Problem streaming video in mediabrowser - SOLVED
lmd
Post Thu Nov 15, 2012 3:09 am
Hi guys,
I upgraded to version 1.0.1 from 0.6.2 last night and I'm really impressed. I'd like to take advantage of the mediabrowser software to access my videos from home when on the move or at work (when I get some 'quiet' time).
I can listen to my mp3s and I can also look at my photos, but when I try to view the videos, I get an error message like this:
200, Stream not found, NetStream.Play.StreamNotFound, clip: '[Clip]
'http://myservername.com:23424/cds/resource/48/MEDIA_ITEM/FLV-0/MEDIUM,flv_player?authToken=longnumberhere''
I'm running serviio on an old laptop using Ubuntu 12.04, Serviio 1.0.1 and the latest Web UI in PHP - I have external hard drives plugged into the machine which are my main source of media. I know they're working OK as the photos and music are coming off them just fine.
Any help appreciated - apologies if I've missed an FAQ on this already, I couldn't see it.
Cheers,
Andy :)
Post Thu Nov 15, 2012 5:18 am
Re: Problem streaming video in mediabrowser
There is a bug that will be fixed in the next release. You will get that message when you attempt to replay a video. A workaround is to start playing another video, stop it and go play the first video again.
lmd
Post Thu Nov 15, 2012 6:12 am
OK jhb50 - thanks for the info. I'll try the workaround - any idea on an ETA for the next release?
Cheers :)
I tried the workaround, and it didn't work for me. I await the next release with great anticipation! Serviio has made my time here in Thailand a really pleasant one - the TV here is just terrible LOL :D
Post Thu Nov 15, 2012 2:22 pm
Do you see any errors in the log when you play the file?
lmd
Post Thu Nov 15, 2012 4:38 pm
I'll try again and take a look! :)
lmd
Post Thu Nov 15, 2012 4:41 pm
2012-11-15 23:37:37,146 DEBUG [ServiioStatusService] Detailed exception:
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-3934-flv_player-MEDIUM.stf' cannot be found, FFmpeg execution probably failed
This is the last error, there were a few before from when I tried a few different videos. I've just done a major reinstall of ffmpeg using the package you provide on the download page. I couldn't get librtmp to work but I don't think that's the problem. It looks like the flv codec isn't installed - I'll give it a try now and see if it works.
I've managed to get my Online resources working again though. Let's see how I go.
I'm running Ubuntu 12.04 if I haven't mentioned it before.
Cheers,
Andy :)
Post Thu Nov 15, 2012 10:48 pm
Enable detailed logging, run it again and you should see the ffmpeg command used. Then try to run the command and post the error
lmd
Post Fri Nov 16, 2012 1:25 am
zip wrote:Enable detailed logging, run it again and you should see the ffmpeg command used. Then try to run the command and post the error
Thanks for looking into this Zip, here's the output:
2012-11-16 08:22:59,589 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth0 (eth0) and address 192.168.1.34, timeout = 0
2012-11-16 08:22:59,590 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device 04498967-31be-31f3-951a-53a7e3af9f75
2012-11-16 08:23:00,309 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2012-11-16 08:23:01,363 DEBUG [CDSRetrieveMediaServerResource] Request for content delivery accepted
2012-11-16 08:23:01,363 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/180.183.74.101, Profile=Flash player'
2012-11-16 08:23:01,363 DEBUG [ResourceDeliveryProcessor] Request for resource 1000000000910001 and type 'MEDIA_ITEM' received
