Transcoding temp folder
galmok
Post Sun Nov 25, 2012 9:57 pm
I am wondering if other folders then the transcoding temp folder is being used when transcoding. The reason I ask is that I have a lot of data written to my C-drive (windows drive) whenever I use Serviio transcoding feature even though I have set it to use drive I (i, another drive). I can see amount of data written as SMART registers record this on a SSD drive.
So, does Serviio use the windows drive (C:) as well as the configured transcoding folder?
Post Mon Nov 26, 2012 3:09 pm
Re: Transcoding temp folder
No it should not. Do you see the transcoding files being created on the I drive?
galmok
Post Wed Nov 28, 2012 12:28 am
I do see files being put on drive I.
Post Wed Nov 28, 2012 12:30 pm
Is this when you watch on MediaBrowser on using DLNA? I think the web Flash player caches the files as well somewhere.
