Problems AGAIN... Samsung LN40C550 Disconnect constantly
Eze2kiel
Post Sun Nov 18, 2012 3:16 am
Hi!
Sorry for my poor English...
I'm from Argentina.
Ok...
Currently I change my PC.
Previously I had this problem with another PC using Windows 7 Ultimate SP1 X64: viewtopic.php?f=10&t=7260
Now in the new PC I'm using Windows 7 Home Premium SP1 X64...
I install Serviio latest version, then update the FFMPEG.exe considering the aforementioned problem... And my surprise was... The problem persists!
The truth can't be the same thing happens!
Any suggestions?
Since you already tried everything and after 15 minutes, 2 minutes, 10 seconds I get the same problem disconnecting!!
I check the FTP cable with a network tester and isn't the problem...
Suggestions?
Since I can't quietly watch a movie!
One thing I was thinking would happen to other DLNA program, but doesn't convince me either as Serviio for now, so I expect an answer to solve this once and for all.
Thanks!
Eze2kiel
Post Wed Nov 21, 2012 1:49 am
Re: Problems AGAIN... Samsung LN40C550 Disconnect constantly
None? :?
Eze2kiel
Post Fri Nov 23, 2012 2:55 am
:( :? :roll:
Post Fri Nov 23, 2012 10:50 am
Wait for 1.1, hopefully it'd help.
jdegreef
Post Sun Nov 25, 2012 2:44 pm
Same problem here !
Strange enough it starts disconnecting after the 15 days the free version was acting as pro. Non documented limitation ?
alfista
Post Mon Nov 26, 2012 12:21 pm
Try disabling all online content and restart the server. I've had problems wih some plugins that caused Serviio to become sluggish enough that my Samsung BD-player kept disconnecting. However, the odd disconnect now and then seems to be par for the course with Samsung equipment.
Post Mon Nov 26, 2012 4:49 pm
jdegreef wrote:Same problem here !
Not related
