Failed retreavin media information for AKAMAI applehttp
I am writing a new WebResource plugin for svtplay, and I am finding that Serviio can not sniff out the media type for the applehttp stream.
Here is an error from the log file:
2012-11-16 00:35:39,074 DEBUG [FeedUpdaterThread] Retrieving file size from the URL connection
2012-11-16 00:35:39,567 DEBUG [FeedUpdaterThread] Retrieving information about the video stream 'Adrian'
2012-11-16 00:35:39,568 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: http://svtplay9d-f.akamaihd.net/i/se/se ... K5kA%3d%3d
2012-11-16 00:35:39,568 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\lib\ffmpeg.exe -i http://svtplay9d-f.akamaihd.net/i/se/se ... K5kA%3d%3d
2012-11-16 00:35:40,710 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://svtplay9d-f.akamaihd.net/i/se/se ... K5kA%3d%3d. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:291)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:382)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:86)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:124)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:268)
... 2 more
The url reported by the FFMPEGWrapper contains commas.
But the url reported by the ProcessExecutor contains escape sequences (url-encoding) for those commas.
If i try to run the unescaped url in VLC, the stream plays fine.
If I try to dump the unescaped url using ffmpeg (latest static build for Windows x64) I get some warnings, but it still parses and dumps the stream:
C:\Users\otto>"C:\Program Files\Serviio\lib\ffmpeg.exe" -i http://svtplay4h-f.ak
amaihd.net/i/world/open/20121115/1308916-064A_ABC/REGIONALA_NYHET-064A-abc-da733
6991ee4e4ce_,900,320,420,620,1660,2760,.mp4.csmil/index_5_av.m3u8?e=b2a7ace1bf66
1c32 d:\tmp\test.mp4
ffmpeg version N-46469-gc995644 Copyright (c) 2000-2012 the FFmpeg developers
built on Nov 5 2012 17:58:15 with gcc 4.7.2 (GCC)
configuration: --enable-gpl --enable-version3 --disable-pthreads --enable-runt
ime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass -
-enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enab
le-libgsm --enable-libmp3lame --enable-libnut --enable-libopenjpeg --enable-libo
pus --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheo
ra --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-li
bvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --ena
ble-zlib
libavutil 52. 5.100 / 52. 5.100
libavcodec 54. 71.100 / 54. 71.100
libavformat 54. 36.100 / 54. 36.100
libavdevice 54. 3.100 / 54. 3.100
libavfilter 3. 21.106 / 3. 21.106
libswscale 2. 1.102 / 2. 1.102
libswresample 0. 16.100 / 0. 16.100
libpostproc 52. 1.100 / 52. 1.100
[h264 @ 0000000004850340] non-existing SPS 0 referenced in buffering period
[h264 @ 0000000004850340] non-existing SPS 32 referenced in buffering period
[mpegts @ 0000000001f28380] Estimating duration from bitrate, this may be inaccu
rate
[h264 @ 0000000004d38280] non-existing SPS 0 referenced in buffering period
[h264 @ 0000000004d38280] non-existing SPS 32 referenced in buffering period
Input #0, hls,applehttp, from 'http://svtplay4h-f.akamaihd.net/i/world/open/2012
1115/1308916-064A_ABC/REGIONALA_NYHET-064A-abc-da7336991ee4e4ce_,900,320,420,620
,1660,2760,.mp4.csmil/index_5_av.m3u8?e=b2a7ace1bf661c32':
Duration: 00:10:03.00, start: 0.100667, bitrate: 0 kb/s
Stream #0:0: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 1280x720
[SAR 1:1 DAR 16:9], 12.50 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:1: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, s16, 160
kb/s
[libx264 @ 0000000004d58c80] using SAR=1/1
[libx264 @ 0000000004d58c80] using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShu
ffle SSE4.2
[libx264 @ 0000000004d58c80] profile High, level 3.1
[libx264 @ 0000000004d58c80] 264 - core 128 r2216 198a7ea - H.264/MPEG-4 AVC cod
ec - Copyleft 2003-2012 - http://www.videolan.org/x264.html - options: cabac=1 r
ef=3 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed
_ref=1 me_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pski
p=1 chroma_qp_offset=-2 threads=12 lookahead_threads=2 sliced_threads=0 nr=0 dec
imate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b
_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=
25 scenecut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.0 qcomp=0.
