7641" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>ABBA</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="1" id="AL_A^INI_65^ART_7650" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>AC/DC</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="1" id="AL_A^INI_65^ART_7652" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Ace of Base</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="1" id="AL_A^INI_65^ART_19661" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Adam Clayton &amp;amp; Larry Mullen</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="3" id="AL_A^INI_65^ART_7531" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Adele</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="2" id="AL_A^INI_65^ART_7659" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Aerosmith</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="7" id="AL_A^INI_65^ART_7668" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Air</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="1" id="AL_A^INI_65^ART_7682" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Al Green</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="2" id="AL_A^INI_65^ART_17574" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Alain Boublil &amp;amp; Claude-Michel Schonberg</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="12" id="AL_A^INI_65^ART_5410" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Alanis Morissette</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="1" id="AL_A^INI_65^ART_7693" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Alesha Dixon</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="3" id="AL_A^INI_65^ART_7694" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Alexi Murdoch</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="5" id="AL_A^INI_65^ART_7695" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Alice Cooper</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="2" id="AL_A^INI_65^ART_7696" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Alice In Chains</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="6" id="AL_A^INI_65^ART_7706" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Alicia Keys</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="13" id="AL_A^INI_65^ART_7739" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Alison Krauss</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="1" id="AL_A^INI_65^ART_7837" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Alison Moyet</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="1" id="AL_A^INI_65^ART_7850" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>The Allman Brothers Band</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="2" id="AL_A^INI_65^ART_7851" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Amy Winehouse</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="2" id="AL_A^INI_65^ART_17571" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Andersson, Rice, Ulvaeus</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="4" id="AL_A^INI_65^ART_17572" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Andrew Lloyd Webber</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="1" id="AL_A^INI_65^ART_4213" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Angelo Badalamenti</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="1" id="AL_A^INI_65^ART_7577" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Annie Lennox</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="1" id="AL_A^INI_65^ART_9052" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Antonio Vivaldi</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="1" id="AL_A^INI_65^ART_7863" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Aqua</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="4" id="AL_A^INI_65^ART_7870" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Arcade