SvtPlay
ottomatic
Post Sat Nov 24, 2012 4:57 pm
Re: SvtPlay (Sweden only)
dtp wrote:FFMPegWrapper in folder lib: SET PATH_TO_FFMPEG="C:\Program Files\Serviio\lib\FFMPeg.exe"
ServiioService.exe in folder bin: -Dffmpeg.location="C:\Program Files\Serviio\lib\FFMPegWrapper.bat"
still the same error...
Did you restar the windows service after you made the changes?
ottomatic
Post Sat Nov 24, 2012 5:03 pm
Also: is the wrapper actually located in the lib directory?
Please stop the windows service, delete the serviio log file, and start the service again.
dtp
Post Sun Nov 25, 2012 7:28 am
I did restart the windows service (and the computer as well).
The Wrapper is located in the lib folder.
Even though I deleted the log-file the new one is huge (>500kb). Deleted the logs from yesterday to be able to post it here.
log.txt
(129.2 KiB) Downloaded 1138 times
ottomatic
Post Sun Nov 25, 2012 7:51 am
The wrapper is still not called.
Please attach the following file:
C:\Program Files\Serviio\bin\ServiioService.exe.vmoptions
If indeed you have the ffmpeg.location option in there, perhaps you should try removing the quotes around the path.
What version of Windows are you on?
dtp
Post Sun Nov 25, 2012 12:54 pm
I'm on Windows Vista, removed the quotes but it didn't help.
Added the underscore to be able to post it here.
ServiioService.exe_.txt
(74 Bytes) Downloaded 1119 times
ottomatic
Post Sun Nov 25, 2012 3:21 pm
This is a .txt - file.
Is it not named ServiioService.exe.vmoptions on your machine?
csholmq
Post Mon Nov 26, 2012 10:20 am
I found a bug in the script. When a filename (or input) has multiple whitespaces in it, it gets trimmed down to one.
Change code to
# Unescape the escaped commas
FILENAME=`echo "$2" | sed -e 's/%2c/,/g'`
and the echo command won't trim down down any whitespaces!
ottomatic
Post Mon Nov 26, 2012 10:28 am
OK.
I updated the linux wrapper in the zip file in the original post.
dtp
Post Tue Nov 27, 2012 7:42 am
ottomatic wrote:This is a .txt - file.
I had to rename it to be able to post it on this forum. It is named ServiioService.exe.vmoptions in my laptop.
dualc
Post Tue Nov 27, 2012 9:40 am
Hi..
Trying out this plugin and i got it to work yesterday, ... BUT
Today whan i trie even with a new install i dont get eny luck at all.. i use "http://www.svtplay.se/?tab=news&sida=1" as Webresource and this is what the log tells me.
"2012-11-27 10:31:40,361 DEBUG [FeedItemUrlExtractor] SvtPlayWebResouceExtractor: SvtPlayWebResouceExtractor: finished extracting items for url: http://www.svtplay.se/?tab=news&sida=1 . Found 0 items
2012-11-27 10:31:40,364 DEBUG [OnlineContentCacheDecorator] Stored online content 'http://www.svtplay.se/?tab=news&sida=1' in the cache (online_feeds), returning it
2012-11-27 10:31:40,364 DEBUG [OnlineLibraryManager] Resource http://www.svtplay.se/?tab=news&sida=1 will expire in the cache on Wed Nov 28 10:31:40 CET 2012
2012-11-27 10:31:40,385 DEBUG [RepositoryDAOImpl] Reading all Repositories"
I have installed the plugin + FFMpeg wrapper + jar files in the correct directories and pointing to each other as well ...
So i dont know what i have done wrong..
Forgot to tell im using Windows 7 64bit as well.
/M
BlurayPlayer: Samsung BD-C5500
TV: Samsung LE40B535
ottomatic
Post Tue Nov 27, 2012 9:44 am
dualc wrote:Hi..
Try increasing the number at the end of the url, thus:
http://www.svtplay.se/?tab=news&sida=5
If that doesn't work, please post the full as an attachment.
ottomatic
Post Tue Nov 27, 2012 10:07 am
dualc,
I tested it myself (even the exact url you posted), and it works for me. Perhaps the pirateplay API was down this morning?
Regards
/ O
dualc
Post Tue Nov 27, 2012 2:30 pm
Ottomatic:
I did as un asked me, i also uninstalled and did a new install of whole Serviio program before i did the changes, and i got the same result.
Here is my log ....
/M
(51.55 KiB) Downloaded 1002 times
ottomatic
Post Tue Nov 27, 2012 3:27 pm
OK.
This time you don't get a result because the plugin does not handle the "Max items to retrieve" property being set to -1.
If you configure your online streams with a "Max items to retrieve" larger than zero it should work.
Meanwhile I will update the plugin to allow a blank value (or -1) indicating that the client wants to receive an unlimited number of items.
Update will be posted shortly.
dualc
Post Tue Nov 27, 2012 3:29 pm
Ottomatic:
Aha, cool.. yeah i have in mind i changed it to Unlimited, i will trie and change it to see if i get a better luck.
/M
ottomatic
Post Tue Nov 27, 2012 3:41 pm
I updated the plugin attachment in the original post with version 1.1.1, which allows unlimited items.
dualc
Post Tue Nov 27, 2012 3:59 pm
Thanks Ottomatic, it's seems to work as it should now.. :)
/M
csholmq
Post Wed Nov 28, 2012 12:41 pm
Btw, it's spelled "SvtPlayWebResourceExtractor", not "SvtPlayWebResouceExtractor" :)
ottomatic
Post Wed Nov 28, 2012 1:00 pm
csholmq wrote:Btw, it's spelled "SvtPlayWebResourceExtractor", not "SvtPlayWebResouceExtractor" :)
No. That's another plugin. (Security by obscurity)
Frallan
Post Thu Nov 29, 2012 8:43 pm
This link seems to work with some Samsung TVs...
beta.svtplay.se/
Maybe there is a way to make it work for serviio?
Return to Available plugins