60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00
[h264 @ 00000000048d3420] non-existing SPS 0 referenced in buffering period
[h264 @ 00000000048d3420] non-existing SPS 32 referenced in buffering period
Output #0, mp4, to 'd:\tmp\test.mp4':
encoder : Lavf54.36.100
Stream #0:0: Video: h264 ([33][0][0][0] / 0x0021), yuv420p, 1280x720 [SAR 1:
1 DAR 16:9], q=-1--1, 12800 tbn, 25 tbc
Stream #0:1: Audio: aac ([64][0][0][0] / 0x0040), 48000 Hz, stereo, s16, 128
kb/s
Stream mapping:
Stream #0:0 -> #0:0 (h264 -> libx264)
Stream #0:1 -> #0:1 (aac -> libvo_aacenc)
frame= 66 fps=0.0 q=28.0 size= 137kB time=00:00:02.95 bitrate= 379.0kbits/
frame= 104 fps=103 q=28.0 size= 324kB time=00:00:04.46 bitrate= 594.3kbits/
frame= 122 fps= 81 q=28.0 size= 581kB time=00:00:05.19 bitrate= 915.9kbits/
frame= 144 fps= 70 q=28.0 size= 847kB time=00:00:06.06 bitrate=1143.1kbits/
frame= 162 fps= 62 q=28.0 size= 1130kB time=00:00:06.77 bitrate=1366.3kbits/
frame= 182 fps= 58 q=28.0 size= 1359kB time=00:00:07.58 bitrate=1468.7kbits/
frame= 208 fps= 56 q=28.0 size= 1711kB time=00:00:08.62 bitrate=1624.2kbits/
frame= 230 fps= 54 q=28.0 size= 1968kB time=00:00:09.52 bitrate=1693.2kbits/
frame= 242 fps= 47 q=28.0 size= 2112kB time=00:00:09.97 bitrate=1735.2kbits/
frame= 262 fps= 47 q=28.0 size= 2438kB time=00:00:10.80 bitrate=1848.3kbits/
frame= 262 fps= 33 q=28.0 size= 2438kB time=00:00:10.82 bitrate=1844.7kbits/
frame= 288 fps= 34 q=28.0 size= 2786kB time=00:00:11.80 bitrate=1933.0kbits/
frame= 304 fps= 31 q=-1.0 Lsize= 3372kB time=00:00:12.48 bitrate=2211.8kbits
/s dup=1 drop=0
video:3167kB audio:196kB subtitle:0 global headers:0kB muxing overhead 0.287847%
[libx264 @ 0000000004d58c80] frame I:5 Avg QP:18.57 size: 31036
[libx264 @ 0000000004d58c80] frame P:178 Avg QP:22.34 size: 14817
[libx264 @ 0000000004d58c80] frame B:121 Avg QP:24.99 size: 3714
[libx264 @ 0000000004d58c80] consecutive B-frames: 35.5% 31.6% 7.9% 25.0%
[libx264 @ 0000000004d58c80] mb I I16..4: 56.4% 24.2% 19.5%
[libx264 @ 0000000004d58c80] mb P I16..4: 28.0% 14.7% 3.1% P16..4: 27.6% 6.8
% 2.2% 0.0% 0.0% skip:17.6%
[libx264 @ 0000000004d58c80] mb B I16..4: 3.0% 2.2% 0.2% B16..8: 28.7% 2.0
% 0.3% direct: 3.7% skip:60.0% L0:40.5% L1:54.4% BI: 5.0%
[libx264 @ 0000000004d58c80] 8x8 transform intra:32.3% inter:68.9%
[libx264 @ 0000000004d58c80] coded y,uvDC,uvAC intra: 22.1% 57.9% 6.8% inter: 12
.3% 27.7% 1.0%
[libx264 @ 0000000004d58c80] i16 v,h,dc,p: 32% 28% 15% 25%
[libx264 @ 0000000004d58c80] i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 25% 33% 3% 2%
2% 2% 3% 4%
[libx264 @ 0000000004d58c80] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 28% 21% 28% 5% 4%
4% 3% 4% 4%
[libx264 @ 0000000004d58c80] i8c dc,h,v,p: 44% 27% 20% 10%
[libx264 @ 0000000004d58c80] Weighted P-Frames: Y:13.5% UV:12.9%
[libx264 @ 0000000004d58c80] ref P L0: 71.1% 13.7% 12.2% 2.8% 0.1%
[libx264 @ 0000000004d58c80] ref B L0: 86.9% 11.8% 1.3%
[libx264 @ 0000000004d58c80] ref B L1: 95.5% 4.5%
[libx264 @ 0000000004d58c80] kb/s:2132.91
If I try using the escaped url, ffmpeg fails (gets a http 404):
C:\Users\otto>"C:\Program Files\Serviio\lib\ffmpeg.exe" -i http://svtplay9d-f.ak
amaihd.net/i/se/secure/20121104/1128572-005A/ADRIAAN-005A-e2c103ba629791e0_%2c90
0%2c320%2c420%2c620%2c1660%2c2760%2c.mp4.csmil/index_5_av.m3u8?e=b2a7ace1bf661c3
2&id=AgBV5iXiXCEhlAh8pVD7zea+31zF8dplSYJPqHsPWBkpDQ8JIFGjKsMNAneJn%2f9bReMdvoGqn
bK5kA%3d%3d
ble-zlib
[http @ 00000000020dae80] HTTP error 404 Not Found
http://svtplay9d-f.akamaihd.net/i/se/se ... AAN-005A-e
2c103ba629791e0_%2c900%2c320%2c420%2c620%2c1660%2c2760%2c.mp4.csmil/index_5_av.m
3u8?e=b2a7ace1bf661c32: Input/output error
id är inte ett internt kommando, externt kommando,
program eller kommandofil.
So, my guess is that one of the components FFMPEGWrapper or ProcessExecutor erroneously url-encodes the url before passing it to FFMPeg.
