"Not Supported Video Codec" with DV-video files
drinkJava
Post Wed Nov 14, 2012 8:16 am
I have an archive of DV files from my Sony Camcorder captured by Windows Live Movie Maker.
These files play nicely on computer but result in 'Not Supported Video Codec" on my Samsung D6420 TV
ffmpeg info:
C:\Serviio\lib>ffmpeg -i "D:\DV_Archive\2002_Canada.avi"
g-config
Guessed Channel Layout for  Input Stream #0.1 : stereo
Guessed Channel Layout for  Input Stream #0.2 : stereo
Input #0, avi, from 'D:\DV_Archive\2002_Canada.avi':
  Duration: 00:46:54.04, start: 0.000000, bitrate: 28850 kb/s
    Stream #0:0: Video: dvvideo, yuv411p, 720x480 [SAR 8:9 DAR 4:3], 28771 kb/s,
 29.97 tbr, 29.97 tbn, 29.97 tbc
    Stream #0:1: Audio: pcm_s16le, 32000 Hz, stereo, s16, 1024 kb/s
    Stream #0:2: Audio: pcm_s16le, 32000 Hz, stereo, s16, 1024 kb/s
I found a similar post here (http://forum.serviio.org/viewtopic.php?f=7&t=6309&p=52470&hilit=dvvideo#p52470) but in my case files don't play at all
Could you please advice what can be wrong?
I'm using v.1.0.1 with original 'profiles.xml'
Thank you in advance,
Val
Post Wed Nov 14, 2012 8:52 am
Re: "Not Supported Video Codec" with DV-video files
avi/dvvideo should be transcoded with "Samsung TV / player (C/D/E-series)" profile.
Could you enable detailed logging (see signature) and check if this file is transcoded and post log here ?
drinkJava
Post Sat Nov 24, 2012 6:00 pm
I have enabled extensive logging with 'DEBUG' threshold but ran into another problem.
After enabling it I stopped the service and deleted the serviio.log file just for convenience to see everything from scratch. But surprisingly after a service startup the logfile was not created!!!. I have tried restarting the service several times but no luck... The 'derby.log' is there, but no 'serviio.log' file. The service is running smoothly... Where did it go to and how to re-enable it again? I have tried changing the logging level back to INFO which didn't make any difference.
Post Mon Nov 26, 2012 12:22 pm
Did you try restarting the PC?
drinkJava
Post Thu Dec 06, 2012 6:28 am
Yes, I have tried rebooting the server, still no serviio.log