Fire</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="3" id="AL_A^INI_65^ART_7871" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Arctic Monkeys</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="1" id="AL_A^INI_65^ART_7569" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Aretha Franklin</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container><container childCount="2" id="AL_A^INI_65^ART_7873" parentID="AL_A^INI_65" restricted="1" searchable="0"><dc:title>Ash</dc:title><upnp:class>object.container.person.musicArtist</upnp:class></container></DIDL-Lite></Result><NumberReturned>30</NumberReturned><TotalMatches>33</TotalMatches><UpdateID>30</UpdateID></u:BrowseResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
all the A's
ginjaninja
Post Tue Nov 13, 2012 10:44 pm
Finally get down to artist called abba...album called abba...with serviio
Accept: */*
Content-Length: 475
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>AL_A^INI_65^ART_7641^A_6</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>*</Filter><StartingIndex>0</StartingIndex><RequestedCount>30</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>HTTP/1.1 200 OK
EXT:
Date: Tue, 13 Nov 2012 22:22:15 GMT
Content-Length: 18576
Connection: close
<?xml version="1.0" encoding="utf-8" ?><SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><?xml version="1.0" encoding="UTF-8" standalone="no"?><DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" xmlns:sec="http://www.sec.co.kr/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/"><item id="AL_A^INI_65^ART_7641^A_6^S_1044" parentID="AL_A^INI_65^ART_7641^A_6" restricted="1"><dc:title>Mamma Mia</dc:title><upnp:class>object.item.audioItem.musicTrack</upnp:class><dc:creator>ABBA</dc:creator><upnp:albumArtURI dlna:profileID="JPEG_TN">http://169.254.26.244:8895/resource/1044/COVER_IMAGE</upnp:albumArtURI><upnp:originalTrackNumber>1</upnp:originalTrackNumber><upnp:icon>http://169.254.26.244:8895/resource/1044/COVER_IMAGE</upnp:icon><upnp:album>ABBA</upnp:album><dc:date>2012-01-02</dc:date><upnp:genre>Pop</upnp:genre><upnp:artist>ABBA</upnp:artist><res bitrate="116500" duration="0:03:31.000" nrAudioChannels="2" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000" sampleFrequency="44100" size="24699913">http://169.254.26.244:8895/resource/1044/MEDIA_ITEM/FLAC-0/ORIGINAL</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000" resolution="160x157">http://169.254.26.244:8895/resource/1044/COVER_IMAGE</res></item><item id="AL_A^INI_65^ART_7641^A_6^S_1045" parentID="AL_A^INI_65^ART_7641^A_6" restricted="1"><dc:title>Hey Hey Helen</dc:title><upnp:class>object.item.audioItem.musicTrack</upnp:class><dc:creator>ABBA</dc:creator><upnp:albumArtURI dlna:profileID="JPEG_TN">http://169.254.26.244:8895/resource/1045/COVER_IMAGE</upnp:albumArtURI><upnp:originalTrackNumber>2</upnp:originalTrackNumber><upnp:icon>http://169.254.26.244:8895/resource/1045/COVER_IMAGE</upnp:icon><upnp:album>ABBA</upnp:album><dc:date>2012-01-02</dc:date><upnp:genre>Pop</upnp:genre><upnp:artist>ABBA</upnp:artist><res bitrate="122125" duration="0:03:16.000" nrAudioChannels="2" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000" sampleFrequency="44100" size="23985709">http://169.254.26.244:8895/resource/1045/MEDIA_ITEM/FLAC-0/ORIGINAL</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000" resolution="160x157">http://169.254.26.244:8895/resource/1045/COVER_IMAGE</res></item><item id="AL_A^INI_65^ART_7641^A_6^S_1046" parentID="AL_A^INI_65^ART_7641^A_6" restricted="1"><dc:title>Tropical Loveland</dc:title><upnp:class>object.item.audioItem.musicTrack</upnp:class><dc:creator>ABBA</dc:creator><upnp:albumArtURI