2012-11-16 08:23:01,363 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1000000000910001 (online)
2012-11-16 08:23:01,363 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 91)
2012-11-16 08:23:01,364 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 91)
2012-11-16 08:23:01,364 DEBUG [VideoDeliveryEngine] Delivering item '1000000000910001' for client 'IPAddress=/180.183.74.101, Profile=Flash player'
2012-11-16 08:23:01,364 DEBUG [VideoDeliveryEngine] Delivering file 'http://o-o---preferred---sn-5np5po4v-c33e7---v19---lscache2.c.youtube.com/videoplayback?upn=jEWBl3c5pOw&sparams=algorithm%2Cburst%2Ccp%2Cfactor%2Cgcr%2Cid%2Cip%2Cipbits%2Citag%2Csource%2Cupn%2Cexpire&fexp=905605%2C912307%2C916408%2C904462%2C922401%2C920704%2C912806%2C927201%2C925706%2C922403%2C925003%2C913546%2C913556%2C916805%2C920201%2C901451&ms=au&algorithm=throttle-factor&burst=40&ip=110.171.118.143&itag=35&gcr=th&sver=3&mt=1353008290&mv=m&source=youtube&key=yt1&ipbits=8&factor=1.25&cp=U0hUSFBOT19MU0NONF9ISFNIOklzRGZQRGZjT2ZW&expire=1353031779&id=fcb3f9bae2dcc02b&signature=A502CA49E371824CC73088794EDF9696C7BF0BCB.6252950158DAC2D427FB5D7941FAC33B5FB2278C' using transcoding
2012-11-16 08:23:01,364 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-1000000000910001-flv_player-MEDIUM.stf'
2012-11-16 08:23:01,364 DEBUG [TranscodingJobListener] Deleted temp file '/tmp/Serviio/transcoding-temp-1000000000910001-flv_player-MEDIUM.stf': false
2012-11-16 08:23:01,364 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/180.183.74.101, Profile=Flash player'
2012-11-16 08:23:01,364 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: http://o-o---preferred---sn-5np5po4v-c33e7---v19---lscache2.c.youtube.com/videoplayback?upn=jEWBl3c5pOw&sparams=algorithm%2Cburst%2Ccp%2Cfactor%2Cgcr%2Cid%2Cip%2Cipbits%2Citag%2Csource%2Cupn%2Cexpire&fexp=905605%2C912307%2C916408%2C904462%2C922401%2C920704%2C912806%2C927201%2C925706%2C922403%2C925003%2C913546%2C913556%2C916805%2C920201%2C901451&ms=au&algorithm=throttle-factor&burst=40&ip=110.171.118.143&itag=35&gcr=th&sver=3&mt=1353008290&mv=m&source=youtube&key=yt1&ipbits=8&factor=1.25&cp=U0hUSFBOT19MU0NONF9ISFNIOklzRGZQRGZjT2ZW&expire=1353031779&id=fcb3f9bae2dcc02b&signature=A502CA49E371824CC73088794EDF9696C7BF0BCB.6252950158DAC2D427FB5D7941FAC33B5FB2278C
2012-11-16 08:23:01,365 DEBUG [ProcessExecutor] Starting ffmpeg -i http://o-o---preferred---sn-5np5po4v-c33e7---v19---lscache2.c.youtube.com/videoplayback?upn=jEWBl3c5pOw&sparams=algorithm%2Cburst%2Ccp%2Cfactor%2Cgcr%2Cid%2Cip%2Cipbits%2Citag%2Csource%2Cupn%2Cexpire&fexp=905605%2C912307%2C916408%2C904462%2C922401%2C920704%2C912806%2C927201%2C925706%2C922403%2C925003%2C913546%2C913556%2C916805%2C920201%2C901451&ms=au&algorithm=throttle-factor&burst=40&ip=110.171.118.143&itag=35&gcr=th&sver=3&mt=1353008290&mv=m&source=youtube&key=yt1&ipbits=8&factor=1.25&cp=U0hUSFBOT19MU0NONF9ISFNIOklzRGZQRGZjT2ZW&expire=1353031779&id=fcb3f9bae2dcc02b&signature=A502CA49E371824CC73088794EDF9696C7BF0BCB.6252950158DAC2D427FB5D7941FAC33B5FB2278C -y -copyts -c:v flv -b:v 1000k -maxrate:v 1000k -bufsize:v 1000k -r 30000/1001 -g 15 -c:a libmp3lame -b:a 128k -ar 44100 -ac 2 -map 0:0 -map 0:1 -sn -f flv /tmp/Serviio/transcoding-temp-1000000000910001-flv_player-MEDIUM.stf
2012-11-16 08:23:01,393 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:41
2012-11-16 08:23:01,568 WARN  [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error.
2012-11-16 08:23:01,568 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2012-11-16 08:23:04,614 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
There must be somehing on ffmpeg I've not installed correctly - any idea?
