SOPCAST VIDEO WEB RESOURCE
silvadalula
Post Mon Oct 22, 2012 2:05 pm
Re: SOPCAST VIDEO WEB RESOURCE
jhb50 wrote:I have only used one feed 8902 but see if ffplay -i http://192.168.1.nn:8904 will play the second feed. If not it is a sopcast problem not serviio.
Ok, now it's ok. If I use http:/127.0.0.1:8904 isn't ok, but with local ip like in your example i can create nn differentes instances of sopcast in execution and i can see all in wdtvlive and samsung tv.
zowie
Post Mon Oct 22, 2012 7:53 pm
zowie
Post Mon Oct 22, 2012 8:25 pm
I must say that with this new configuration: http://192.168.1.nn:8904/ on my samsung C630 is much better no lockout and image of fluid flow at 1700 kbps, many thanks jhb50.
silvadalula
Post Sat Oct 27, 2012 3:01 pm
zowie wrote:I must say that with this new configuration: http://192.168.1.nn:8904/ on my samsung C630 is much better no lockout and image of fluid flow at 1700 kbps, many thanks jhb50.
The same in my wdtv live.
NX3
Post Sun Oct 28, 2012 10:08 am
I'm running sopcast on my desktop PC 192.168.1.101 and run serviio on my ubuntu media server box 192.168.1.106. I've changed the reference in the groovy plugin from localhost to 192.168.1.101 and the streams are now lost on all the media playback devices. However all say 'unable to playback' ! I've got Sony 2011 tvs and a PS3, the firewalls are open and VLC can play the steams 192.168.1.101:8902 between the pcs.
Does anyone else have a split setup and got it working ? Or working on Sony 2011 series tvs ?
footballscoccerfan
Post Tue Nov 20, 2012 6:45 am
Post Sun Nov 25, 2012 7:39 pm
What's that got to do with SOPCAST? Please post in a relevant thread.
Vintila
Post Mon Jan 21, 2013 9:11 am
Is this plugin compatible with the Xbox 360?. I am asking because Santa brought me an Xbox 360 and when I try to use the plugin the Xbox refuses to play the streams saying that the content is not compatible.
I have been enjoying this superb plugin for several months with my Samsung C7000 TV where it works like a charm, however it does not work with my Xbox. Other online plugins are working without issues with my Xbox (Ustream, Hahasports…) but not Sopcast.
Thanks for the support.
Vintila
Post Sun Jan 27, 2013 6:25 pm
None?
Post Sun Jan 27, 2013 10:41 pm
Better you post in Xbox thread. Its not a plug in problem.
txolovinsky
Post Sun Feb 10, 2013 4:51 pm
Hi, I have a Samsung ES7000 and when I play sports channels through Sopcast, the signal is cut too soon. Are there any changes that apply to avoid this problem? Thanks
Post Sun Feb 10, 2013 6:26 pm
That's the whole purpose of this plugin. it will handle 7 dropouts.
Vintila
Post Sun Feb 10, 2013 8:10 pm
txolovinsky wrote:Hi, I have a Samsung ES7000 and when I play sports channels through Sopcast, the signal is cut too soon. Are there any changes that apply to avoid this problem? Thanks
have you modified your profile in the way explained in the first post for Samsung C/D/E users?
Note for Samsung C/D/E profile users:
Due to a Serviio bug in 1.0.1, mpegts streams with h264 video and mp2 audio, fail in transcoding. To fix that, add the second line shown below following first line shown below in the first section of the C/D/E profile <Transcoding> entry. You may also add the third line, and then h264 mpegps as well as h264 mpegts and wmv.asf streams will transcode to MPEG2VIDEO making all these typical SOPCAST streams compatible and eliminate the need to refresh when switching between them.
<Matches container="mpegts" vCodec="h264" /> <!-- jhb50 fixes serviio h264.ts to h264.ts transcode bug -->
<Matches container="mpeg" vCodec="h264" /> <!-- optional -->
Post Sun Feb 10, 2013 9:06 pm
No. As it says that is a 1.0.1 bug fix, which was fixed in V1.1, so is no longer required.
Vintila
Post Sun Feb 10, 2013 10:47 pm
Really? The only way I get continuos playback without dropouts in my C7000 is with that modded profile and, yes, I am running Serviio 1.1.......
Post Mon Feb 11, 2013 1:48 am
It depends on what Sopcast stream you are playing.
BloodZ is notorious for streaming a non standard avc/mp2.mpegps stream which Serviio plays natively on the Samsung but is prone to dropouts. Everyone else uses avc/mp3.mpegts streams. The profile changes above would cause that stream and any other avc stream to be transcoded to mpeg2video/ac3.mpegts by ffmpeg before it is sent to the Samsung which may be why they play better for you.
Can you post what streams you are playing that fail without these changes and their ffmpeg -i attributes?
Post Tue Feb 12, 2013 4:16 pm
It seems that the above referenced bug is not fixed in 1.1 so the profile patch would still be required. It should be fixed in 1.2 which is now in beta test. viewtopic.php?f=5&t=7141&view=unread#unread
It would be good if you could post the debug log of the ffmpeg command used by Serviio when the Sopcast file is played without using the patch. This would allow me to verify that this is the case. Thanks
Vintila
Post Tue Feb 12, 2013 7:36 pm
Of course I will do! I really appreciate your efforts with all the plugins you have developed, especially with this one which is my favorite. I will post the debug log during the week end when I use mostly this plugin to watch the football matches.
Thanks for your support!
Vintila
Post Sun Feb 17, 2013 7:20 pm
As promised find attached the debug log file.
http://www.mediafire.com/?upzbs6jvejsefld
I have tried 3 different SOPCAST channels:
The first one, was the Sopcast channel 133000, Sop TV1 [RU] streaming at 3,000 Kbps bitrate. 4 cuts in a 20 minutes playback
The second one is the Zhujang TV streaming at 1071 kpbs, no cuts in a 10 minutes frame playback
The last one is the channel 141327 Digi Sport1 [RO] streaming at 1500 kbps. Continuous cuts, it ended up refusing to play it.
All the channels were played on the PC absolutely perfect
Regards
Post Mon Feb 18, 2013 6:49 am
As best as I can tell, without the profile changes, Serviio 1.1 will attempt to play the mpegts streams natively and your log confirms that, even though live streams should all be remuxed to mpegts.
While the profile changes were intended to fix a 1.0.1 bug (which your log confirms no longer exists in 1.1) they also result in transcoding the h264(avc) streams to mpeg2video.
I can only conclude from that, that the Samsung does not tolerate any glitches in the native avc/mpegts streams and drops out, but will play the streams if first transcoded to mpeg2video/mpegts.
I do not have the bandwidth to test SOPCAST at present, but it would be interesting to know if Samsung would play the avc/mpegts streams if they were remuxed to mpegts by serviio rather than played natively.
These additions to the Online Transcoding section would that, and handle the Bloodz avc/mpegps streams
<Video targetContainer="mpegts" >
Otherwise I would suggest you add the following to your online section in place of the prior patch to cause that transcoding to occur.
<Video targetContainer="mpegts" targetVCodec="mpeg2video">
Return to Available plugins