dlna:profileID="JPEG_TN">http://169.254.26.244:8895/resource/1046/COVER_IMAGE</upnp:albumArtURI><upnp:originalTrackNumber>3</upnp:originalTrackNumber><upnp:icon>http://169.254.26.244:8895/resource/1046/COVER_IMAGE</upnp:icon><upnp:album>ABBA</upnp:album><dc:date>2012-01-02</dc:date><upnp:genre>Pop</upnp:genre><upnp:artist>ABBA</upnp:artist><res bitrate="118500" duration="0:03:05.000" nrAudioChannels="2" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000" sampleFrequency="44100" size="21967658">http://169.254.26.244:8895/resource/1046/MEDIA_ITEM/FLAC-0/ORIGINAL</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000" resolution="160x157">http://169.254.26.244:8895/resource/1046/COVER_IMAGE</res></item><item id="AL_A^INI_65^ART_7641^A_6^S_1047" parentID="AL_A^INI_65^ART_7641^A_6" restricted="1"><dc:title>SOS</dc:title><upnp:class>object.item.audioItem.musicTrack</upnp:class><dc:creator>ABBA</dc:creator><upnp:albumArtURI dlna:profileID="JPEG_TN">http://169.254.26.244:8895/resource/1047/COVER_IMAGE</upnp:albumArtURI><upnp:originalTrackNumber>4</upnp:originalTrackNumber><upnp:icon>http://169.254.26.244:8895/resource/1047/COVER_IMAGE</upnp:icon><upnp:album>ABBA</upnp:album><dc:date>2012-01-02</dc:date><upnp:genre>Pop</upnp:genre><upnp:artist>ABBA</upnp:artist><res bitrate="116750" duration="0:03:21.000" nrAudioChannels="2" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000" sampleFrequency="44100" size="23531766">http://169.254.26.244:8895/resource/1047/MEDIA_ITEM/FLAC-0/ORIGINAL</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000" resolution="160x157">http://169.254.26.244:8895/resource/1047/COVER_IMAGE</res></item><item id="AL_A^INI_65^ART_7641^A_6^S_1048" parentID="AL_A^INI_65^ART_7641^A_6" restricted="1"><dc:title>Man in the Middle</dc:title><upnp:class>object.item.audioItem.musicTrack</upnp:class><dc:creator>ABBA</dc:creator><upnp:albumArtURI dlna:profileID="JPEG_TN">http://169.254.26.244:8895/resource/1048/COVER_IMAGE</upnp:albumArtURI><upnp:originalTrackNumber>5</upnp:originalTrackNumber><upnp:icon>http://169.254.26.244:8895/resource/1048/COVER_IMAGE</upnp:icon><upnp:album>ABBA</upnp:album><dc:date>2012-01-02</dc:date><upnp:genre>Pop</upnp:genre><upnp:artist>ABBA</upnp:artist><res bitrate="118625" duration="0:03:01.000" nrAudioChannels="2" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000" sampleFrequency="44100" size="21538185">http://169.254.26.244:8895/resource/1048/MEDIA_ITEM/FLAC-0/ORIGINAL</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000" resolution="160x157">http://169.254.26.244:8895/resource/1048/COVER_IMAGE</res></item><item id="AL_A^INI_65^ART_7641^A_6^S_1049" parentID="AL_A^INI_65^ART_7641^A_6" restricted="1"><dc:title>Bang-A-Boomerang</dc:title><upnp:class>object.item.audioItem.musicTrack</upnp:class><dc:creator>ABBA</dc:creator><upnp:albumArtURI dlna:profileID="JPEG_TN">http://169.254.26.244:8895/resource/1049/COVER_IMAGE</upnp:albumArtURI><upnp:originalTrackNumber>6</upnp:originalTrackNumber><upnp:icon>http://169.254.26.244:8895/resource/1049/COVER_IMAGE</upnp:icon><upnp:album>ABBA</upnp:album><dc:date>2012-01-02</dc:date><upnp:genre>Pop</upnp:genre><upnp:artist>ABBA</upnp:artist><res bitrate="124125" duration="0:03:03.000" nrAudioChannels="2" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000" sampleFrequency="44100" size="22775784">http://169.254.26.244:8895/resource/1049/MEDIA_ITEM/FLAC-0/ORIGINAL</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000" resolution="160x157">http://169.254.26.244:8895/resource/1049/COVER_IMAGE</res></item><item id="AL_A^INI_65^ART_7641^A_6^S_1050" parentID="AL_A^INI_65^ART_7641^A_6" restricted="1"><dc:title>I Do I Do I Do I Do I Do</dc:title><upnp:class>object.item.audioItem.musicTrack</upnp:class><dc:creator>ABBA</dc:creator><upnp:albumArtURI