Thanks! :)
Post Fri Nov 16, 2012 12:34 pm
so what happens when you execute this?
fmpeg -i "http://o-o---preferred---sn-5np5po4v-c33e7---v19---lscache2.c.youtube.com/videoplayback?upn=jEWBl3c5pOw&sparams=algorithm%2Cburst%2Ccp%2Cfactor%2Cgcr%2Cid%2Cip%2Cipbits%2Citag%2Csource%2Cupn%2Cexpire&fexp=905605%2C912307%2C916408%2C904462%2C922401%2C920704%2C912806%2C927201%2C925706%2C922403%2C925003%2C913546%2C913556%2C916805%2C920201%2C901451&ms=au&algorithm=throttle-factor&burst=40&ip=110.171.118.143&itag=35&gcr=th&sver=3&mt=1353008290&mv=m&source=youtube&key=yt1&ipbits=8&factor=1.25&cp=U0hUSFBOT19MU0NONF9ISFNIOklzRGZQRGZjT2ZW&expire=1353031779&id=fcb3f9bae2dcc02b&signature=A502CA49E371824CC73088794EDF9696C7BF0BCB.6252950158DAC2D427FB5D7941FAC33B5FB2278C" -y -copyts -c:v flv -b:v 1000k -maxrate:v 1000k -bufsize:v 1000k -r 30000/1001 -g 15 -c:a libmp3lame -b:a 128k -ar 44100 -ac 2 -map 0:0 -map 0:1 -sn -f flv /tmp/Serviio/transcoding-temp-1000000000910001-flv_player-MEDIUM.stf
lmd
Post Sat Nov 17, 2012 3:01 pm
OK, so when I execute that from the command line I get this:
HTTP error 403 Forbidden
http://o-o---preferred---sn-5np5po4v-c33e7---v19---lscache2.c.youtube.com/videoplayback?upn=jEWBl3c5pOw&sparams=algorithm%2Cburst%2Ccp%2Cfactor%2Cgcr%2Cid%2Cip%2Cipbits%2Citag%2Csource%2Cupn%2Cexpire&fexp=905605%2C912307%2C916408%2C904462%2C922401%2C920704%2C912806%2C927201%2C925706%2C922403%2C925003%2C913546%2C913556%2C916805%2C920201%2C901451&ms=au&algorithm=throttle-factor&burst=40&ip=110.171.118.143&itag=35&gcr=th&sver=3&mt=1353008290&mv=m&source=youtube&key=yt1&ipbits=8&factor=1.25&cp=U0hUSFBOT19MU0NONF9ISFNIOklzRGZQRGZjT2ZW&expire=1353031779&id=fcb3f9bae2dcc02b&signature=A502CA49E371824CC73088794EDF9696C7BF0BCB.6252950158DAC2D427FB5D7941FAC33B5FB2278C: Input/output error
Not sure what to make of that, I'm testing it with videos that work fine over Samba or through my TV.
Where to next?
Thanks again for all the help! :)
Andy
Post Sat Nov 17, 2012 5:24 pm
Possibly the URL expired. Can you try to play a local file, instead of online youtube stream?
lmd
Post Sat Nov 17, 2012 8:01 pm
OK,
I've tried again with a fresh install, here's the log entry for where it fails (at least I think it is)
2012-11-18 02:58:29,795 DEBUG [CDSRetrieveMediaServerResource] Request for content delivery accepted
2012-11-18 02:58:29,795 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.37, Profile=Flash player'
2012-11-18 02:58:29,795 DEBUG [ResourceDeliveryProcessor] Request for resource 1779 and type 'MEDIA_ITEM' received
2012-11-18 02:58:29,795 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1779 (local)
2012-11-18 02:58:29,796 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1779)
2012-11-18 02:58:29,796 DEBUG [VideoDAOImpl] Reading a Video (id = 1779)
2012-11-18 02:58:29,797 DEBUG [VideoDeliveryEngine] Delivering item '1779' for client 'IPAddress=/192.168.1.37, Profile=Flash player'
2012-11-18 02:58:29,797 DEBUG [VideoDeliveryEngine] Delivering file 'South.Park.S16E13.720p.HDTV.x264-IMMERSE.mkv' using transcoding
2012-11-18 02:58:29,797 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.37, Profile=Flash player'
2012-11-18 02:58:29,797 WARN  [ServiioStatusService] IOException occured. Returning error code 500 to the REST layer. Message: Transcoded file '/tmp/Serviio/transcoding-temp-1779-flv_player-MEDIUM.stf' cannot be found, FFmpeg execution probably failed
2012-11-18 02:58:29,797 DEBUG [ServiioStatusService] Detailed exception:
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-1779-flv_player-MEDIUM.stf' cannot be found, FFmpeg execution probably failed
   at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:45)
   at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:125)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:95)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:120)
