Serviio Deleted half my software on uninstall
Additional note. Even after reinstalling Steam It is unable to connect to the internet. It would appear that something in windows is damaged. I will try the win7 disc to see if I can repair it
Burned wrote:Zip no offense, BUT something caused this. I was in the process of doing a uninstall of serviio. I couldnt figure out why it was going so slow so I opened the details portion. It was moving fast the only thing I could make out was "stalker shadow of Chernobyl" before I hit the kill switch. I can guarantee the only thing these two programs had in common was C drive. The stalker file still exists but critical files are gone and it will not run. this is just one of scores of programs. I would ask you to consider that I may be telling the truth and the symptoms i describe are accurate. There is no point to making them up.
All of this is absurd but there is nothing I can do at this point. I have purchased a new HD and will start over. I dont want to reinstall windows but may try reinstalling all my software.
Additional: it would appear there is something screwed up with my windows installer. Given this is win7 pro i have been unable to find a windows installer package.
zip wrote:It is a bug, as mentioned before. Will make a more durable installer for 1.1 (ie always add Serviio folder to the target location). As mentioned before, it deletes all files from the Serviio installation directory, so if you installed it into (let's say c:\Program Files instead of the default c:\Program Files\Serviio, you'd lose all files in c:\Program Files. It won't however, touch your registry. Obviously if the installation files of your programs have been removed, you won't be able to run them.
mike_s104 wrote:I hadn't read the other posts about the issue since I'm new here. My wife and I loved and used the free version so much I paid for the Pro version. As with any install, you don't to install it with any other programs. It's great Zip was willing to step up and admit the issue and that he's working on correcting it.
If you haven't done anything to the hard drive that had the data removed, it might still be there. I would try some software that is able to recover deleted data to see if you can recover anything. http://lifehacker.com/5237503/five-best ... very-tools
Might be too late, but maybe something to think about in the future. You could backup your hard drive to an external or secondary hard drive, If this happened and you had a backup, you might be able to recovery from the backup. The link below is the software that I've been using for years on my servers and desktops.
http://www.macrium.com/default.aspx
