CricFree.TV [LAST UPDATED: Oct 08, 2012]
Post Tue Oct 23, 2012 3:53 pm
Re: CricFree.TV [LAST UPDATED: Oct 08, 2012]
The cricfree site works fine but the plugin returns nothing. The current link I found for skysports 1 is rtmp://199.115.114.221:1935/live/_defin ... 1112121221
2012-10-23 08:59:32,645 DEBUG [OnlineLibraryManager] Resource http://www.cricfree.tv/ not in cache yet, loading it
2012-10-23 08:59:32,645 DEBUG [WebResourceParser] Parsing web resource 'http://www.cricfree.tv/'
2012-10-23 08:59:32,646 DEBUG [WebResourceParser] Found matching url extractor (cricfree.tv) for resource http://www.cricfree.tv/
2012-10-23 08:59:32,646 DEBUG [FeedItemUrlExtractor] cricfree.tv: Starting parsing resource: http://www.cricfree.tv/
2012-10-23 08:59:34,382 DEBUG [FeedItemUrlExtractor] cricfree.tv: Starting extraction of url for item: skysports1
2012-10-23 08:59:35,085 DEBUG [FeedItemUrlExtractor] cricfree.tv: CRICFREE.TV - -NOTFOUND-
2012-10-23 08:59:35,085 DEBUG [FeedItemUrlExtractor] cricfree.tv: Finished extraction of url: no result
2012-10-23 08:59:35,085 WARN  [WebResourceParser] Plugin cricfree.tv returned no value for resource item 'skysports1'
2012-10-23 08:59:35,085 DEBUG [WebResourceParser] Skipping web resource item 'skysports1' because it's not of type VIDEO
2012-10-23 08:59:35,085 DEBUG [FeedItemUrlExtractor] cricfree.tv: Starting extraction of url for item: skysports2
2012-10-23 08:59:35,597 DEBUG [FeedItemUrlExtractor] cricfree.tv: CRICFREE.TV - -NOTFOUND-
2012-10-23 08:59:35,597 DEBUG [FeedItemUrlExtractor] cricfree.tv: Finished extraction of url: no result
2012-10-23 08:59:35,597 WARN  [WebResourceParser] Plugin cricfree.tv returned no value for resource item 'skysports2'
2012-10-23 08:59:35,597 DEBUG [WebResourceParser] Skipping web resource item 'skysports2' because it's not of type VIDEO
2012-10-23 08:59:35,597 DEBUG [FeedItemUrlExtractor] cricfree.tv: Starting extraction of url for item: skysports3
2012-10-23 08:59:36,016 DEBUG [FeedItemUrlExtractor] cricfree.tv: CRICFREE.TV - -NOTFOUND-
2012-10-23 08:59:36,016 DEBUG [FeedItemUrlExtractor] cricfree.tv: Finished extraction of url: no result
2012-10-23 08:59:36,016 WARN  [WebResourceParser] Plugin cricfree.tv returned no value for resource item 'skysports3'
2012-10-23 08:59:36,016 DEBUG [WebResourceParser] Skipping web resource item 'skysports3' because it's not of type VIDEO
2012-10-23 08:59:36,016 DEBUG [FeedItemUrlExtractor] cricfree.tv: Starting extraction of url for item: skysports4
2012-10-23 08:59:36,415 DEBUG [FeedItemUrlExtractor] cricfree.tv: CRICFREE.TV - -NOTFOUND-
2012-10-23 08:59:36,415 DEBUG [FeedItemUrlExtractor] cricfree.tv: Finished extraction of url: no result
2012-10-23 08:59:36,415 WARN  [WebResourceParser] Plugin cricfree.tv returned no value for resource item 'skysports4'
2012-10-23 08:59:36,415 DEBUG [WebResourceParser] Skipping web resource item 'skysports4' because it's not of type VIDEO
2012-10-23 08:59:36,415 DEBUG [FeedItemUrlExtractor] cricfree.tv: Starting extraction of url for item: espn
2012-10-23 08:59:37,071 DEBUG [FeedItemUrlExtractor] cricfree.tv: CRICFREE.TV - -NOTFOUND-
2012-10-23 08:59:37,071 DEBUG [FeedItemUrlExtractor] cricfree.tv: Finished extraction of url: no result
2012-10-23 08:59:37,071 WARN  [WebResourceParser] Plugin cricfree.tv returned no value for resource item 'espn'
2012-10-23 08:59:37,071 DEBUG [WebResourceParser] Skipping web resource item 'espn' because it's not of type VIDEO
2012-10-23 08:59:37,071 DEBUG [FeedItemUrlExtractor] cricfree.tv: Starting extraction of url for item: eurosports
Post Mon Oct 29, 2012 9:22 pm
I have created a modified plugin that corrects the problem reported above. Feel free to use it until the author corrects the original version.
EDIT: I have repaced this update with a new SkySportsPlus.groovy.
See viewtopic.php?f=20&t=8128
yaro
Post Thu Nov 01, 2012 11:00 am
It is still not working.
Post Sun Nov 11, 2012 7:08 am
TEMP Version 2 Posted Above viewtopic.php?f=20&t=7556&p=55952#p55359
Post Tue Nov 13, 2012 8:27 am
TEMP Version 3 Posted Above viewtopic.php?f=20&t=7556&p=55952#p55359
Corrects cacheKey so refresh will work correctly.
arsaboo
Post Fri Nov 16, 2012 1:32 am
Still not working :(
Post Fri Nov 16, 2012 5:25 am
Working fine for me. Post a debug log showing a forced refresh.
csholmq
Post Fri Nov 16, 2012 9:57 am
Works for me.
sarsonuk
Post Sat Nov 17, 2012 11:40 am
I now something showing in the directory on the tv however all links dont play but when I try the same link on the mac it works fine. Any known reasons?
Post Sat Nov 17, 2012 4:42 pm
My temp update works fine for me.
Post Sun Nov 18, 2012 6:37 am
TEMP Version 4 Posted Above
adds mips.tv support.
Note: the site has started to use myhdtv.com for some channels, however I am unable to access them so they will not appear.
blokey
Post Sun Nov 18, 2012 9:12 pm
I just get no items to display every time. I have never managed to get this working. Here is my log, any advice would be greatly received.
(24.83 KiB) Downloaded 1673 times
yaro
Post Sun Nov 18, 2012 10:44 pm
blokey wrote:I just get no items to display every time. I have never managed to get this working. Here is my log, any advice would be greatly received.
Try downloading serviio again.
Post Mon Nov 19, 2012 1:44 am
You need to post a DEBUG log. Yours does not show enough information.
blokey
Post Mon Nov 19, 2012 9:03 pm
Here is the debug log, I have found something interesting though, if I access the serviio library through VLC, the channels turn up and i can play them, they just don't appear on my sony tv at all, strange!
serviio.zip
(62.12 KiB) Downloaded 3899 times
Post Mon Nov 19, 2012 11:01 pm
Your log is cluttered with all kinds of requests from another device plus playlist and other invalid feeds. As best as I can see you tried to display the cricfree menu while the feed was being refreshed, so obviously it has been removed and will not be available until the refresh is complete.
Post Sun Nov 25, 2012 8:24 pm
A new SkySportsPlus groovy has been posted to replace this one.
Previous
Return to Available plugins
Users browsing this forum: No registered users and 283 guests
