<DC:Date> YYYY format on Movies not supported?
ginjaninja
Post Wed Nov 21, 2012 7:51 pm
Serviios seems to be transmitting <dc:date> YYYY-MM-DD for TV and <dc:date> YYYY for movies.
My TV Samsung ES7000 doesnt understand YYYY and this format produces a spurious result on the TV UI. (it is happy with the TV format)
The Samsung software transmits YYYY-DD-MMTHH:MM:SS for movies (based on filesystem date modified, rather than release date).
So it would appear that whilst the Tv supports multiple date formats it does not support serviios choice for movies...is there anything the user can do to configure the date format communicated.
Indeed does serviio even store the release date by month and day for movies..or just a year.
thanks
Post Thu Nov 22, 2012 8:27 pm
Re: <DC:Date> YYYY format on Movies not supported?
It should send DD-MM-YYYY for everything. How do you get the movie metadata (online, xbmc)? What movie it is?
ginjaninja
Post Fri Nov 23, 2012 11:04 am
1000 apologies for wasting time, i cant reproduce it...testing too many different products..i must have made a mistake..
looks like the tv is receiving
<dc:date>2012-08-10</dc:date>
YYYY-MM-DD
and the tv has no problem with that.
POST /serviceControl HTTP/1.1
Accept: */*
User-Agent: SEC_HHP_[TV]UE46ES7000/1.0 DLNADOC/1.50
Host: 192.168.4.53:8895
SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
CONTENT-TYPE:  text/xml; charset="utf-8"
Content-Length: 467
Connection: close
<?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><ObjectID>V_F^FOL_R11$F7364</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter>*</Filter><StartingIndex>0</StartingIndex><RequestedCount>1</RequestedCount><SortCriteria></SortCriteria></u:Browse></s:Body></s:Envelope>HTTP/1.1 200 OK
EXT:
Date: Fri, 23 Nov 2012 10:48:46 GMT
Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1
Content-Length: 2427
Content-Type: text/xml; charset="utf-8"
Connection: close
<?xml version="1.0" encoding="utf-8" ?><SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><SOAP-ENV:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><?xml version="1.0" encoding="UTF-8" standalone="no"?><DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dlna="urn:schemas-dlna-org:metadata-1-0/" xmlns:sec="http://www.sec.co.kr/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/"><item id="V_F^FOL_R11$F7364$MI71027" parentID="V_F^FOL_R11$F7364" restricted="1"><dc:title>2 Days in New York (2012).mkv</dc:title><upnp:class>object.item.videoItem</upnp:class><upnp:albumArtURI dlna:profileID="JPEG_TN">http://192.168.4.53:8895/resource/106153/COVER_IMAGE</upnp:albumArtURI><upnp:icon>http://192.168.4.53:8895/resource/106153/COVER_IMAGE</upnp:icon><dc:date>2012-08-10</dc:date><upnp:genre>Comedy</upnp:genre><dc:description>Marion and Mingus live cozily ... perhaps too cozily ... with their cat and two young children from previous relationships. However, when Marion...s jolly father, her oversexed sister, and her sister...s outrageous boyfriend unceremoniously descend upon them for a visit, it initiates two unforgettable days that will test Marion and Mingus...s relationship. With their unwitting racism and sexual frankness, the French triumvirate hilariously has no boundaries or filters... and no person is left unscathed in its wake.</dc:description><upnp:rating>Unknown</upnp:rating><res bitrate="816000" duration="1:35:44.000" protocolInfo="http-get:*:video/x-mkv:DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000" resolution="1280x696" size="4687566575">http://192.168.4.53:8895/resource/71027/MEDIA_ITEM/MATROSKA-0/ORIGINAL</res><res protocolInfo="http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=00D00000000000000000000000000000" resolution="107x160">http://192.168.4.53:8895/resource/106153/COVER_IMAGE</res></item></DIDL-Lite></Result><NumberReturned>1</NumberReturned><TotalMatches>1</TotalMatches><UpdateID>4</UpdateID></u:BrowseResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
Post Sun Nov 25, 2012 3:06 pm
cool.
