Samsung PS51E550 transcoding and subtitle not working
bedo
Post Sun Nov 25, 2012 8:08 am
My Samsung plasma doesn't show subtitles using serviio. Subtitles have the same name as video. I'm running serviio from Synology NAS. But using Synology media server I have no problem to play video with subtitles.
I'm using Samsung c/d/e profile. Any hints?
Next issue is with the transcoding. I have a mkv @5.1 ref frames 16. This is not supported by Samsung. Is there a way how to play this file? How can I test if transcoding has even started? I tried to modify the profile with match * and transcode to asf and low bit rate - so as a result I'd expect low res playback for all files. But they all play in their native quality.
Thanks for help.
bedo
Post Sun Nov 25, 2012 9:13 am
Re: Samsung PS51E550 transcoding and subtitle not working
well, I did some testing and I installed the serviio on my laptop (win7). Using this server I'm able to play subtitles without any problems. So the problem lays somewhere in the NAS Serviio. Plex Media server also doesn't play subtitles. Only Synology Media Server does work.
With the transcoding I have no success.
This is the output of ffmpeg -i (from Synology NAS)
Jamaica> ffmpeg -i /volume1/video/_serialy/Planet.Earth.2006.1080p.HDDVD.x264-AJ
P/Planet.Earth.01.From.Pole.to.Pole.2006.1080p.HDDVD.x264-AJP.mkv
ffmpeg version UNKNOWN, Copyright (c) 2000-2011 the FFmpeg developers
  built on Sep 26 2012 03:38:04 with gcc 4.2.1
  configuration: --arch=arm --target-os=linux --cross-prefix=/usr/local/arm-none        -linux-gnueabi/bin/arm-none-linux-gnueabi- --enable-cross-compile --enable-optim        izations --disable-yasm --disable-altivec --enable-pic --enable-shared --disable        -static --disable-swscale-alpha --disable-ffserver --disable-ffplay --enable-lib        mp3lame --enable-libfaac --enable-nonfree --enable-version3 --enable-libopencore        -amrnb --enable-libopencore-amrwb --disable-decoder=amrnb
  libavutil    50. 40. 1 / 50. 40. 1
  libavcodec   52.120. 0 / 52.120. 0
  libavformat  52.108. 0 / 52.108. 0
  libavdevice  52.  4. 0 / 52.  4. 0
  libavfilter   1. 77. 0 /  1. 77. 0
  libswscale    0. 14. 0 /  0. 14. 0
[matroska,webm @ 0x33fc0] max_analyze_duration reached
[matroska,webm @ 0x33fc0] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (5994/125) -> 23.98 (24000/1001)
Input #0, matroska,webm, from '/volume1/video/_serialy/Planet.Earth.2006.1080p.HDDVD.x264-AJP/Planet.Earth.01.From.Pole.to.Pole.2006.1080p.HDDVD.x264-AJP.mkv':
  Duration: 00:53:20.65, start: 0.000000, bitrate: 11735 kb/s
    Stream #0.0: Video: h264 (High), yuv420p, 1920x1080, PAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s (default)
      title           : English (AC3)
    Stream #0.2(eng): Subtitle: ass (default)
    Stream #0.3: Attachment: [0][0][0][0] / 0x0000
      filename        : exprswy_free.ttf
    Stream #0.4: Attachment: [0][0][0][0] / 0x0000
      filename        : Framd.TTF
This is the output of mediainfo:
\\192.168.0.7\video\_serialy\Planet.Earth.2006.1080p.HDDVD.x264-AJP\Planet.Earth.01.From.Pole.to.Pole.2006.1080p.HDDVD.x264-AJP.mkv
      Unique ID : 234889861999101227410480373199304244556 (0xB0B624529F20B0E3837851B0CB2DBD4C)
      Complete name : \\192.168.0.7\video\_serialy\Planet.Earth.2006.1080p.HDDVD.x264-AJP\Planet.Earth.01.From.Pole.to.Pole.2006.1080p.HDDVD.x264-AJP.mkv
      Format : Matroska
      Format version : Version 1
      File size : 4.37 GiB
      Duration : 53mn 20s
      Overall bit rate : 11.7 Mbps
      Encoded date : UTC 2007-05-12 15:33:30
      Writing application : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55
      Writing library : libebml v0.7.7 + libmatroska v0.8.1
      Attachment : Yes / Yes
   Video #1
      Format : AVC
      Format profile : High@L5.1
      Format settings, CABAC : Yes
      Format settings, ReFrames : 16 frames
      Codec ID : V_MPEG4/ISO/AVC
      Duration : 53mn 20s
      Bit rate : 11.3 Mbps
      Width : 1 920 pixels
      Height : 1 080 pixels
      Display aspect ratio : 16:9
      Frame rate : 23.976 fps
      Color space : YUV
      Chroma subsampling : 4:2:0
      Bit depth : 8 bits
      Scan type : Progressive
      Bits/(Pixel*Frame) : 0.227
      Stream size : 4.12 GiB (94%)
      Writing library : x264 core 55 svn-655
      Encoding settings : cabac=1 / ref=16 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=2 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=11305 / ratetol=1.5 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
      Default : Yes
      Forced : No
   Audio #2
      Format : AC-3
      Format/Info : Audio Coding 3
      Codec ID : A_AC3
      Duration : 53mn 20s
      Bit rate mode : Constant
      Bit rate : 448 Kbps
      Channel(s) : 6 channels
      Sampling rate : 48.0 KHz
      Bit depth : 16 bits
      Compression mode : Lossy
      Stream size : 171 MiB (4%)
      Title : English (AC3)
      Language : English
      Default : Yes
      Forced : No
   Text #3
      Format : ASS
      Codec ID : S_TEXT/ASS
      Codec ID/Info : Advanced Sub Station Alpha
      Compression mode : Lossless
      Language : English
      Default : Yes
      Forced : No
bedo
Post Sun Nov 25, 2012 9:46 am
another update. Everyting works from win7 serviio, even transcoding.
So my problem is Synology NAS Serviio doesn't play subtitle and doesn't do transcoding. Anyone has had a similar issue?
thanks
Users browsing this forum: Baidu [Spider] and 12 guests
