.rec Files from Topfield SRP2100 on Sony Bravia 2011
jojo8897
Post Mon Nov 12, 2012 4:12 pm
I want to play fiels wich where saved on my Synology ds412+ the files are records from the Topfield SRP2100 and the names ends with .rec
First of all i have zo make it possible that serviio show me the .rec files in the shared folders. The .rec files are .ts
Here the infos from Mediainfo
Allgemein
Complete name                            : Y:\Der Sleepover Club ~ Der neue Sleepover Club.rec
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 2,31 GiB
Duration                                 : 22min
Overall bit rate mode                    : variabel
Overall bit rate                         : 14,4 Mbps
Menu ID                                  : 11160 (0x2B98)
Format profile                           : High@L4.0
Format settings, CABAC                   : Ja
Format settings, ReFrames                : 6 frames
Codec ID                                 : 27
Duration                                 : 23min
Bit rate                                 : 12,9 Mbps
Width                                    : 1 280 Pixel
Height                                   : 720 Pixel
Frame rate                               : 50,000 FPS
Scan type                                : progressiv
Bits/(Pixel*Frame)                       : 0.280
Stream size                              : 2,07 GiB (90%)
colour_primaries                         : BT.709
transfer_characteristics                 : BT.709
matrix_coefficients                      : BT.709
Audio #1
Format                                   : MPEG Audio
Format version                           : Version 1
Format profile                           : Layer 2
Codec ID                                 : 3
Duration                                 : 22min
Bit rate mode                            : konstant
Bit rate                                 : 256 Kbps
Channel(s)                               : 2 Kanäle
Sampling rate                            : 48,0 KHz
Delay relative to video                  : -491ms
Stream size                              : 42,1 MiB (2%)
Language                                 : Deutsch
Audio #2
Format                                   : MPEG Audio
Codec ID                                 : 3
Duration                                 : 22min
Bit rate                                 : 192 Kbps
Stream size                              : 31,6 MiB (1%)
Audio #3
Codec ID                                 : 6
Duration                                 : 22min
Bit rate                                 : 448 Kbps
Delay relative to video                  : -414ms
Stream size                              : 73,7 MiB (3%)
Language                                 : Deutsch
Text
ID                                       : 6630 (0x19E6)-100
Format                                   : Teletext
Language                                 : Deutsch
Menü
Duration                                 : 22min
List                                     : 6610 (0x19D2) (AVC) / 6620 (0x19DC) (MPEG Audio, Deutsch) / 6621 (0x19DD) (MPEG Audio) / 6622 (0x19DE) (AC-3, Deutsch) / 6630 (0x19E6) ()
Language                                 :  / Deutsch /  / Deutsch
Service name                             : KiKA HD
Service provider                         : ZDFvision
Service type                             : advanced codec HD digital television
ffmpeg -i
ffmpeg version UNKNOWN, Copyright (c) 2000-2011 the FFmpeg developers
  built on Sep 26 2012 04:26:09 with gcc 4.2.1
  configuration: --arch=i686 --target-os=linux --cross-prefix=/usr/local/i686-linux-gnu/bin/i686-linux-gnu- --enable-cross-compile --enable-optimizations --disable-yasm --disable-altivec --enable-pic --enable-shared --disable-static --disable-swscale-alpha --disable-ffserver --disable-ffplay --enable-libmp3lame --enable-libfaac --enable-nonfree --enable-version3 --enable-libopencore-amrnb --enable-libopencore-amrwb --disable-decoder=amrnb
  libavutil    50. 40. 1 / 50. 40. 1
  libavcodec   52.120. 0 / 52.120. 0
  libavformat  52.108. 0 / 52.108. 0
  libavdevice  52.  4. 0 / 52.  4. 0
  libavfilter   1. 77. 0 /  1. 77. 0
  libswscale    0. 14. 0 /  0. 14. 0
[h264 @ 0x8079ee0] non-existing SPS 0 referenced in buffering period
[h264 @ 0x8079ee0] non-existing PPS referenced
[h264 @ 0x8079ee0] non-existing PPS 0 referenced
[h264 @ 0x8079ee0] decode_slice_header error
[h264 @ 0x8079ee0] no frame!
Input #0, mpegts, from 'sleepover.rec':
  Duration: 00:23:01.15, start: 94181.984500, bitrate: 14379 kb/s
  Program 11150
      service_name    : ?3sat HD
      service_provider: ?ZDFvision
  Program 11160
      service_name    : ?KiKA HD
    Stream #0.0[0x19d2]: Video: h264 (High), yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 50.76 fps, 50 tbr, 90k tbn, 100 tbc
    Stream #0.1[0x19dc](deu): Audio: mp2, 48000 Hz, stereo, s16, 256 kb/s
    Stream #0.2[0x19dd](mis): Audio: mp2, 48000 Hz, stereo, s16, 192 kb/s
    Stream #0.3[0x19de](deu): Audio: ac3, 48000 Hz, stereo, s16, 448 kb/s
    Stream #0.4[0x19e6](deu): Subtitle: [6][0][0][0] / 0x0006
  Program 11170
      service_name    : ?ZDFinfo HD
Thank you for help and sorry for my bad english
Jörg
Post Mon Nov 12, 2012 5:16 pm
Re: .rec Files from Topfield SRP2100 on Sony Bravia 2011
Serviio will scan the first audio track, it wiil be mp2 for this "rec" file. Don't know if serviio supports it (h264/mp2)...
Could you enable detailed logging (see signature), then simply change/rename the file, and force a library refresh. Then post here the log file ?
Then as you can see there were many [h264 ] errors on ffmpeg result, its probably because this "live recorded" file don't have h264 header at the beginning of the file, don't know how serviio/ffmpeg will support it (check log file for library scan result)
jojo8897
Post Mon Nov 12, 2012 6:43 pm
Hello Illico,
here is the logfile
2012-11-12 19:25:06,145 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7135.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 3887, data length: 13595).