dlna:profileID="JPEG_TN">http://169.254.26.244:8895/resource/1050/COVER_IMAGE</upnp:albumArtURI><upnp:originalTrackNumber>7</upnp:originalTrackNumber><upnp:icon>http://169.254.26.244:8895/resource/1050/COVER_IMAGE</upnp:icon><upnp:album>ABBA</upnp:album><dc:date>2012-01-02</dc:date><upnp:genre>Pop</upnp:genre><upnp:artist>ABBA</upnp:artist><res bitrate="124250" duration="0:03:15.000" nrAudioChannels="2" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000" sampleFrequency="44100" size="24313875">http://169.254.26.244:8895/resource/1050/MEDIA_ITEM/FLAC-0/ORIGINAL</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000" resolution="160x157">http://169.254.26.244:8895/resource/1050/COVER_IMAGE</res></item><item id="AL_A^INI_65^ART_7641^A_6^S_1051" parentID="AL_A^INI_65^ART_7641^A_6" restricted="1"><dc:title>Rock Me</dc:title><upnp:class>object.item.audioItem.musicTrack</upnp:class><dc:creator>ABBA</dc:creator><upnp:albumArtURI dlna:profileID="JPEG_TN">http://169.254.26.244:8895/resource/1051/COVER_IMAGE</upnp:albumArtURI><upnp:originalTrackNumber>8</upnp:originalTrackNumber><upnp:icon>http://169.254.26.244:8895/resource/1051/COVER_IMAGE</upnp:icon><upnp:album>ABBA</upnp:album><dc:date>2012-01-02</dc:date><upnp:genre>Pop</upnp:genre><upnp:artist>ABBA</upnp:artist><res bitrate="128500" duration="0:03:04.000" nrAudioChannels="2" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000" sampleFrequency="44100" size="23762366">http://169.254.26.244:8895/resource/1051/MEDIA_ITEM/FLAC-0/ORIGINAL</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000" resolution="160x157">http://169.254.26.244:8895/resource/1051/COVER_IMAGE</res></item><item id="AL_A^INI_65^ART_7641^A_6^S_1052" parentID="AL_A^INI_65^ART_7641^A_6" restricted="1"><dc:title>Intermezzo No1</dc:title><upnp:class>object.item.audioItem.musicTrack</upnp:class><dc:creator>ABBA</dc:creator><upnp:albumArtURI dlna:profileID="JPEG_TN">http://169.254.26.244:8895/resource/1052/COVER_IMAGE</upnp:albumArtURI><upnp:originalTrackNumber>9</upnp:originalTrackNumber><upnp:icon>http://169.254.26.244:8895/resource/1052/COVER_IMAGE</upnp:icon><upnp:album>ABBA</upnp:album><dc:date>2012-01-02</dc:date><upnp:genre>Pop</upnp:genre><upnp:artist>ABBA</upnp:artist><res bitrate="123250" duration="0:03:46.000" nrAudioChannels="2" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000" sampleFrequency="44100" size="27978783">http://169.254.26.244:8895/resource/1052/MEDIA_ITEM/FLAC-0/ORIGINAL</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000" resolution="160x157">http://169.254.26.244:8895/resource/1052/COVER_IMAGE</res></item><item id="AL_A^INI_65^ART_7641^A_6^S_1053" parentID="AL_A^INI_65^ART_7641^A_6" restricted="1"><dc:title>Ive Been Waiting for You</dc:title><upnp:class>object.item.audioItem.musicTrack</upnp:class><dc:creator>ABBA</dc:creator><upnp:albumArtURI dlna:profileID="JPEG_TN">http://169.254.26.244:8895/resource/1053/COVER_IMAGE</upnp:albumArtURI><upnp:originalTrackNumber>10</upnp:originalTrackNumber><upnp:icon>http://169.254.26.244:8895/resource/1053/COVER_IMAGE</upnp:icon><upnp:album>ABBA</upnp:album><dc:date>2012-01-02</dc:date><upnp:genre>Pop</upnp:genre><upnp:artist>ABBA</upnp:artist><res bitrate="128750" duration="0:03:40.000" nrAudioChannels="2" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000" sampleFrequency="44100" size="28410793">http://169.254.26.244:8895/resource/1053/MEDIA_ITEM/FLAC-0/ORIGINAL</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000" resolution="160x157">http://169.254.26.244:8895/resource/1053/COVER_IMAGE</res></item><item id="AL_A^INI_65^ART_7641^A_6^S_1054" parentID="AL_A^INI_65^ART_7641^A_6" restricted="1"><dc:title>So Long</dc:title><upnp:class>object.item.audioItem.musicTrack</upnp:class><dc:creator>ABBA</dc:creator><upnp:albumArtURI