Serviio Not Found Over WLAN
patrick81
Post Mon Nov 19, 2012 1:48 am
All my devices that try to locate Serviio over the my local WLAN fail to find the device, but if I plugin to the router the device is found just fine. I can connect over my local Wifi to reach the server where Serviio is running, so the problem doesn't appear to be my wifi connection. I havn't made any changes to my server, client computers, or router in several months, so I don't understand why this spontaneously stopped working. I have looked on the forums and havn't found any solutions, I have even tried upgrading serviio versions. Any suggestions? What other information should I provide?
Serviio running on Ubuntu Linux
Can connect to it with PS3(1), Windows 7 Desktop and Windows 7 Laptop All hardwired to router
Can't connect with PS3(2), google tv, and Windows 7 laptop over Wifi
Thanks,
Patrick
mike_s104
Post Mon Nov 19, 2012 4:37 pm
Re: Serviio Not Found Over WLAN
Have you tried updating the firmware of the AP (or router that is providing wireless)? I had the same thing happen through a D-Link DIR-655.
patrick81
Post Wed Nov 21, 2012 10:14 pm
My router firmware is up to date, and no changes have been made to the network in months, and this setup has been running fine until recently. Any other suggestions?
patrick81
Post Fri Dec 07, 2012 11:05 am
Anyone have any ideas?
Post Fri Dec 07, 2012 2:07 pm
did you try to bind to your IP? (see FAQ).
miksa
Post Fri Dec 07, 2012 4:51 pm
patrick81 wrote:My router firmware is up to date, and no changes have been made to the network in months, and this setup has been running fine until recently. Any other suggestions?
to enable DLNA connection between wireless and wired devices i had to change one setting in my Verizon router: set "IGMP Proxy" to Disable.
- Mike
Users browsing this forum: Google [Bot] and 39 guests
