BEEG - AN ADULT STREAMS VIDEO WEB RESOURCE
Post Sun Nov 11, 2012 7:36 am
Beeg offers a collection of over 8000 Adult Videos in reverse chronological order, up to 400 per page.
Implement as a Webresource, using the links of the form where www. is optional:
http://www.beeg.com = section/home/1
http://www.beeg.com/section/home[/n]
http://www.beeg.com/section/long-videos[/n]
http://www.beeg.com/tag/xxx[/n]
where n is a valid page number and xxx is one of the tags displayed under the 'tags' tab at http://www.beeg.com.
or to search
http://www.beeg.com/search?q=xxxxx
where xxxxx is the term within a video title.
If /n is not specified it defaults to page 1
If either page or tag are invalid, the home page 1 will be used.
The parameters start=xxx and for=yyy may also be used to define the range of videos to be accessed, otherwise 'start' will default to 1 and 'for' will default to the console value. For example http://www.beeg.com/section/home/20?start=399&for=1 will get video number 8000.
The groovy will post progress time stamps within the DEBUG log, and once items begin to be extracted will exit after 27 seconds and process items extracted to that point in order to avoid the Serviio 30 second timeout on slow cpu's.
Note that due to the common format of the beeg video urls, the groovy quickly generates the video urls for each file rather than slowly extract them from the beeg site with each refresh, and it only extracts the current url from beeg at playback time in case the beeg url has changed servers. For 350 videos this reduces the url extract refresh time from 22 minutes to 1 second.
Recent experience has shown however that urls using the alternate beeg servers are prone to failure and so with V10 the groovy offers a parameter usegen=1 to force the use the generated urls at playback time.
Version 2 - 5x Performance improvement, full tag,long and page support.
Version 3 - Eliminate repetative ffmpeg calls since all files are the same.
Version 4 - use console value as the 'for' default value.
Version 5 - Support revised web source
Version 6 - Major Performance improvement, Support search & http://beeg.com url, log progress timestamps.
Version 7 -Improved URL Extract Performance as well.
Version 8 - Fix titles and thumb extract, add option to generate urls
Version 9 - Eliminate genurls option and only extract when played.
Version 10 - Add usegen option to ignore new beeg urls
Version 11 - May 27, 2013 Fix empty search bug, video/titles mismatch.
Beeg.groovy
beeg.groovy V11 May 28, 2013
(8.1 KiB) Downloaded 6392 times
Xmantium
Post Mon Nov 12, 2012 1:12 am
Re: BEEG - AN ADULT STREAMS VIDEO WEB RESOURCE
Nice one! :D
Does it support the top Tag section such as http://beeg.com/tag/18
and Longer Videos section?
Post Mon Nov 12, 2012 1:25 am
Nope. I figured 400 were enough to keep anyone busy :shock:
miksa
Post Mon Nov 12, 2012 5:24 am
Xmantium wrote:Does it support the top Tag section such as http://beeg.com/tag/18
here is version to support tags :)
Beeg-tag.groovy
(3.54 KiB) Downloaded 3848 times
- Mike
Post Tue Nov 13, 2012 7:28 am
Version 2 posted with 5x performance improvement and full tag, long and page support.
Xmantium
Post Tue Nov 13, 2012 7:56 pm
jhb50 wrote:Version 2 posted with 5x performance improvement and full tag, long and page support.
Really appreciate the updates :P
Post Wed Nov 14, 2012 4:26 am
V3 posted which eliminates ffmpeg calls on new beeg feeds and plugin refreshes, making new beeg feed creation and refreshes very fast.
bikergrove
Post Sat Nov 17, 2012 6:44 pm
Thanks for this plugin.
Only one problem I can not get more than 10 videos with the long-videos,
This is what I'm using http://beeg.com/section/long-videos/1?start=1&for=50 but it only shows 10 videos, what am I doing wrong?
Post Sat Nov 17, 2012 9:40 pm
bikergrove
Post Tue Nov 20, 2012 10:47 pm
jhb50 thanks for that
zaer
Post Wed Nov 28, 2012 1:34 am
Hi
I tryed this but show only 10 videos why?
http://beeg.com/tag/tits+cumshot?start=5&for=50
http://beeg.com/tag/tits+cumshot/1?start=1&for=50
Don't working start&for in a category with two words or + in tags address?
bye
Xmantium
Post Wed Nov 28, 2012 8:17 am
Is it not possible for this plugin to get the number of videos set in the console settings automatically?
zaer
Post Thu Nov 29, 2012 1:13 am
I don't know... I waiting creator of plugins for other explication
Post Thu Nov 29, 2012 2:31 am
As it said, the tag must be valid. See the tags tab for the list.
Also as it said the default number displayed is 10. If you want more use the "for" option.
zaer
Post Thu Nov 29, 2012 2:16 pm
http://beeg.com/tag/tits+cumshot?start=1&for=50
The tag is valid but display only 10 videos not 50..
start&for is only for tag with one word?
Post Fri Nov 30, 2012 1:50 pm
As it says, correct form is http://www.beeg.com
Post Fri Nov 30, 2012 10:16 pm
Version 4 posted - now uses console value as default for 'for' value.
bikergrove
Post Fri Dec 14, 2012 1:53 pm
Is this still working? my folders are empty today
Post Sat Dec 15, 2012 12:15 am
Version 5 posted to support revised web source.
mqojdn
Post Fri Jan 04, 2013 2:41 pm
Return to Available plugins
