PC Restart
zombyzzz2609
Post Tue Mar 20, 2012 11:21 pm
PC Restart
I have Serviio 0.6.2 installed and working. However when I shutdown or restart my PC I get a Windows "End Program - ServiioConsole" error. I can't restart or shutdown until I click the "End Now" button. Any ideas? Thank you
serviio-buddy
Post Tue Mar 20, 2012 11:28 pm
Re: PC Restart
Which version of Windows are you using ?
serviio-buddy
SONY SMP-N100 Media Player, HP PC: Vista 32/Ubuntu 11.10, Serviio 0.6.2, XBMC, VLC, ASUS eeePC Netbook: Vista 32, XBMC, SHARP Aquos BD-HP25U DLNA Blu-Ray Player
HowTo: Provide supported formats of a device | Record a new ticket on Bitbucket | Provide details of a video file that doesn't play | Turn on detailed logging
bjurran
Post Wed Mar 21, 2012 10:59 am
Re: PC Restart
Borrowing thread to let you know that I've seen the same thing on my WHS 2k3 when logged on using RDP.
Post Wed Mar 21, 2012 12:38 pm
Re: PC Restart
I did some updates to the console for the next verion, hopefully it'll be fixed. You can as well join beta group to try to confirm if it's still there or not before we go live.
zombyzzz2609
Post Thu Mar 22, 2012 1:40 am
Re: PC Restart
Serviio-Buddy: Using Windows XP SP3.
zip: How do I join the beta group?
serviio-buddy
Post Thu Mar 22, 2012 4:06 am
Re: PC Restart
For XP, I would recommend unistalling/reinstalling Serviio. Then try it again.
serviio-buddy
Post Thu Mar 22, 2012 10:58 am
Re: PC Restart
zombyzzz2609 wrote:Serviio-Buddy: Using Windows XP SP3.
Normally just sending Zip a PM is all you have to do.
gco
Post Thu Nov 22, 2012 7:52 am
Re: PC Restart
I have this problem too. The PC in question (running XP) shuts down fine normally, but hangs waiting for serviio if serviio has actually been used since the last boot. It's a bit annoying because after I think I've shut down the PC I don't discover it's hung until I next want to use it.
gco
Post Thu Nov 22, 2012 7:55 am
Re: PC Restart
Sorry - should have said - I'm running serviio pro v 1.0.1
