Matches folder=
nickski
Post Fri Nov 23, 2012 3:38 pm
Matches folder=
I have a small number of movies that have very high peak bit rates that stutter or even stop during play back.
At the moment I have a choice of manually transcoding the movie (lengthy) or temporarily restarting Serviio with a profile that transcodes everything.
Would it be possible to change Serviio to force transcoding of movies found in a particular folder - irregardless of other active profile settings?
Maybe add a "Matches folder=" parameter to profile processing.
nickski
Render: Panasonic Viera TX-L42E30B + DMP-BDT210 + Jelly Bean 4.1 Tablet + Onkyo TX-NR616 | Server: Intel i5 Win 7 ult x64 | NW: Homeplug @ 175 Mbps
Post Fri Nov 23, 2012 3:45 pm
Re: Matches folder=
nickski wrote:At the moment I have a choice of manually transcoding the movie (lengthy) or temporarily restarting Serviio with a profile that transcodes everything.
You don't have to restart serviio, I usually change profile on serviio console then click save.
nickski
Post Sat Nov 24, 2012 8:27 am
Re: Matches folder=
Thanks Illico - I didn't realize I could change the profile on the fly - without restarting.
nickski
Return to Feature requests