dlna:profileID="JPEG_TN">http://169.254.26.244:8895/resource/1054/COVER_IMAGE</upnp:albumArtURI><upnp:originalTrackNumber>11</upnp:originalTrackNumber><upnp:icon>http://169.254.26.244:8895/resource/1054/COVER_IMAGE</upnp:icon><upnp:album>ABBA</upnp:album><dc:date>2012-01-02</dc:date><upnp:genre>Pop</upnp:genre><upnp:artist>ABBA</upnp:artist><res bitrate="128375" duration="0:03:05.000" nrAudioChannels="2" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000" sampleFrequency="44100" size="23822035">http://169.254.26.244:8895/resource/1054/MEDIA_ITEM/FLAC-0/ORIGINAL</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000" resolution="160x157">http://169.254.26.244:8895/resource/1054/COVER_IMAGE</res></item><item id="AL_A^INI_65^ART_7641^A_6^S_1055" parentID="AL_A^INI_65^ART_7641^A_6" restricted="1"><dc:title>Crazy World</dc:title><upnp:class>object.item.audioItem.musicTrack</upnp:class><dc:creator>ABBA</dc:creator><upnp:albumArtURI dlna:profileID="JPEG_TN">http://169.254.26.244:8895/resource/1055/COVER_IMAGE</upnp:albumArtURI><upnp:originalTrackNumber>12</upnp:originalTrackNumber><upnp:icon>http://169.254.26.244:8895/resource/1055/COVER_IMAGE</upnp:icon><upnp:album>ABBA</upnp:album><dc:date>2012-01-02</dc:date><upnp:genre>Pop</upnp:genre><upnp:artist>ABBA</upnp:artist><res bitrate="119750" duration="0:03:45.000" nrAudioChannels="2" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000" sampleFrequency="44100" size="27012570">http://169.254.26.244:8895/resource/1055/MEDIA_ITEM/FLAC-0/ORIGINAL</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000" resolution="160x157">http://169.254.26.244:8895/resource/1055/COVER_IMAGE</res></item><item id="AL_A^INI_65^ART_7641^A_6^S_1056" parentID="AL_A^INI_65^ART_7641^A_6" restricted="1"><dc:title>Medley (Pick a Bale of Cotton - On Top of Old Smokey - Midnight Special (1978</dc:title><upnp:class>object.item.audioItem.musicTrack</upnp:class><dc:creator>ABBA</dc:creator><upnp:albumArtURI dlna:profileID="JPEG_TN">http://169.254.26.244:8895/resource/1056/COVER_IMAGE</upnp:albumArtURI><upnp:originalTrackNumber>13</upnp:originalTrackNumber><upnp:icon>http://169.254.26.244:8895/resource/1056/COVER_IMAGE</upnp:icon><upnp:album>ABBA</upnp:album><dc:date>2012-01-02</dc:date><upnp:genre>Pop</upnp:genre><upnp:artist>ABBA</upnp:artist><res bitrate="132500" duration="0:04:19.000" nrAudioChannels="2" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000" sampleFrequency="44100" size="34456778">http://169.254.26.244:8895/resource/1056/MEDIA_ITEM/FLAC-0/ORIGINAL</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000" resolution="160x157">http://169.254.26.244:8895/resource/1056/COVER_IMAGE</res></item><item id="AL_A^INI_65^ART_7641^A_6^S_1057" parentID="AL_A^INI_65^ART_7641^A_6" restricted="1"><dc:title>Mamma Mia (Spanish Version)</dc:title><upnp:class>object.item.audioItem.musicTrack</upnp:class><dc:creator>ABBA</dc:creator><upnp:albumArtURI dlna:profileID="JPEG_TN">http://169.254.26.244:8895/resource/1057/COVER_IMAGE</upnp:albumArtURI><upnp:originalTrackNumber>14</upnp:originalTrackNumber><upnp:icon>http://169.254.26.244:8895/resource/1057/COVER_IMAGE</upnp:icon><upnp:album>ABBA</upnp:album><dc:date>2012-01-02</dc:date><upnp:genre>Pop</upnp:genre><upnp:artist>ABBA</upnp:artist><res bitrate="120500" duration="0:03:34.000" nrAudioChannels="2" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000" sampleFrequency="44100" size="25862182">http://169.254.26.244:8895/resource/1057/MEDIA_ITEM/FLAC-0/ORIGINAL</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000" resolution="160x157">http://169.254.26.244:8895/resource/1057/COVER_IMAGE</res></item></DIDL-Lite></Result><NumberReturned>14</NumberReturned><TotalMatches>14</TotalMatches><UpdateID>30</UpdateID></u:BrowseResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
no sort order..
ginjaninja
Post Tue Nov 13, 2012 10:57 pm
Going back to talking to samsung allshare...but tv is now configured with by "folder view".