2012-11-12 19:25:06,150 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_3265.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 6582, data length: 16290).
2012-11-12 19:25:06,162 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_3298.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 6106, data length: 15814).
2012-11-12 19:25:06,167 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7109.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 6865, data length: 16573).
2012-11-12 19:25:06,175 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_3396.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 6064, data length: 15772).
2012-11-12 19:25:06,177 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_3193.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 5677, data length: 15385).
2012-11-12 19:25:06,182 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7355.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 8076, data length: 17784).
2012-11-12 19:25:06,191 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7138.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 6841, data length: 16549).
2012-11-12 19:25:06,193 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7168.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 6536, data length: 16244).
2012-11-12 19:25:06,197 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7157.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 7206, data length: 16914).
2012-11-12 19:25:06,206 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_3253.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 4769, data length: 14477).
2012-11-12 19:25:06,209 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7356.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 8969, data length: 18677).
2012-11-12 19:25:06,212 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7133.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 6901, data length: 16609).
2012-11-12 19:25:06,243 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_3389.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 6157, data length: 15865).
2012-11-12 19:25:06,248 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7174.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 6976, data length: 16684).
2012-11-12 19:25:06,255 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7087.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 7204, data length: 16912).
2012-11-12 19:25:06,257 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7261.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 6304, data length: 16012).
2012-11-12 19:25:06,264 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_3299.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 5966, data length: 15674).
2012-11-12 19:25:06,267 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7329.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 8048, data length: 17756).
2012-11-12 19:25:06,269 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_3239.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 4669, data length: 14377).
2012-11-12 19:25:06,275 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7238.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 7512, data length: 17220).
2012-11-12 19:25:06,284 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7241.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 5572, data length: 15280).
2012-11-12 19:25:06,286 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_3372.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 6146, data length: 15854).
2012-11-12 19:25:06,294 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7203.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 6264, data length: 15972).
2012-11-12 19:25:06,299 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_3274.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 7752, data length: 17460).
2012-11-12 19:25:06,301 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_3184.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 7976, data length: 17684).
2012-11-12 19:25:06,303 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_3301.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 5753, data length: 15461).
2012-11-12 19:25:06,311 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7175.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 7623, data length: 17331).
2012-11-12 19:25:06,318 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_3358.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 5985, data length: 15693).
2012-11-12 19:25:06,321 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7283.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 7442, data length: 17150).
2012-11-12 19:25:06,331 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_3394.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 6094, data length: 15802).
2012-11-12 19:25:06,337 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_3291.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 5651, data length: 15359).
2012-11-12 19:25:06,357 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7177.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 8105, data length: 17813).
2012-11-12 19:25:06,359 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_3186.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 8193, data length: 17901).
2012-11-12 19:25:06,361 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7114.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 6896, data length: 16604).
2012-11-12 19:25:06,371 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_3258.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 4987, data length: 14695).
2012-11-12 19:25:06,376 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7326.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 8781, data length: 18489).
2012-11-12 19:25:06,388 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7269.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 9314, data length: 19022).
2012-11-12 19:25:06,401 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7229.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 6655, data length: 16363).
2012-11-12 19:25:06,409 WARN  [LibraryManager] Cannot read metadata of file /volume1/photo/Carlotta/_MG_7360.JPG via extractor EMBEDDED. Message: Could not read block (block start: 9716, block length: 7597, data length: 17305).
2012-11-12 19:27:39,788 INFO  [LibraryAdditionsCheckerThread] Added file 'sleep.ts' (title: Sleep) to Library
But ther is no warning for the file only for photos. I changed the name from sleep.rec in sleep.ts
Jörg
Post Mon Nov 12, 2012 7:13 pm
It is the standard log, could you enable DETAILED logging (see signature link), then restart serviio serviceor reboot, change *.rec file name to force serviio to rescan the file...
jojo8897
Post Mon Nov 12, 2012 7:41 pm
I make a new one i've updatet serviio an the update changed the file. SORRY
jojo8897
Post Mon Nov 12, 2012 8:13 pm
It is a big file, 5 files :)
wich part you need or should i send it as an archive to you.
here is an snipped
2012-11-12 21:05:53,952 DEBUG [MediaItemDAOImpl] Media item euhd-body-s02e06-720p.mkv already exists in DB
2012-11-12 21:05:53,952 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /volume1/video/Dr. House
2012-11-12 21:05:53,963 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /volume1/video/Dr. House/@eaDir
2012-11-12 21:05:53,963 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /volume1/video/37 Grad
2012-11-12 21:05:54,024 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /volume1/video/TimeShift
2012-11-12 21:05:54,025 DEBUG [LibraryAdditionsCheckerThread] Found file 'sleeeeeeeeeeeeeeep4.ts', checking if it's already in the Library
2012-11-12 21:05:54,025 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item sleeeeeeeeeeeeeeep4.ts
2012-11-12 21:05:54,025 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /volume1/video/sleeeeeeeeeeeeeeep4.ts, ignore case: false
2012-11-12 21:05:54,025 DEBUG [MediaItemDAOImpl] Media item sleeeeeeeeeeeeeeep4.ts already exists in DB
2012-11-12 21:05:54,025 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /volume1/video/Royal-Pains
2012-11-12 21:05:54,026 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /volume1/video/Royal-Pains/Royal Pains - S02E07 - Paige & Evan - Ge
2012-11-12 21:05:54,028 DEBUG [LibraryAdditionsCheckerThread] Looking for files to share in folder: /volume1/video/Royal-Pains/@eaDir
Users browsing this forum: No registered users and 84 guests