   at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:84)
   at org.serviio.upnp.service.contentdirectory.rest.resources.server.CDSRetrieveMediaServerResource.deliver(CDSRetrieveMediaServerResource.java:65)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
   at java.lang.reflect.Method.invoke(Method.java:616)
   at org.restlet.resource.ServerResource.doHandle(ServerResource.java:449)
   at org.restlet.resource.ServerResource.get(ServerResource.java:645)
   at org.restlet.resource.ServerResource.doHandle(ServerResource.java:527)
   at org.restlet.resource.ServerResource.doNegotiatedHandle(ServerResource.java:587)
   at org.restlet.resource.ServerResource.doConditionalHandle(ServerResource.java:299)
   at org.serviio.restlet.AbstractProEditionServerResource.doConditionalHandle(AbstractProEditionServerResource.java:35)
   at org.serviio.upnp.service.contentdirectory.rest.resources.server.AbstractCDSServerResource.doConditionalHandle(AbstractCDSServerResource.java:50)
   at org.serviio.upnp.service.contentdirectory.rest.resources.server.AbstractRestrictedCDSServerResource.doConditionalHandle(AbstractRestrictedCDSServerResource.java:53)
   at org.restlet.resource.ServerResource.handle(ServerResource.java:846)
   at org.restlet.resource.Finder.handle(Finder.java:510)
   at org.restlet.routing.Filter.doHandle(Filter.java:156)
   at org.restlet.routing.Filter.handle(Filter.java:203)
   at org.restlet.routing.Router.doHandle(Router.java:497)
   at org.restlet.routing.Router.handle(Router.java:737)
   at org.restlet.engine.application.StatusFilter.doHandle(StatusFilter.java:151)
   at org.restlet.engine.ChainHelper.handle(ChainHelper.java:111)
   at org.restlet.engine.application.ApplicationHelper.handle(ApplicationHelper.java:72)
   at org.restlet.Application.handle(Application.java:388)
   at org.restlet.Component.handle(Component.java:388)
   at org.restlet.Server.handle(Server.java:488)
   at org.restlet.engine.http.connector.BaseServerHelper.handle(BaseServerHelper.java:158)
   at org.restlet.engine.http.connector.BaseServerHelper.handleInbound(BaseServerHelper.java:167)
   at org.restlet.engine.http.connector.BaseHelper.handleNextInbound(BaseHelper.java:418)
   at org.restlet.engine.http.connector.Connection.readMessages(Connection.java:695)
   at org.restlet.engine.http.connector.Controller$2.run(Controller.java:95)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
   at java.lang.Thread.run(Thread.java:679)
What would I input on the command line to replicate directly with ffmpeg?
Thanks again for the help!
Andy
Post Mon Nov 19, 2012 1:29 pm
further up in the log it'll say Invoking ffmpeg to transcode file .. or similar - with the ffmpeg command. You'l have to copy and paste the command and wrap the file name in quotes (it it includes spaces, you don't have to otherwise). then post the result of the command.
lmd
Post Sat Nov 24, 2012 1:46 pm
zip wrote:further up in the log it'll say Invoking ffmpeg to transcode file .. or similar - with the ffmpeg command. You'l have to copy and paste the command and wrap the file name in quotes (it it includes spaces, you don't have to otherwise). then post the result of the command.
Cool - thanks, I'll get to it later.
Gonna watch a movie with the gf - using Serviio of course! It's a lifesaver :)
Thanks!
Andy
lmd
Post Sat Nov 24, 2012 5:29 pm
I rebuilt the ffmpeg library, as found on the ffmpeg site here http://ffmpeg.org/trac/ffmpeg/wiki/Ubun ... ationGuide and now it works - I've just got to fiddle around with the quality settings as I think I can improve the video quality.
I can't wait to try this out and show the guys at work heh heh :)
Thanks for your support - would you like me to mark this as 'SOLVED'?
Cheers,
Andy
Users browsing this forum: No registered users and 121 guests