Accept: */*
Content-Length: 291
Connection: close
DATE: Tue, 13 Nov 2012 22:47:20 GMT
EXT:
SERVER: UPnP/1.0
Connection: close
<s:Body>
</s:Body>
</s:Envelope>
(In by folder view there is no track sort order it is alphabetical).
Accept: */*
Content-Length: 451
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>1</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>*</Filter><StartingIndex>0</StartingIndex><RequestedCount>1</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>HTTP/1.1 200 OK
Content-Length: 1440
EXT:
SERVER: UPnP/1.0
Connection: close
<s:Body>
<container id="4518" parentID="1" childCount="20" searchable="0" restricted="1"><upnp:class>object.container</upnp:class><dc:title>Abba</dc:title><upnp:objectUpdateID>4639</upnp:objectUpdateID><sec:initUpdateID>3902</sec:initUpdateID><sec:classCount class="object.container">15</sec:classCount><sec:classCount class="object.item.imageItem">5</sec:classCount><sec:classCount class="object.item.audioItem">0</sec:classCount><sec:classCount class="object.item.videoItem">0</sec:classCount></container>
<TotalMatches>4</TotalMatches>
</u:BrowseResponse>
</s:Body>
</s:Envelope>
abba as one of the four containers on by folder view.
Accept: */*
Content-Length: 454
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>4519</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>*</Filter><StartingIndex>0</StartingIndex><RequestedCount>1</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>HTTP/1.1 200 OK
Content-Length: 1864
DATE: Tue, 13 Nov 2012 22:47:25 GMT
EXT:
SERVER: UPnP/1.0
Connection: close
<s:Body>
<item id="4521" parentID="4519" restricted="0"><res duration="00:03:12" size="24048377" protocolInfo="http-get:*:audio/x-flac:DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000">http://192.168.4.53:17679/FileProvider/M$192000/O$1/S$/P$/I$audio/x-flac/4521</res><upnp:originalTrackNumber>2</upnp:originalTrackNumber><upnp:album>Ring Ring</upnp:album><upnp:genre>Pop</upnp:genre><upnp:playbackCount>0</upnp:playbackCount><upnp:artist>ABBA</upnp:artist><sec:dcmInfo>MOODSCORE=0,MOODID=5,CREATIONDATE=1325517476,YEAR=2012</sec:dcmInfo><sec:modifiationDate>2012-01-02T15:17:56</sec:modifiationDate><sec:preference>0</sec:preference><dc:date>2012-01-02T15:17:56</dc:date><upnp:class>object.item.audioItem</upnp:class><dc:title>Another Town Another Train</dc:title><upnp:objectUpdateID>3908</upnp:objectUpdateID><sec:initUpdateID>3908</sec:initUpdateID></item>
<TotalMatches>20</TotalMatches>
</u:BrowseResponse>
</s:Body>
</s:Envelope>
1st track in list in the 1st album of abba 'album artist' with the samsung allshare software with tv configured for 'folder view'...alphabetical sort order. "By Folder View" is the only view which is not sorted by tracknumber on allshare..well i say on allshare...but of course it is not the server which is producing the sort order, or perhaps even the track metadata transmitted, but the TV itself which is deciding which order to display in.
ZIp
Are there any particular further wiresharks that might help you ascertain
1) if there was a serviio config solution to sort order on TV
2) If enabling the propriety samsung views is not as propriety and complex as 1st anticipated.
otherwise im still thinking that setting dc:title to %tracknumber%. %title% using id3tags, is the simplest way to get a music sort order on a renderer that refuses to play nicely.
Post Wed Nov 14, 2012 9:23 am
Re: Using the intel Upnp tools and wireshark to diagnose is
ginjaninja wrote:otherwise im still thinking that setting dc:title to %tracknumber%. %title% using id3tags, is the simplest way to get a music sort order on a renderer that refuses to play nicely.
Probably yes.
Users browsing this forum: No registered users and 70 guests
